Introduction: Beaded Heart Shaped Pendant
after making bracelets, i was having some beads left.. and some leftover wire..
so from all these leftover materials i made a heart shaped pendant.
for making it we need
-crystal beads (preferably red/reddish)
-seed beads (i was having greenish beads left, so used them)
-wire (approx. 2 feet)
Step 1:
for getting started, we need 5 crystal beads and 16 seed beads.
i have arranged then in a particular manner (please refer picture)
take one crystal bead and pass it through a wire and keep it at center
now pass 2 seed beads from each end of wire
now take one crystal bead and pass it from one side of wire and then pass other end of wire through the same bead as shown
now pull both ends of wire tightly to make a loop as shown
again put 2 seed beads from both ends of wire then crystal bead and then make loop in the same way
make such 4 loops
Step 2:
to give the curved shape, i have arranged beads in a particular pattern (refer image)
in this pattern we are taking 2 seed beads on outer side and i seed bead on inner side
now follow the same procedure and make loops
we will be making 3 such loops
Step 3:
for giving extra curve now we are taking 3 seed beads on outer side and 1 seed bead on inner side
follow same procedure and make loops
we will need 2 such loops
Step 4:
again we are going to make 2 loops with 2 seed beads on outer side and 1 on inner side
Step 5:
this one is little tricky part
pass 2 seed beads on outer side wire
pass one crystal bead on inner side wire
now take 1 crystal bead and pass it through one side of wire and pass another side of wire through same bead and make loop
Step 6:
for making other side of heart we need to follow same procedure
firsts 2 loops (2 seed beads on outer side and 1 on inner side)
next 2 loops (3 seed beads on outer side and 1 on inner)
next 3 loops (2 seed beads on outer side and 1 on inner side)
and finally 4 loops ( 2 seed beads on each side of wire)
