When the robot is going to fall the motor starts and moves the robot to the direction it is going to fall, so the motor torque about the center of gravity that is higher than the motor makes the robot balanced.
Remove these ads by
Signing UpStep 1Things you need
small electric motor
some gears
(or a motor with gearbox)
a shaft
two wheels
some sheets of plastic to make bearings and the robot neck
two battery holders
4 AA batteries
one button cell
one SPDT (single pole double throw) switch with a metal lever
one toggle switch for the on/off switchs
one nail
some wire
soldering iron
some glue
Aso it is a good idea to have the hight of switch adjustable. As I spent 2 hours adjusting the hight.
Could you upload a video of your robot, it would be very helpful for ones who want to make one.
ive also pulled one out of a computer, and several other interesting looking switches. mostly out of the optical drives, front panels and a somewhat of floppy drives, but if you keep your eyes open...
I have two Segways (a blast, by the way) and they stand up on their own. It's fun to watch them "dance"..
I literally had to go to the factory in NH to take a class on how to ride these models. Yes, long time ago.
What they suggested this: to stabilize my units when first riding it, add some weights to the saddle bags on either side. It not only helped me when learning, it helped the Segway stay upright without excess movement
So what I'll seggest (lol) to you is this: get the center of gravity lower by moving the batteries down or adding weight to the bottom of the plastic. That should allow the bot to stay upright without falling over.
LET ME KNOW HOW THAT WORKS.
Robb
Grand Rapids, MI
but why do u have 2 segways, its pretty cool, i just dont understand y u have them.
My intention was to hire good looking college gals to ride them around with our company logo on the side of the saddle bags, answering questions about our business and handing out literature.
Great marketing idea, but have not had enough time to devote to the project.
It would be interesting to try it with tilt switchs (**MERCURY is BAD kids**) and perhaps make two stages of power, voltage divider between cells for those times when it tilts beyond a certain range the additional voltage is switched on.
Also would be neat to try a magnetic pendulem with reed switchs.
Good Job.
excellent instructable.
i think its because i only used two gears one on the motor and another one on the driver shaft so there's no mechanical income but im not sure if its that or it is just that the batterries are not fresh enought :O
thanks for the instructable and i apologize for my bad english
For more info search "balancing robot" on internet.
High CG object has high moment of inertia, so it needs more moment to move and has more stabillity. Because of these you must choose the longest robot and consider your motor power.
The more complex controlling system, the more stabillity. but the most important feature of this robot is that it is simple (according to the the others comments)
