3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
batch file animations
im going to show you how to make an animation
in batch.
what you need:
1.a computer
2.know how to save batch files
3.time lots of time
4.(optional) half-a-brain
DISCLAIMER:
i am not responsible for any damage that happens to your
computer because you pissed around with batch files
and had no idea what you were doing!
Wooh
now thats out of the way lets start.....>>> (this way)
Step 1THE CODE
THE CODE
the attached file is a simple
animation i made show WTF is all
this maddness
ECHO
a command used to echo the
input
@ECHO OFF
sets it so the command is
not shown
SLEEP xxx
pauses the script for
a set amount of seconds (xxx)
echo 1. start
echo 2. exit
SET /P M=Type 1 or 2 then press ENTER:
IF %M%==1 GOTO start
IF %M%==2 GOTO exit
simple menu
GOTO xxx
goes to the specified label (xxx)
:xxx
sets a label (xxx)
cls
clears the screen
ok this is probably hurting your bran so i will move on....
7 comments
May 4, 2011. 7:42 AMblakexz13 says:
ur program took a little to long. (also sleep isnt on some computers)
HERE IS AUGMENTED CODE:
@echo off
title the life of stick man bob
color 0F
cls
echo THE LIFE OF STICK MAN BOB
echo.
echo IN SLOW MOTION
echo.
echo OOOOOO
echo O O
echo O # # O
echo O ---- O
echo OOOOOO
echo ][
echo _[]_
echo //][\\
echo // [] \\
echo // ][ \\
echo // [] \\
echo //\\
echo // \\
echo // \\
echo // \\
echo.
echo 1. start
echo 2. exit
IF %M%==2 GOTO exit
:start
cls
echo ----------------
echo . 0 .
echo . /l\ .
echo . l .
echo . - .
echo . / \ .
ping locahost -n 1 >nul
cls
echo . 0 .
echo .@ /l\ .
echo . l .
echo . - .
echo . / \ .
cls
echo . 0 .
echo . /l\ .
echo . @ l .
echo . - .
echo . / \ .
cls
echo . 0 .
echo . /l\ .
echo . l .
echo . @ - .
echo . / \ .
cls
echo . 0 .
echo . /l\ .
echo . l .
echo . - .
echo . @ / \ .
cls
echo . 0 .
echo . /l\ .
echo . l .
echo . - .
echo . @ / \ .
cls
echo . 0 .
echo . /l\ .
echo . l .
echo . #*# - .
echo . *@*/ \ .
cls
echo . 0 .
echo . /l\ .
echo . !!!!!l .
echo . !!!!!- .
echo . !!@!! \ .
cls
echo . 0 .
echo . / \ .
echo . l .
echo . .
echo . \ .
cls
echo . .
echo . 0 .
echo . / \ .
echo . l .
echo . \ .
cls
echo . .
echo . .
echo . .
echo . 0 .
echo . / l\\ .
cls
echo THE END OF BOB!
echo or is it?
echo.
echo 1. restart
echo 2. exit
IF %M%==2 GOTO exit
:exit
echo exiting......
sleep 2
echo 1
sleep 1
echo 2
sleep 2
echo 3
sleep 1
exit
Oct 2, 2010. 8:04 AMitanium says:
well... i don't have the program "sleep" on my computer. it doesn't work as the anims play real quick.
Oct 6, 2010. 4:42 AMitanium says:
nice solution! im on vista. its kinda using a bazooka to kill a mosquito approach but very good!
Oct 6, 2010. 11:43 AMitanium says:
I think I did this some time ago. I used to make the animation play by pressing space (I used the program pause piped with null on DOS command line... never thought of using a timer [back then I couldnt, didn't even have internet]). So when I pressed space, the anim batch file would play another frame.
It was pretty fun the time I made it but no one around cared bout that. Computers were merely tools.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:eoscondor
i hide, i find, i jump, i cupple to your head and use my beak to crack your skull and eat you brains!
