ok hey um im gonna show you how to make blue fire!!!
well to start off you need:
1.5 or so matches
2.sparklers that turn blue when lit{you can use normal ones just for fun, wont be blue though}
3.adult super vision,unless you are asking to get burnt
4.youreself
optionial:
thick paper
thin cardboard
diferent colored sparkelers
tape
Step 1: Matches!
ok so get the matches and cut the heads off like so.
then grind then up with knife or somin till made into a fine powder
thoraxe says: Apr 13, 2008. 3:07 PM
Hey! Theres a little somthing called... PROPANE! and... BUTANE!... and.. METHANE!!!.... They all burn blue! Even purple in the case of propane.
tbh-1138 says: Nov 26, 2012. 3:55 PM
And... ALCOHOL!
franklinonline says: Oct 28, 2009. 8:15 PM
 when things burn really efficiently and complete they burn blue. Its just that it does look supprising, as that looks like a jet.
geodez says: Jun 16, 2009. 5:11 PM
coke burns blue.
hardrock_jake11 (author) says: Apr 18, 2008. 6:04 PM
yeah... untill you blow ur self up? then what u do???
thoraxe says: Apr 19, 2008. 2:36 PM
well, thats your fault. If you blow yourself up you're too stupid to be playing with propane in the first place.
itsthatsguy says: Jan 4, 2010. 7:37 PM
well a propane blowtorch is really easy to modify, i am inventing a new nossle for them and i found is relatively easy to modify a torch safely. ( i am using a welders mask and welding gloves, over-protective but safer). anyway things burnm in differnt colors based on chemical composition and flame intensity,
from least hottest to most
yellow-red-blue-light blue- white
(white is so hot it melts hardened flame-proof and (supposedly)  melt-proof epoxy see here )
lunchboxslayer27 says: Dec 23, 2008. 9:01 PM
agreed!
guillotine says: Jan 17, 2010. 8:59 PM
diddent see the vid was taken down
RandomHero says: Jun 27, 2008. 1:27 PM
im pretty sure salt would turn blue also... thats what i heard at least
cowscankill says: Oct 7, 2008. 1:49 PM
salt turns red. copper powder would turn blue.
struckbyanarrow says: Aug 10, 2009. 1:25 PM
ya i've had a continuing argument that copper burns blue or it burns green..
PKM says: Nov 25, 2008. 12:52 PM
Actually table salt turns bright yellow. Copper compounds are greeny-blue, the only good red flames come from lithium and strontium which are hard to get hold of. Note that sodium chloride, copper sulphate and lithium nitrate are all "salts" in the chemical sense of the word, hence potential confusion.
Pryo Chain says: Oct 31, 2009. 11:12 AM
Mmyeah, salt turns bright yellow.
As PKM said, Strontium chloride makes red, but there's also:
  Copper chloride - blue
  Copper sulfate - green
  Potassium chloride - purple, and
And to make colored candles, just boil the metal shavings with water, then soak a wick in the solution.  After that, just cover it with wax, and you got a colored candle!
Mattrox says: Jun 2, 2008. 11:00 PM
you got a ton of pics but not of the most important thing the fire
EnigmaMax says: Mar 30, 2008. 2:42 PM
why don't you call it a blue fire instead of a rainbow fire?
heavy.metal.nguyen says: Jan 23, 2008. 3:29 PM
There is no picture of a final project.
hardrock_jake11 (author) says: Jan 24, 2008. 4:14 PM
k hope i fixed it
, i put on a video if not then heres the hyperlink
http://www.youtube.com/watch?v=5H97D9edZ4I
heavy.metal.nguyen says: Feb 4, 2008. 6:37 PM
For some wierd reason I read it as rainbow knife. Don't ask me why. So yeah that's why I posted that.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
