Step 2Choose your sofa size
sofa model diameter length --------------------------------------------- pea 3 feet 3 feet (standard beanbag chair) garden slug 3 feet 8 feet (recommended) banana slug 4 feet 10 feet (bad! diameter is too big!) centipede 3 feet 30 feet (around-the-room sofa) earthworm 1.5 feet 8 feet (back rest only) millipede 3 feet 1000 feet (block party sofa)
it turns out there is also a jellyfish sofa, the jellyfish is what you get when you don't have enough beans in the bag to keep its shape and it just squooshes out all over the floor. the problem with the banana slug that i built - and the reason i don't recommend it - is that when it is filled enough to not be a jellyfish, it no longer will fit through a doorway. and it is just way too huge for a normal room, it tends to envelop everything else in the room. months later you'll discover your little dog toto buried in the folds of the jellyfish.
oh yes, so your spool of cloth must be as wide as the diameter of the sofa. for the recommended "garden slug" sofa you'll need a spool 3 feet wide and 32 feet long. use something sturdy! i made mine out of corduroy. there's a good selection of fabrics for $4-8 per yard at my local fabric store.
Pretty neat instructable :3
they do make a bit more noise, and don't shift around quite as easily, though.
A smaller version may be doable though.
