Balisong/butterfly Knife
6,443
29
8
Published
Introduction: Balisong/butterfly Knife
My balisong knife
I'm thiking about making a Instructable some time
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    8 Comments
    Sorry for replying so late i havent gone on the site for all most a year...
    I just took a peace of plywood and the i used an table saw to make i the correct sice then i cut the line in the midle (not sure what it's called) with a hand saw (It could be made beater with an table saw but it is much harder to get it the correct depth) after that i just driled two holes (one for each) in the middle/top of the two ply woods (I recomend using a table drill) then i just Googled: "butterfly knife sketch" and used the blade from one of the pictures. Then i cut out the blade thingy (with sicors...) then i drew the out lines of it on an aluminum plate and just cut it out with some garden sicors (to trim bushes or something (not sure what they are caled)) it will come out a wierd shape so i just hammered it down.
    Then i drilled two holes in to the aluminum plate so it would fit in the plywood.
    then i just screw it on with some bolts (remember not to tighten it to much or the ply wood could brake) then i just taped the safe side of the blade with clear tape and that should be it...
    ps. DON'T CUT YOUR SELF OR ANY ONE ELSE!!!
    hey just a tip instead of using bolts use rivets
    please dont tell me that the blade is made of aluminum foil?
    I think im going to attempt to make one of these! :) I love your design
    correct me if I'm wrong, but it looks like you've cut across the grain of the wood on the bite handle. Other than that nice job :D
    if you look at the last pic where its disassembled, you can see its made out of plywood, so cutting across the grain doesnt really matter except for looks
