3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
bellows for large format camera
heres how you can make a bellows for a large format camera .
while i realize that film cameras are the old way this can be used if you want to make a scanner camera a pinhole camera or even a bellows to pump air.
Step 1Material list
to make this you will need :
1 sheet of black bristol board(sometimes called bristle board)
1 roll of black cloth hockey stick tape 1inch wide
1 ballpoint pen{if its dried up its ok so long as its stromgly made}
1 straight edge (longer than the sheet)
27 comments
Jul 16, 2011. 9:31 PMdwerg85 says:
Thanks for this. I've seen everywhere that making the bellows is a long and arduous process. With this how to, cutting the carton was the most time consuming bit.
Jan 11, 2010. 12:37 AMquepez says:
vientos carnal esta muy interesante
Apr 14, 2011. 2:37 PMnef says:
jajaj awebo barrio!
Nov 16, 2009. 10:01 PMTbonestone says:
 Is there an instructable on building the camera framework? I would like to build the bellows, but need a reason to... :-)
Thank you,
Tbonestone
Nov 5, 2009. 2:31 PMpolerix says:
went a step beyond, added a usb flatbed scanner to the back, and one of those black cloth covers.
Aug 28, 2009. 10:23 PMpolerix says:
great instructable. works as displayed.
Jun 25, 2006. 9:05 AMbigbadd says:
Lennyb, how water resistant is this material? I am interested in building a field camera and the one you have pictured looks like a jewel but I would like whatever I build to stand the weather. thank's bb
Jun 3, 2008. 3:42 AMLach says:
Gold! My next project is going to be a concertina, so this will be very handy.
May 25, 2008. 11:51 AMmjbphoto says:
I might of missed it but did anyone specify what material should be used for a traditional bellows on my 8x10. What was used by the original maker, Agfa in the early 1900's mjb
Mar 18, 2007. 8:46 AMgmoon says:
Great stuff! I've got an ancient 'Ansco' 8x10 view camera, but the bellows are really leaky. Had thought about using a neoprene compound to seal the worn areas--but now might try replacing 'em...
Oct 27, 2007. 6:56 PMsmieglitz says:
Did you ever construct replacement bellows for the Ansco? I have 2 Agfa Commercial View Cameras that need bellows replaced so I will be starting that project soon. Your camera may be a newer version of the two I have. I have an old bellows to use as a pattern. I'll append my bellows construction webpage once I have it figured out.
Oct 28, 2007. 6:02 AMgmoon says:
No, I haven't. I'll check out your page, it might be just what I need. If you PM me your email, I'll send you a photo of the camera....to compare with yours.
Mar 30, 2007. 6:21 AMgmoon says:
That's a good point, although I generally don't collect photo stuff that I can't use...
May 7, 2007. 5:22 AMfreewheeler says:
it would be cool if someone posted an instructable of a negative pinhole camera. i made one at skool using a pinhole camera without a viewing screen,and photographic paper stuck on the back.
May 4, 2007. 2:13 AMfreewheeler says:
hey do you know where it is possible to get one of those modern plate cameras?i want something with HUGE format and serious depth of field.
Jan 6, 2007. 11:20 PMtrjames says:
Come on, we're looking for those camera plans!
Apr 2, 2007. 9:59 PMtrjames says:
Thanks for the reply. I understand the combo all too well believe me. Don't you love those projects that don't get worked on for years at a time? I got six I can think of off the top of my head.
May 23, 2006. 2:07 PMhomebrew106 says:
thats the best idea for making bellows i've seen the camera looks good too any chance of listing plans for that ?? cheers Homebrew
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
42
Author:lennyb
i am a photolab technician and an incurable packrat. i have made swords ,chainmail, crossbows.cameras,bike trailers,kayaks,guitars{slide and electric},knives,various film winders and vacum easels for...
more »
