Bedroom Automation
Introduction: Bedroom Automation
In this Instructable I am going to show you how I constructed a system to let me run my bedroom using my computer.
Step 1: Parts of the Beast
here are the parts I used to build the system:
USB interface board (I used a K8055 experiment interface board)
4 channel remote socket set
box to put it in
single core wire
USB cable
Step 2: I Am Now Making My Primary Insision Into the Circuit Cavity
the first thing to do is open up the remote control that came with the socket. to my surprise I found it contained 8 push switches, 2 for each button on the remote
Step 3: Soldering Time
you will want to check what configuration works with your remote and USB board, I soldered in the leads so that the output of the board and the ground for the board are either side of the switch (the grounds are linked together to neaten it all up).
Step 4: Computer Meet Sockets, Sockets Meet Computer
you will now want to connect the wires from the remote to the USB board and then connect the USB board to the computer. my board came with some demo software that gives me tick boxes for the digital outputs.
Step 5: Testing, Testing
I plugged the board into my computer and one of the sockets into a small lamp. when I sent a command from the computer, the lamp lit up. IT'S ALIVE.
Step 6: To Be Coninued....
for my first major project this was a good start. I am now going to look at automating my bedrooms lights, and that will be the topic of a future Instructable.
well let me know what you think, helpful suggestions welcome
    • Epilog Challenge 9
      Epilog Challenge 9
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    one head-sup dude that board is capable of so much more if you seriously learn to program since that board supports Delphi, Visual Basic and C++
    and with some modifications you can even use it as a programmer for simple pics
    One recommendation.
    Have a look at VB programming, I used this to make an automated pyrotechnics controller, but it could be modified for this purpose and gives a lot of customization as far as functionality goes.
    Yeah, I do a LOT of VB programming for arduino projects and the like. If you want to use the velleman kit with VB, you have to download a seperate .DLL file to control the board, then you can make your own interface for your system. :)
    The DLL comes with the board on a small CD, as well as the demo program he used in this ible... but if you're running windows vista/7 you need to go to the velleman website and get the version 4 DLL.
    I'm attempting something like this but instead of household automation, I'm attempting to build some kind of robot toy for my friend.
    I've got the K8055 board hooked up to my computer and I've attempted to wire in the controller of a robotic arm that I have laying around.
    I've got the GND wire hooked up to one end of the switch and the DI1 wire going to the other side of the switch. But when I run the demo program and turn DI1 on... nothing happens, how did you wire up the remote to your experiment board?
    So what exactly do you "run" in your bedroom that requires an automated system?
    you can plug in anything that normaly conects to the mains supply. when I tested it i was using it to control some of my rooms lamps.
    Why were you surprised that there were 8 switches? Weren't there 8 buttons on the font of the remote transmitter? 2 on and 2 off for each of the 4 channels.
    sorry for the late reply.
    there were only 4 switches on the front of the remote, one doing off and on for each channel. thats why I was surprised to find 8. I suppose there were two switches so that, no mater where you pressed on the switch, it triggered the channel.
    So you set up the software to mimic momentary to trigger the relays? Can you tell me how you did it ?
