Introduction: Braided Princess Crown or Necklace From Flowers.
About: I have had a few careers so far, soldier, school teacher, arborist, millwright. I love change and I love learning.
The beauty of this instructable is it is totally free, you don't need any other supplies but flowers, and it's just tricky and unique enough that you will stand out as amazing.  Little girls just freak out when you make these, just be prepared that if you make one in a crowd, you will have tons of puppy dog eyes begging you to make more.
Please check out my other instructables: https://www.instructables.com/tag/?sort=none&limit%3Atype%3Aid=on&q=dave+spencer
I also have a DIY podcast at http://www.mechanicalmashup.tv
Step 1: What Do I Need?
As I said in the intro, all you need are flowers.  Most of the time I just pick clover from a park or soccer field.  (its everywhere where I live).  This is the first time I have incorporated flowers that were not weeds as well.  I have made them from dandelions (because little girls don't care) but I sneeze a lot after so I avoid them now.  They need to have stems at least about 3 inches long.  The amount required varies with how big a head it is being made for and how dense you want the flowers to be. You can also get the receiver of the crown to help pick them. I only ended up using about half the clover in this picture.
Step 2: How Do I Start the Braid?
Start with three flowers and begin to braid them leaving the flower heads at different lengths.  the heads normally keep the braid from unravelleling at the top.  As you approach the end of a stem (or anytime you want to add more flowers) just lay a new flower into the braid and run the old and new stem through the braid together until the old stem runs out.  You can trim the stems with your finger nails but I suggest at least three turns or braids of overlap.  You don't want it falling apart too easy.
If you are not sure how to braid:
https://www.instructables.com/id/How-To-Braid-1/
Step 3: Can I Make It Even Better?
This step is not required but if you can make a pattern of different types of flowers, all the better.
Step 4: When Do I Stop?
the length you are going to make this depends on whether it is a necklace or a crown and the size of the head it goes on.  I just eye it up.
Step 5: How Do I Stop?
This is the trickiest part, but once you have done it 2 or 3 times it is easy.  You need to take the stem ends you have and weave them into the starting end of the crown.  Pick one stem at a time and follow one of the stems at the start, tucking it through all the holes the starting stem goes through.  When done right, you will not be able to tell where the splice is.
Step 6: Now What Do I Do With It?
Find a deserving little girl who would like to be a princess and watch her smile!
The whole process takes about 10 minutes.  The smiles last the rest of the day.
Thanks for reading!
