3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
bondo body filler casting
bondo body filler is normally used to fix dents in cars and trucks but A can use it for making small plastic like parts pieces or toys ill show you how to cast bondo in a one time use plaster mold for bondo
Step 1Supplys tools
supplys tools
stuff you need to cast bondo
10 comments
Feb 15, 2009. 12:47 PMthepelton says:
I have been making small carvings out of vegetable ivory nuts. The two problems they have, besides being only about plum size, is that they have a dime sized void in the center, and since they are nuts after all, they have an empbryonic palm tree at one end, that falls out when they dry out, and leave a hole about 3 milimeters wide by 3 milimeters deep. I wonder if bondo would fill that hole without looking out of place. The ivory nuts are usually a pale yellow-white.
Jan 6, 2012. 2:58 PMLokisgodhi says:
With the Tagua nuts I think you'd be better off starting with a white casting resin like Snap-On and adding a little yellow pigment to match the cream of the nut than using Bondo.
Feb 16, 2009. 1:28 PMthepelton says:
Perhaps I should ask the people in the Woodcraft store about how to fix that hole.
Sep 7, 2009. 1:21 PMMakaifh says:
for the love of freaking pete, either use a macro lens or hold the object further!!!! You can't see anything in these pictures!!!!!
Feb 25, 2009. 9:22 PMDR Mac says:
Hi, I've done something similar a few times, try mixing your "Bondo" etc 50/50 with polyester (fiberglass) resin, It pours easier and the stuff I had made the castings incredibly tough! You can also get other types of body filler in various shades including white. I colour mine with bottled pigments for fiberglass. Keep experimenting and have fun! Hope this helps.
Dec 22, 2008. 4:05 AMscafool says:
Hi Brandon. Your instructibles are getting better. I have used bondo to copy small pieces of wood trim.
Oct 18, 2008. 5:40 AMLftndbt says:
Nice work. Simple and to the point. Is this a common method, as I have not read of it before?
Oct 17, 2008. 10:22 PMmycroftxxx says:
Nicely done. Some spelling errors, but the instrucable is clear and easy to understand
Oct 18, 2008. 5:39 AMLftndbt says:
I concur. ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:brandon borick
