3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
bfo metal detector
bfo metal detector
Simple BFO metal detector
BFO ( beat frequency oscillator ) metal detectors use two oscillators, each of which produces a radio frequency. One of these oscillators uses a coil of wire that we call the search loop. The second oscillator uses a much smaller coil of wire, and is usually inside the control box and is called the reference oscillator. By adjusting the oscillators so their frequencies are very nearly the same, the difference between them is made audible as a beat note, this beat note changes slightly when the search loop is moved over or near to a piece of metal. It has been found in practice best to make the search oscillator fixed say at 100khz and to arrange for the reference oscillator to be adjustable 100khz plus or minus 250hz. This gives a beat note of 250hz to 0 to 250hz. The beat note disappears or nulls when the two oscillators are about equal. This type of detector is most sensitive when the beat note is close to zero, about 5hz ( motor boating ) any slight change being noticeable.
Step 1Parts
Parts list
Power source:
Any 9v battery PP3 is ideal.
Capacitors:
2 off 220uF 16v electrolytic.
5 off .01uF polyester.
5 off .1uF polyester.
Resistors:
All resistors 1/4 watt 5%
6 off 10k
1 off 1K
1 off 2.2m
2 off 39k
Transistors:
All BC 183B. Just about any small signal npn with a gain of 250+ will do. There are hundreds to choose from.
Audio output:
A 2.5 inch 8 ohm speaker will work but headphones or earpiece are preferable the higher the impedance the better.
Many of the above parts could be salvaged from a broken transistor radio.
Once the components have been obtained the circuit can be built in a few hours using copper clad stripboard, or if you the facilities make a printed circuit board using the layout below. The original layout as below should print out at about 50mm x 100mm.
42 comments
1-40 of 42next »
Nov 26, 2011. 5:50 AMpaulinex127 says:
hi! i would like to know where the 220 uf electrolictics connect, because the two
have the B-, and if possible where the two electrolictics are going to connect.
Best regards,
Paulino Alves paulino_al@iol.pt
p.s. i´m trying to build your project, but i don´t understand what i mencioned!
Jun 29, 2011. 2:42 AMRyan McDougall says:
I have just bought a GC-1005 metal detector from ebay,
is this good to get started with?
please replie
Jun 16, 2011. 8:40 AMbaker amin says:
Hi,
thanks for this instructable. Can I use this method to make a security system like those we see in airports, those which look like doors that passengers pass to check them.
Mar 28, 2011. 1:52 PMjack002 says:
No connection means the wires at the junction there at the bottom where the one goes up and down and the other goes left and right do not connect. The one passes over the other. The bottom of the 10K resistor will go to the base of Q3 and will NOT connect to B- but pass over it.
Jun 13, 2010. 10:51 AMtoben222 says:
hey, sorry, but really: what does NO CONNECTION mean...? where should i connect the 10K ???
Sep 28, 2010. 11:34 AMAzayles says:
It means the two wires crossing over each other are two separate wires, and not connected at the node.
Mar 16, 2011. 12:26 PMyahklfe says:
xwtdqdsrhj
Dec 9, 2010. 3:52 PMbobberts says:
can anyone tell me how to figure s voltage drop across any of the resistors??? cause there's no ground in this circuit :s
Oct 7, 2010. 7:13 AMjaschhina says:
Hi ,
I am working on project of metal detector .
Could we find out that how far it can detect.
if we want more distance metal to detect what I have to do for it.
Thanks
Jan 21, 2010. 6:34 PManasko says:
vere gooooooooooooooood
Mar 21, 2010. 3:43 PMeasytreasure says:
You can find the original of this project on my site http://www.easytreasure.co.uk
this is where it was stolen from. There is also a video of it working here
http://www.youtube.com/watch?v=aSqmFWtoXYw
If you check it out on my site there is nothing to pay its free.
Jan 21, 2010. 6:27 PManasko says:
yese vere good
May 28, 2009. 6:55 AMrickove says:
In search coil build as photo,use nylon bolt an nut an plastic ,polycarb L shape for brackets,to reduce Metals in search head an connector cable from search head short as possible an screen cable to control unit.for best signal to noise performance for this basic unit. metals in centre of search head make balancing the coil for this simple circuit harder to achieve an less sensitive overall once built.
May 28, 2009. 6:40 AMrickove says:
Pinout for common BC548 NPN appear same as BC184 NPN transistors.all OK.
Mar 24, 2009. 11:54 PM4star says:
can any one explain this circuit for me.....and is that no connection..does that mean we dont have to connet the 10k resistors there.then where do we connect it..i've tried to make this project but..can we use bc548 instead of bc183
May 28, 2009. 6:29 AMrickove says:
a very simplistic schematic,as the transistors all appear to be NPN types from Q1 thru to Q6, BC548 transistors should suit.just remember correct pinout for this transistor for collector,base, emitter pins. most capacitors by their values could probably be Green caps! poly/mylar type. cheap, an a couple of cheap 220uf Electro caps 16v types or better. B- an B+ to connect battery 9V. Getting the coil winding right ,an matched is the tricky part?
May 28, 2009. 6:37 AMrickove says:
See in the photo MKT capacitors used for most all, except the Electro caps.
Jun 20, 2008. 1:25 AMPanther_645 says:
Which transistor can be used in place of BC 183B transistor.
Jan 1, 2009. 10:44 PMpaewookyung says:
I used a C1815 transistor and it's works well.
Dec 27, 2008. 12:40 AMrabiif says:
very good
Jun 23, 2008. 6:50 AMkingwaffles says:
What gauge of wire did you use?
Mar 10, 2008. 12:04 AMJoelDude says:
my BFo metal detector
OK I'm finished here it is!!
Mar 3, 2008. 8:46 PMJoelDude says:
this thing is harder to build than it looks. I built it to spec and nothing. I've used this calculator to find the inductance:
http://www.coilgun.info/mark2/inductorsim.htm
and I have both inductors within .007mh difference, using 9v battery and tiny headphone. I hear nothing n i got voltage on both coils. i can't find what's wrong. I used radioshacks transistors " general" use npn. I've spent3 days and nothing.
Mar 8, 2008. 8:36 PMJoelDude says:
Ok i figured it out: the diagrams in the transistor package are very confusing. all transistors were backwards. it works but it still not finished i'm working on a more detailed instructable of this same one so everyone is more confortable at atempting it
Jul 20, 2006. 12:58 PMHen says:
Does Anybody Know How To Make A Homemade Metal Detector? If So Tell Me How This Is VERY IMPORTANT!!!!
Feb 26, 2008. 12:34 PMJoelDude says:
SOMFG!!!!!111eleven one!! ROFL STFU LOL!!!!!!
Dec 21, 2007. 1:18 PM!Andrew_Modder! says:
really...
Dec 14, 2007. 8:41 AMDavidRobertson says:
duh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 8, 2007. 2:05 PMMouserz says:
hahaha
Nov 24, 2007. 3:56 PMJames (pseudo-geek) says:
um. thats what this instructable is about......
Nov 2, 2006. 4:16 AMamlan_2008 says:
PLS SEND ME THE DETAILS OF TRANSISTORS USED IN BFO METAL DETECTOR
Oct 18, 2006. 3:20 PMCoffee bean says:
Part of this site is relisting projects so they can become more widely used!!!!
Sep 3, 2006. 10:02 PMvbrtrmn says:
Nice work, really cool to read. Thanks!
May 2, 2006. 2:43 PMSilas says:
P.S hehe, no i also don't want an argument, were all makers, we should stick togheter.. I'm merely pointing out that this is not a "valid" entry..
May 2, 2006. 2:41 PMSilas says:
I'm not saying it's mine. What i'm saying is that, ok he put it in, but he should have added credits, and asked the owner if he could do it.. Am i sure?? YES! Check out this link, this is where he stole it from: http://home.clara.net/saxons/bfo.htm as i said before.. Also This instructable should NOT be able to participate in the contest! Honestly, HE STOLE IT!
May 1, 2006. 2:21 AMll.13 says:
Ok fair enough if you originally put this idea on (with ALL nessecary copyrights) but are you sure this is exactly the same as yours??? What was that about donkeys???? did you possibly mean llama??? P.S. i do not want this to turn into a huge debate(argument).
Apr 30, 2006. 9:06 AMSilas says:
How would you feel if someone stole a project of yours, posted it as there own, and then win a maker contest?! I bet you would feel like Big Bubba aka. hung like a donky, paid you a visit!
Apr 29, 2006. 1:31 PMll.13 says:
so what who is so perfect that they keep every single copyright law in the world?? how many pirate MS XP copies are there????(not exactly related i know)
Apr 28, 2006. 5:11 PMSilas says:
Sure enough #1 on google, search bfo+metal+detector.. I'm sure your well aware that if this isn't yours, then what you did, is illegal, right!?
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:jurgis
cx
