bike trailer
bike trailer
this is a cargo bike trailer for towing whatever and can be made on budget for like 10-20 dollars
parts needed
-metal pipe
-small bolts and skrews
-tub or cooler of some sort
-golf bag caddy (get them at thrift stores)
-caribeaner
-strap/rope
tools needed
-drill (drill press best)
-wrenches
-screwdriver
-something to bend pipe(vice and two people work)
Step 1Frame (golf bag caddy)
frame (golf bag caddy)
using a golf bag caddy as the axle/frame take the pipe and drilla hole thru it and the bag caddy and bolt them together. now bend the pipe to go around the back bike tire and to the chainstay (bottom pipe on tire fork for rear of bike). make sure it has room for you to make right turns with out hitting the tire.
17 comments
Jul 25, 2010. 7:31 AMespdp2 says:
If you already own a bike trailer and you don't use it anymore, it makes a great cargo trailer too. I found mine for sale for $5 at a yard sale.
Apr 8, 2010. 1:00 AMguitarpete247 says:
A much better mount would be something like this from a child bike trailer www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_729517_categoryId_165542_langId_-1. I'm sure similar would be available in most countries.  I have this on trailer I take grand daughter out in.  It has safety cord on trailer if pin comes out.
Dec 2, 2009. 8:41 PMmtbr4life says:
 Does the trailer have a lot of play when you turn and stop? It seems like it wouldn't stay connected very well
Mar 11, 2009. 3:47 PMangusmacgyver says:
i made one that is dif than yours. but it is hard to pull do you have any sugestions? (besides making it lighter)
Dec 5, 2008. 11:07 PMYerboogieman says:
Does this bounce around at all or anything like that? Or is is Fairly smooth?
May 8, 2008. 3:18 PMdewexdewex says:
Trailers work best if the force from the load in them acts directly down through the axle. Also, the coupling should be relatively stiff but should allow the bike to lean. A universal joint like on the Weber Kupplung is the best. Failing this, a length of stiff rubber radiatorhose from an automotive supplier of 1/2 to 1 inch should do the trick. The trouble with the Weber, howver, is that it's axle coupled. Even if this is better for towing, it's more awkward for bending down when attaching/detaching. Hope that helps.
Jul 14, 2007. 5:03 PMJoss2007 says:
hi, does the hitch bar not hit the back wheel when your taking a corner ?
Jan 9, 2008. 10:08 PMglassspider2142 says:
if it duz put more bend in it! or pay some one to work it out for you!
Oct 7, 2007. 2:50 PMHandsome-Ryan says:
I like that your design uses materials you could get for cheap or free.
Jun 24, 2007. 5:19 PMcpotoso says:
This is a very cool idea, very very useful.
Jun 22, 2007. 2:02 PMRobyntheslug says:
This is one of the most realistic, cheap and simple builds I've seen! But could you point out where exactly you are attaching it to your bike? Cool beans! -Robyn
Jun 22, 2007. 2:01 PMjolshefsky says:
I see those old golf caddies in the trash now and then and always thought they had to be useful for something. Excellent idea!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:rocknrollskwurl
