Remove these ads by
Signing UpStep 1Parts
-crescent/ adjustable wrenches
-chain breaker
-extra chain
-electric drill
-bolts/ nuts
-two bicycles, nothing fancy (possibly a smaller frame for the stoker if you'd like, and if you're picky and want certain cranks, go with frames with square/ taper BB's)
-crank puller (optional)
-allen keys
-basic bike tools
-probably some other stuff I can't remember right now.
As another poster here discusses, I used to string 3 or 4 bicycles together by this method. I never tried more than 4.
FYI: "Tandem" refers to the arrangement of one in front of another; not to quantity. Mother duck and all her little ducklings following along behind her are "in tandem".
At any rate, if I build another one, it probably will have independent drivetrains!
We laughed so hard!
It's a very nice idea !
I'll try to make one as soon as possible,
congratulations!
It steers like a truck because it can't flex around the middle wheel.
Back in the middle of the last century (ok, I'm an old coot ), we used to chain as many as 15 bikes together by hooking the fork of one over the axle of the bike in front, usually for parades. Watching them snake thru the floats was wild as all the riders usually dressed up as clowns.
Each bike kept it's own chain drive and coaster brake (pre-ten-speed era), but the lead guy decided where you went ... and no arguing about it.
Take the bolts out, disconnect the rear bike drive from the front bike and you'll find it works a lot better.
Budd
It shows another solution to the same problem which is arguably simpler and more manuverable.
While (I agree) this would be catastrophic for the drive train that you've built, it would work fine if each bike were to keep it’s own (independent) drive train.
What I mean is, why not just connect the front fork of the rear bike, to the rear axle of the front bike, and be done?..
And best of all, this way you wouldn't need to splice a super-long chain together, or deal with complications of trying to share the drive train.
