3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
battery adaptor for cordless tool
I had a whole set of 14.4 Volt cordless tools including flashlight, small circular saw and a drill.
First the charger went, then the batteries died, and then before I could buy replacements the company then switched to the 18V format and dropped all product support for the 14.4V line.
I purchased a new 18 Volt drill from another manufacturer in protest but it really wasn’t as good as my old one, the chuck slips when drilling and the drill clutch doesn’t seem to handle torque well.
So how to resuscitate my old tools cheaply?
I had two 18V batteries and chargers from other tools and when I jumped them to the 14.4V tools they seemed to run okay. The challenge then was to convert a 14.4V battery into an adaptor.
Step 1Step 1 Salvage
Step 1 Salvage
Gut the battery, removing the NiCD batteries inside and safely recycle them. Salvage the clips off the battery that serve as the connectors to the Tool.
47 comments
1-40 of 47next »
Dec 23, 2011. 12:24 PMcj8675 says:
you have a kinda junky drill. you should spend the money on a dewalt because ive had mine 6 years and also dont change the battery design. i drop mine off 24 foot ladders, into water on side walks and etc. buy better tools
i had a ryobi and i dropped it off a 6 foot ladder onto the sidewalk and it smashed into a billion peices. now i only buy high quality tools.
Dec 24, 2011. 12:38 PMcj8675 says:
ok sorry
Oct 23, 2008. 7:05 PMhandydave937 says:
I agree with dendave.joe, I have dropped my Milwaukee drill off the roof, off of ladders and abuse it on a daily basis. I also know for a fact that I can get any part for any of my Milwaukee power tools including batteries. It always pays to buy high quality tools
Oct 6, 2011. 9:41 PMzappenfusen says:
I've been using my Hilti hammer drill, Makita drills and impacts & Milwaukee sawzall for 15 years with a few battery pack cell replacements since I purchased them. Hilti, 20 years (corded) Sawzall also corded, 15 years, & Makita Li-on since I replaced my Dewalt Nicd 6 yrs. ago. I've got a Milwaukee 3.6 volt screwdriver which will do darn near everything the Makita will do and is my most used tool. I'm an Electrician destructing, drilling, and screwing for a living. Handy Dave's philosophy is undeniable. You truly get what you pay for and if & when they go down they'll survive homemade batterie's, alternate power sources and an infinite variety of DIY repairs. The additional cost is more than negated when you have no complete tool systems being tossed in the dustbin. My wife doesn't get it or approve but if I allowed her to purchase I'd be pitching Ryobi's once a month.
Oct 3, 2008. 10:26 AMCeltic Davey says:
not a bad way to make use of an old tool but does the balance not feel a bit off with a heaver battery lower down on your drill/jig saw/circular saw?
Sep 16, 2008. 3:36 AMfinton says:
Wyle_E suggested (Jun 19)that "You could make a similar adapter ... to run portable tools from a car battery." I tried that with my 12v Black&Decker, but disconnected it REALLY quickly when smoke came out of the drill's vents! Why would that happen? 12v car battery, 12v drill... Has anyone successfully done this?
Sep 16, 2010. 7:54 AMchrwei says:
this was at idle or under a load? it could be that the motor itself also had a problem and was trying to pull more amps than it should have. Black&Decker's tend to have "lowest bidder" parts in them, which is why your chargers keep failing.
Feb 26, 2009. 4:46 PMsyfire says:
hmmm. well the car battery has 12 volts sure, but it can deliver 80 ampere so its about 200W of power. Sure, that enough juice to burn any electronic component.
Sep 16, 2010. 7:50 AMchrwei says:
that's not how amps works. amps are simply available, it's up to the load to pull them. Your typical home outlet provides 15 amps, but plugging in a .5amp cell phone charger doens't explode anything.
Oct 30, 2010. 12:59 PMDallasDeckard says:
This is true, but your example isn't really correct. A .5 amp phone charger outputs .5 amps, that doesn't mean the charger *requires* .5 amps from it's source or that it passes on a higher amperage to the phone. The amperage from the socket doesn't pass directly through the phone charger (or shouldn't). If it's stated amperage is .5 amps, it outputs .5 amps (or should) and no more.
You are right though, amp rating is simply what is available, it's up to the load to pull what it requires. Too many amps won't damage anything unless the voltage isn't fixed. Some (cheap) stuff can increase voltage when the current requirement exceeds it's amp rating, which could damage a device, but it's unlikely.
The voltage output of a car battery can vary slightly, up to 14 or 15 volts. It would only be this extra voltage that may damage the drill.
The problem you had could be the wiring. The motor may have drawn more current than it's wiring could handle.
Jan 29, 2009. 7:33 PMcoolguy says:
Cars don't put out a consistent 12v. They can jump up or down depending on how fast the alternator is turning. You if you try to use auto power, measure the voltage first (using a multimeter), build a voltage divider circuit, and filter the input power to protect from irregular voltage spikes.
Mar 16, 2012. 9:31 AMamclaussen says:
FOR THE BENEFIT OF QUITE A FEW... Lets put it clear and more or less complete.- Understanding the most basic law of electricity and electronics can help a lot when you want to use electric motors and almost any kind of stuff. The OHM law is not difficult to understand. Imagine a piping circuit instead of an electrical one, that will help a lot. The amount of water that can flow thru a partially open valve will depend on how high the water tank is above the valve, but also on how big the diameter of the pipe is, and how open the fawcett valve is. The VOLTAGE of the circuit source or supply is akin to the PRESSURE of the water inside the piping (think PSI), the CURRENT is akin to the FLOW or quantity of water that flows in a given time (think GPM), and the RESISTANCE is akin to the friction loss or PRESSURE DROP of the piping circuit, either with a pipe that is too small or a valve that is almost closed. Now, using the unit system, the voltage is measured in VOLTS, the current in AMPERES, and the resistance in OHMS. This way is all too easy to fully understand and even predict how the devices will work when the power is applied to the circuit: Let's say we have a car battery with a nominal 12 volts (in reality it could have as few as 11 volts when almost discharged, to a little above 14 volts, when fully charged ans just recently disconnected from the charger!).
If we connect an electric motor, a small one, it will allow  just a fraction of an Ampere to flow through it, say 250 milliamps or so; because the small wire that is used in the windings will present a comparatively large RESISTANCE of about 48 Ohms.  BUT if we connect a much larger motor, like the Starter Motor of a car, the same 12 V battery will flow a large current, maybe 150 Amperes! because this motor presents a much lower resistance, of around 0.08 Ohms... (its windings are made with a much larger wire gage, just look at the diameter of the car battery cables!).
POWER is the result of multiplying applied voltage times current, so that a WATT is produced or dissipated when a current  of one Ampere flows pushed by one Volt.  Therefore, power can be calculated from the following simple relations:
I = V / R, V = I x R,  R = V / I...    P = V x I  or  P = (V) squared / R
In the case of our friend FINTON above, the small motor must have been defective, most probably having some shorted windings.  This resulted in a too small resistance that caused that the large capacity 12 V car battery  able to deliver several amperes and quickly burned the poor small motor.  If the motor would have been in good condition, it would run perfectly under the light load meant for it.  At the same time, that small defective motor would turn at partial speed when connected to an smaller voltage battery (say, a common 9V alcaline cell), but that small battery would be incapable of sustaining its output voltage when connected to the partially shorted motor, thus not being cappable of burning it!
Now, most DC (direct current) electric motors can be fed with a higher voltage, above the nominal one it was designed to handle, but  it is a matter of how heavy will it be loaded when operated.  See, the motor presents an electrical load that DEPENDS on the MECHANICAL load it has to move, so that if lightly loaded, common electrical motors certainly can handle say 1.5 times the nominal voltage, if the mechanical load is not far above the design one.  Present day Model Airplane hobbyists use motors designed for say, 12 Volts, with battery packs that can sustain almost double that voltage, but they use it wisely, using the maximum power for brief periods of seconds, like for Take-Off or maneuvers, backing off the electronic throttle to avoid burning the motor.  As this INSTRUCTABLE says, it is "safe" to assume that a Cordless Hand Drill meant for "12 V" nominal, can be perfectly run with a 14.4 V pack.  It will turn faster and will be capable of more power output, BUT WILL ALSO OVERHEAT more quickly if the same Load is applied, so keep this in mind and avoid loading it too much.  BTW, rechargeable cells have an actual voltage that is NOT the nominal one under load, so that the 12V pack is assembled from 10 1.2 V nominal cells, that maintain close to 1.0 volt under load each wired in series, and the 14.4 V pack has 12 such cells, thus achieving only 12V under load.  This applies to Nickel based cells. Lithium cells have 3.7 to 3.8 nominal Volts, so that one can perfecly use a pack of three to four Lithium-Ion or Lithium Polymer cells for that drill, saving a lot of weight and bulk, but then would need a special charger designed for Lithium cells, and also apply ALL the cautions of using Lithium cells!  Good Luck. amclaussen.-
Feb 2, 2009. 1:05 AMfinton says:
Oh, OK. In my particular case the car wasn't running, but your point is good to know for when the situation arises. Thanks. Oh, and Criggie: I didn't have the battery in the drill when I tried running it off the car battery. As it turns out, the charger was defunct: the replacement I bought also didn't work! I gave the hardware guy my drill, battery, and the new charger - I just got them all back today with a charged battery, so I guess we'll see if the chargers are at fault or I have a problem in my workshop wiring...
Dec 24, 2008. 6:34 PMcriggie says:
Yes - I used a 14.4 V drill and connected 15 metres of cable to a pair of clamps. Great for using out in the land rover, and a lot more efficient than an inverter+mains drill. The long run of cable induces quite a voltage drop too - the drill only gets around 11.5V Also remember the charging voltage of a car battery is around 14 V, so running the drill with the car motor going is likely to provide a slightly higher voltage than when the motor is stopped.
Dec 25, 2008. 12:55 AMfinton says:
Thanks for the reply criggle. Good to know it is already being done. Hmmm... I could make an adaptor for the drill, and one for the car battery, such that they could be connected by various length standard extension cords. Oooh! The extra resistance suggested by 11010010110 could be variable at the drill adaptor(a potentiometer?)to accommodate various lengths of extension cord!
Dec 26, 2008. 12:45 PMcriggie says:
My drill was heading for the recyclers anyway.... Make like a plumber - "Suck it and see" how it goes. You won't damage the battery unless you short it or flatten it. Was the drill working before the battery died? Could it have been some old grease or lithium lube across some contacts? Or maybe its a cheaper build and the components couldn't cope with the current.... Mine was a fairly expensive bosch (thanks dad)
Dec 27, 2008. 9:02 PMfinton says:
The drill and battery both work, it's the charger that doesn't. No grease, but I did squirt a bit of CRC (non-conductive thin lubricant, used to remove moisture from electrical components, among other purposes) down the charger as the battery was very hard to get out. As the charger worked for a long time after this, I would be surprised if that was the problem, but I'm not pontificating. I went to Dick Smith's (Australasian electronics supplier) for that "pot" today: the bloke was of the opinion that even a short length of wire should create enough resistance, but explained that some drills have a four terminal arrangement where the first two are part of the switch arrangement for the main battery capacity - in other words I had bypassed this and was feeding the car battery straight into the drill. Haven't checked the drill for this yet...
Oct 3, 2008. 7:09 AM11010010110 says:
The NiCD batteries of the drill have more resistance than the car battery. When you run your tool off NiCD it actually gets less than 12 V (the rest is lost in heating up the battery) The car battery has low resistance so the tool gets really allmost all the 12 V You can add something with few ohm resistance in series to the car battery to simulate the resistance of NiCD's. Heat wire from electrical heaters is good for this. Expect it to heat quite much
Jun 6, 2011. 3:06 PMfinton says:
Hey 11010010110, I know it's over two years later, but what significance is the number 3372 to you? (your binary username in base 10).
Still haven't got around to trying your idea with resistance... :[
Oct 3, 2009. 10:33 PMsmessud says:
Just to ramble. "one order of magnitude up or down i.e.a 12v on a 9.6 motor" This is not one order, one order (10x) would be 96V. You are roughly 30% above rated voltage. That is you are dividing its lifetime by around 4 to 10. You should be more careful (may be I am dramatizing) with the blade that has a limited centrifugal resistance and could break under stress, especially low quality blades.
Sep 16, 2010. 7:46 AMchrwei says:
a good drill will have its motor slightly oversized and so the motor itself would handle it. A cheap drill might actually have the motor undersized already, and certainly will have the cheapest gears to get to past the warranty. If your drill has lasted several years past its warranty already and isn't sloppy or making funny noises then it'll probably do just fine at some higher voltage. Do this to a cheap drill and you'll probably flatten the gears first.
The ozone smell is most likely due to overheating the motor brushes. Do it too much and you'll burn out the commutator, ruining the motor. Depending on how nice a motor it has, you may be able to replace the brushes with higher quality ones that won't overheat so easy.
As for drills and blades, using ones made for AC powered drills will always be fine for battery powered ones. AC drills pretty much always run at higher RPM's than battery.
As for "order of magnitude", this phrase has a specific mathematical meaning of "ten times". Using it to mean anything else will mean that people misunderstand you. Using it mean "one step up" is like saying run when you mean crawl.
Sep 16, 2010. 6:36 AMUnclegene says:
I had a charger go bad - went through my left over computer equipment power supplies and found one with a 24 volt AC output, got a bridge rectifier from Frys for 5 bucks and back in business. On this lash up, don't leave it unattended connected and monitor temperature.
On over voltage operation, I am running an 18 V drill on 24 volts and it is spry, but I watch for overheating and understand the commutator might go out quicker.
Mar 10, 2009. 1:08 AMsukhbinder says:
One should avoid increasing the battery voltage of a power tool as the motors are specified to work at the particular voltage. If you have a look at the motor used i cordless power tools you'll find that they donot have much coil windings but the coil wire is quite thick. so the motor generates the power by using high current and not voltage (which is the case for motors which have a large coil windings but with fine coil wire). if you increase the voltage the motor cannot extract as much current and will not perform to its capacity and the battery discharge will me more. Never change a NiMH or NiCd battery with a lead acid battery, the internal resistance of the lead acid battery is very low and the excessive current will damage the motors commutator and brush system. You can use a NiCd or NiMH with higher current rating (AH) but the same voltage as earlier so you'll have more back up or operation time available
Aug 28, 2009. 7:29 AMProfessorJWN says:
Well, sometimes. Power wheels kids cars for example. These run at 12v, but the motors are 18v and will runat 24v with an electronic controller. In fact if the motors use and electronic speed controller, that likely would be the "limiting factor" and the source of smoke. I believe these are an H-Bridge and more than likely are made for the particular voltage of hte batteries.
Mar 11, 2009. 1:04 AMsukhbinder says:
The smoke coming out from the drill vents as mentioned in fintons post is most probably generated by the drills commutator and brush assembly. due to the very low internal resistance of the car battery it can source a very high current for an instance which is enough to fry the drill motor windings and the commutator brush assembly. Usually car battery have ratings of about 12V@35-40AH (current rating can be more depending on the vehicle). The AH rating means it can put out a current of 40A for an hour at 12V, so just think of the peak current it can put out in 1 sec (40x3600=144000A).
in a vehicle the part that uses the most current is the starter which is a high power dc motor, vehicle batteries have a spec called the CCA or cold cranking amps thats the current it can put out when starting the car. usually car batteries have a CCA rating of 300-400A. thats why the mechanics use such a heavy cable for jump starting your vehicle from another battery (the thick cables have very low resistance to allow for the large current to flow, else instead of starting your vehicle the cables would be burning)
Jan 27, 2009. 4:30 PMalanis91 says:
any ideas for an adapter to run 18 v tools with the house current outlet 110 AC
Jun 24, 2008. 2:14 PMdendav.joe says:
Ive had my Hilti drill 8 years. Its been in swimming pools, dropped off roofs and abused endlessly. Its as good as new. Pay a bit extra for a good quality drill, but the big money goes on the battries. Dont be seduced by voltage, its the a/hrs that count.
Oct 3, 2008. 7:13 AM11010010110 says:
Its W/hrs that count
1 W/hr = 1 V * 1 A/hr
Sep 10, 2008. 3:53 AMpanstar1 says:
This might be a little off topic ,but the person who said ni-cad's are good for power tools because of there ability to put out large spurts of current. As a matter of fact ni-cad's were used to start aircraft engines I think they used them to replace the older lead acid battery's in radial engines (after a good cleaning repainting and complete removal of all acid from the lead acid battery the acid some how screws up the ni-cad. There best use is with small gas turbine engines like helecopters have. The engines have to spool up to about 50% before and fuel is injected & these starter's draw something like 1,200 amps ! I would like to see a li-ion pack do that !
Sep 5, 2008. 2:54 PMselvol says:
Good idea. I thought of the same thing a few years ago. My problem was I had around 10 different brand drill. Some Slid on and some had the pole in the middle. Glad to see someone made the idea. Regards
Aug 25, 2008. 4:15 AMDerin says:
whoa,i see an aerosol can of propane in the background
Jul 9, 2008. 4:47 AMDerin says:
I hate wire nuts!Use butt splices its a lot easier
Aug 25, 2008. 4:14 AMDerin says:
rant not directed at u,just ranting the *cough* wire nuts *cough*
Jun 26, 2008. 10:01 AMdsandds2003 says:
I usually watch the rummage sales for them unwanted tools. I get them for next to nothing. I have used the DC motors for a couple wind experiments and the batteries are used to repair battery packs or charge them up with wind/solar to use on other projects. It is cool idea to reuse these packs for repowering.
Jun 20, 2008. 2:02 PMFireBAT says:
Very nice work! I have a Craftsman 18V drill that has good batteries, but the charger died. Since Sears changes the design of their battery connectors apparently every 6 months, the "UNIVERSAL" charger I bought won't work, even though the plugs are the same shape. I'll have to try this with my other broken drill.
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:burntbob
