3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
baking soda and vinegar rocket
it's very easy to make and with luck you can launch it about 200 feet.
all you need is a plastic 16 oz. bottle with a cheap lid. (crystal geyser works great)
and baking soda and vinegar.
this is my first instructable so don't judge it too hard
Step 1Mix!!
put in baking soda and vinegar, about 2 tablespoons of each, and shake until the bottle is good and hard.
you can experiment and put different amounts of the stuff but make sure it doesn't blow up!
i'm not liable for anything bad that happens during your experimenting, broken windows, broken bones, loss of limbs, ect.
31 comments
Jun 23, 2008. 6:27 PMgrimfig says:
I did this with a really tiny pepsi max bottle and it shot like 30ft.
Jul 6, 2008. 1:42 PMcodongolev says:
what the heck is your picture?!?!
Jul 6, 2008. 2:19 PMgrimfig says:
Some random picture I found when I googled fat man or something. What is yours huh?!?!?!
Apr 21, 2012. 3:44 PMtinker234 says:
i think it is sid
Jul 6, 2008. 6:17 PMcodongolev says:
the default with swan wings cropped in from wikipedia.
Feb 26, 2012. 6:05 PMgunpro says:
all u have to do is put in the viniger and baking soda put on the lid and shake, when it is insanely hard point it strait up and spin the cap off
Jul 26, 2007. 12:00 AMghicken says:
I did an instructable like this, it might help.HereHere
and this is the video of me doing it.
Aug 11, 2010. 5:43 AMToddisI says:
Yes but you made a quote, "bomb".
Aug 11, 2010. 4:20 PMghicken says:
Really it depends on how you throw it, what surface it hits, vinegar/baking soda ratio, and the type of bottle that decides whether or not it rockets off or just explodes. I just chose to use "bomb".
Aug 16, 2010. 1:50 PMToddisI says:
true, sorry if i offended u or something... :D
Jul 16, 2010. 11:26 AMminiclipper says:
what if you just throw strait down.
Jan 24, 2009. 12:13 AMfrikkie says:
I was thinking if you take the bottle and make a hole near the top of the bottle.Then insert a little pipe connection.You can then make a dripstand with vinegar,this you'l use to drip vinegar into the bottle.But first make a small hole in bottom of bottle and cover the hole with tape.Then connect the pipe of the drip to the bottle. One will have to connect the pipe in such a way that the bottle dont stick to it,but release.The tape should be a strong adhesive tape like ducktape. As pressure builds the reaction should blast through the bottom hole and send the bottle up. Let me know what you think. :)
Feb 21, 2009. 10:53 AMbylerfamily says:
...And I just made the instructable for it.
Feb 22, 2009. 9:45 PMfrikkie says:
nice!
Apr 18, 2009. 4:21 AMbylerfamily says:
Do you mean the instructable itself or me making the instructable.
Apr 19, 2009. 10:27 PMfrikkie says:
That you made the instructable dude.
Apr 20, 2009. 4:05 AMbylerfamily says:
Okay.
Feb 18, 2009. 12:31 PMbylerfamily says:
Cool!I am designing a rocket with a release mechanism exactly like that.
Feb 28, 2009. 11:18 AMbassclarinet23 says:
I usually chuck it as far as possible down the street.
Feb 21, 2009. 3:24 PMrock climber says:
I tried this and I threw the rocket like 20 feet infront of me, and next thing i know it flies about a foot away from my face, and kept going for another 20 feet.
Sep 14, 2008. 3:31 PM456acdc5443 says:
this looks cool i will try it
Sep 7, 2008. 12:50 AMNoodle god says:
I use gatorade bottle and they work fine for me
Jul 8, 2008. 9:40 AMpyrowithinpyro says:
u have to throw the bottle so that the lid hits the hard ground
Jul 4, 2008. 10:59 AMFirebang says:
Question: If you substituted the lid for something that would come off easier under pressure, but still maintaining a high-pressure release threshold, would that still work? I just thought it up in my head, and it would eliminate the chance of you chucking it at the ground and it either a)landing on it's side or bottom b)launching, and hitting someone because of a dangerous launch. Cheers, Tyler (Fires and bangs)
Jun 23, 2008. 6:02 PMgrimfig says:
Yeah but Crystal Geyser is kinda thin. So something a little probably not gatorade unless you screw it on really tight.
Jun 9, 2008. 10:34 AMlitlechica101 says:
you should put picture they are more helpful!!!!
Jul 15, 2007. 1:25 PMscorp says:
:) i turner my rockets into grenades... thanks for the idea tho...also somthing you could do that is more reliable...:if you pound a nail into the cap after tying a string to it then after doing all that, you can just pull a string to pull the nail out to launch it..the best way would be to drill a hole in a board to fit it.
Feb 16, 2008. 4:14 AMwiebevandomburg.hotmail.com says:
could you fill it with vinegar and baking soda, stick it with two sticks in the ground,with the lid about 5 cm above the ground and melt the cap with a long end lighter
Jan 28, 2008. 11:22 AMkallno36 says:
Nice idea I am about to try it.
Jan 21, 2008. 1:01 PMJames M says:
I was gonna do an Instructable on this, but alas, you beat me to it. I get even better results with the little 8 or 12 ounce pepsi bottles. You can reuse the bottles since the plastic is pretty thick, and you can grab extra caps off of any other soda bottle, since its a pretty generic size.
Jul 25, 2007. 1:30 AMryan289 says:
i tried this n it wouldnt work for me
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:byob916
