Introduction: Bleaching Powder Battery
Its a simple homemade battery costs around .92$
Step 1: Materials
500g of ordinary chlorax bleach
Tap water
×1 clip cable
×10 50ml small container's
×10 aluminum strips
×10 copper strips
multiple voltametre
Step 2: Cells Construction
Take a knife , make two slits , beware make one small and make one bit large and make a small hole using shouldering iron for drain hole.
Step 3: Electrodes
Fit the aluminium strip to the large slit and copper to small slit.
ALUMINUM - cathode
COPPER + anode
Step 4: Filling Electrolyte
Take one container, fill water until it reaches top, later add a spoon of chloride bleach, stirred it well until it dissolve.
Step 5: Testing Cell
Have a look, each cell produces around 1.35v to 1.45v.
Step 6: Connecting All Cells
Now, I have connected all cells together, it produces 14.30v to around 15v max so I can easily connect to my home theater.
THANK YOU...............
Is there any issue of small amount of chlorine being developed here? Wow, 14-15 volts from these chlorax batteries! Quite innovative. Well, any metal with a base (bleach contains Lye too) would generate electricity.
Do you know if Hypochorite ions in solution with lye help increase voltage? Electrical Potential Molar of Lye (Sodium hydroxide).
NaOH (aq) >>> Na+ + OH-. Probably the main factor. Hypochorite ions are quite weak for an acid tho.
As a test you should test 1 mole Lye soluton and 1 mole Bleach to see the difference in voltage. That would allow you to see the difference in voltage potential here.
59 Comments
I also think bleach or HClO may have an influence on the flow of electrons too.
HClO << >> H+ + OCl-. Acid.
NaOH << >>> Na+ + OH- Base.
Chlorine and hypochlorite ions (OCl-) could in theory somewhat give the 14-15 volts tho.
You should try other types of Bleaches (Pool bleach) Sodium dichloro isocyanurate too.
NaDCC + 2 H2O → 2 HOCl + Na+
+ C3N3O3H2
http://www.oxy.com/ourbusinesses/chemicals/products/documents/isocyanurates/acl_faqs.pdf
I would seriously like to know how this type of knowledge is obtained. The contributors and commenters, (while not always the best spellers) have a grasp of chemistry, physics, engineering, etc. that I never got in school and I know my kids are not getting, despite taking AP Science classes. Without practical application, there is little retention or deep understanding of complex connections, but even simple applications that could lead to more innovation. Is this by design? Because I feel that if more kids were exposed to the exciting world of making, and doing, with mentors who encouraged trial and error, but supervised to teach safety, to prevent accidents, we would see much more engaged citizens and less crime even. Yet the schools and local governments seem resistant to allow the development of spaces that would nurture this type of learning.
very, very interesting... my self and my grandsons would try this ....will use led on the output or led bulbs according to voltage...maybe it will make a good night light...i bought a led clock that has a wick and uses water to power it,its over a year now and it is still working.
thanks
my great grandfather had a 12' x 16' poured concrete vat 4' high in the side yard of his house around 1931?- 1953 (a-c lines finally ran to area). this vat contained similar cathodes and water with an active agent from U.S.Carbide added a 90 pound bag at the time.my mother can verify this but did not know name of agent used.
US Carbide is an acetylene manufacturer, so that bag was more than likely calcium carbide, like the name. Coal miners use to wear CC lamps, where they'd drop a lump into some water for light down below.
Wow, amazing, the next step is making it rechargeable somehow...
IT IS NOT RECHARGEABLE,
if you try to recharge the electrodes may carrode ,
IF YOU WANT TO MAKE A RECHARGEABLE BATTREY,
Just fill the cells with salt water and charge with 24v output charger.
Please, tellme more.
Don't do this (@home)!
You will get H2 + 1/2*O2 which could be explosive.
