Introduction: Baby Go Round
Picture of Baby Go Round
baby go round, Halloween prop
what you will need:
wood, for the base and spinning platform i used some scrap i had it is 3' in diameter
a ceiling fan, they are cheep
3/4" pvc pipe and fittings
paint,screws,jig saw,
Step 1: Mounting the Fan
Picture of Mounting the Fan
i took the base and connected the ceiling fan to it with some dry wall screws
Step 2: Cutting Out Spinning Platform
Picture of Cutting Out Spinning Platform
i cut out a 3' round piece of plywood and also cut a 7" hole in the center for the fan
Step 3: The Spinning Platform
Picture of The Spinning Platform
set the top plywood over the fan, attach the blade hardware to the fan then mount the plywood to the bottom side of the blade holders
Step 4: The Frame for the Babies
Picture of The Frame for the Babies
i used a 3/4" pvc 3 way fitting fitting which is basically a 90 with a kick off on one side, build a square and then four corners go down to the platform, if you mark out where they sit and screw 4 pvc caps down to the platform then slide in the frame over the top
Step 5: Paint and Testing
Picture of Paint and Testing
you can paint if you choose, i did a memorizing spiral that looks awesome when spinning,
wire in a cord to the motor and add whatever you want to spin
here is the finished prop https://www.youtube.com/watch?v=aWS-G-15j3o
BoyWonder620 (author)2014-09-08
So Awesome!!!
About This Instructable
301views
6favorites
License:
Bio: I love to create, I find a way to mimic what I see, and since I am a stubborn German I usually succeed.
More by rayzer95:baby go roundCamping hand wipesGIANT SPIDER
Add instructable to:
