3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
bicycle trailer.
Step 5Chassis to bike connection.
chassis to bike connection.
this is how i built the trailer handle. So that the trailer wouldn't sit at a funny angle I needed an s-bend type thingy to raise the height of where it would attach to the bike. I had some funny pieces of wooden hand-railing that i drilled, screwed together, and then bound with waxed string. later this was to prove the weak point. the actual attachment to the bicycle is a pair of old crutches, these can be found anywhere.
4 comments
Feb 24, 2009. 9:02 AMalanwest says:
Conduit - aluminum or EMT is easily bent - up to about one inch diameter. Some electrical shops will sell you a piece of scrap and bend it for you. Don't think I would go larger than two inch. 1-1/4 inch would probably be about right.
Feb 11, 2009. 12:27 PMthe commando bear 2 says:
this is the best disign for a bike traler that i have seen so far on the internet and im going to try and make it this weekend. p.s wheal char wheals are a lot better for this type of disign as they are made to be side mounted.
Jan 13, 2007. 12:34 PMbuildingteen says:
hwo about some pvc and two 45 degree angles?
Oct 7, 2007. 2:58 PMHandsome-Ryan says:
PVC is not strong enough to be weight bearing. also- It breaks down in sunlight so even if it holds for a while it would break eventually (at the least opportune time).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
110
Author:saul
