i made this lamp in my first year of highs school, i wanted a lava lamp but without the color so it would be easier to read under its light. i reconstructed the lamp earlier this year since the first base for it wasn't i deal because when i built the lamp i didn't have the ability to weld.
i call it a bubble lamp and not a lava lamp because in its off state the "lava" sits at the top of the bottle, but as it is turned on and heated the wax sinks according to the room temperature and remains a static bubble.
you will need:
+ power plug
+ switch
+ glass bottle
+ metallic bottle holder (angle iron)
+ rubbing alcohol
+ paraffin wax
+ 30 watt globe
Step 1: Base & switch
switch
you could go with the easier option of using a cable mounted switch. but i enjoy making mechanisms and creating more work for myself. so i went for creating a rotary switch using a brass knob from a drawer. i threaded a bolt into it and welded a washer off center to touch the switch, the video should explain.
Video
invalid movie: http://www.vimeo.com/5487773
base
the base can be made out of whatever you want i used wood because it has a nice finish and made it much easier for me to router the shapes to create my switch.
cdalton4 says: Apr 28, 2013. 10:06 AM
Love the instructions, thank you
TheBookworm says: Nov 10, 2012. 11:27 PM
can you fix the video link? Vimeo does not seem to like lava lamps
surfreak says: May 9, 2010. 1:18 AM
The paraffin wax I'm familiar with is a white, waxy solid. Could you elaborate on what you mean/describe what you're using?
The nerdling says: May 31, 2011. 10:40 PM
kerosene
The nerdling says: May 31, 2011. 10:26 PM
steampunk-ish cool
--= Excogitate =-- says: Jul 24, 2010. 1:55 AM
wait wait wait... paraffin wax AND alcohol?! Around a BULB. It's cool looking don't get me wrong, but it seems like a big liability. Is there a sub for the alcohol at least?
ryanninjasheep says: Jul 13, 2010. 6:54 PM
does it have to have a perfect base???
NinjaFixedIt says: Jun 23, 2010. 7:35 AM
Looks cool! Lol, the book next to the lamp: Death By Black Hole Lol!!! ROFL!
fabiyamaue says: Jul 19, 2009. 12:26 PM
i've tried it, didn't work...
rmart says: Jul 10, 2009. 4:40 PM
yeah I can't find it, could u maybe, post some how on wiring this thing up. I was wondering if u could use a "stick light" like the ones u find in a fish tank
[insert username here] says: Jul 11, 2009. 6:27 PM
I don't think a fluorescent bulb would be hot enough to melt the wax.
cmallouf says: Jul 7, 2009. 9:55 AM
nice job, I like the wooden base, and your switch, but you left out the wiring and placement for the bulb. Unless I browsed past it.
wrs715 says: Jul 11, 2009. 6:39 AM
He mentioned the placement of the bulb in Step 2. I think this is a grand idea, largely because I wanted one of these beasts, but either they were too expensive, or (when I could afford it) the color scheme was completely garish. :\ This way, at least, I get to make it what I want! :D
possum888 says: Jul 7, 2009. 3:00 PM
This came up for me
Video
rustlabs (author) says: Jul 7, 2009. 8:22 PM
yeha, any idea how i can fix that? it wont embed properly..
jovino says: Jul 9, 2009. 5:11 PM
<object width="400" height="300"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=5487773&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=5487773&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="300"></embed></object><p><a href="http://vimeo.com/5487773">switch</a> from <a href="http://vimeo.com/user643523">michael candy</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
rustlabs (author) says: Jul 10, 2009. 9:52 PM
yeah, that doesn't work, tried it.
jphphotography says: Jul 9, 2009. 8:14 PM
I made a lava lamp like this years ago, we used mineral oil instead of paraffin wax though. Mine was actually just like a lava lamp though, you have to use 70% rubbing alcohol and 99% though. You start off with the 99% and fill it up most of the way, then add %70 which changes the density, add 70% until it looks like the mineral oil is wanting to lift off the bottom. Once you get the mixture just right it works just like a lava lamp. I coloured the oil using oil based paints ;)
toddley says: Jul 8, 2009. 2:28 PM
OK, I'm thinking this Instructable is from the UK. In the US, paraffin wax is a solid material.
Paraffin wax is called kerosene in most of the U.S., Australia and New Zealand.
http://en.wikipedia.org/wiki/Paraffin
xenobiologista says: Jul 9, 2009. 8:33 AM
I think you mean "paraffin", not "paraffin wax" is called kerosene in the US. I live in the US and I have seen "paraffin wax" used lots of times, mostly to refer to the high-molecular-weight solid paraffin that cheap candles are made of. I believe rustlabs is referring to what most US authors call "mineral oil", since "kerosene" refers to the lighter fraction which is used to fuel lamps and aeroplanes - which is also a lot more flammable. Also, you wouldn't find kerosene at a pharmacist, I don't think.
Speaking of flammability, this alcohol/mineral oil formulation can be hazardous. There are versions using water and various organic solvents which are somewhat harder to obtain, but safer. See here.
Danish M1Garand says: Jul 9, 2009. 7:53 PM
No OP is talking about sealing wax. The kind you use to seal jam jars with.
USA=Paraffin wax is solid at room temp 19c 70F
toddley says: Jul 9, 2009. 9:50 AM
Thanks for helping clarify. Sometimes I think we need a universal translator for our own language! Now if we can correct the aluminium thing, we'd be good to go! : )
Jack of Most Trades says: Jul 9, 2009. 8:57 AM
Hopefully rustlabs will clear this confusion up for us. Sucks to be a "people separated by a common language", don't it? ;) I'm suspecting it's what we Yanks call kerosene or perhaps the ultra-refined lamp oil called "liquid paraffin". I really like this lamp. Very nive.
DasBus says: Jul 9, 2009. 6:34 AM
Beautiful!
sparx01 says: Jul 7, 2009. 4:42 PM
could you change the colour by adding food colouring?
lukeyj15 says: Jul 9, 2009. 12:52 AM
our kerosene is dyed blue (AUSTRALIA)
Suzanne in Orting says: Jul 8, 2009. 2:25 PM
My sphere of knowledge is more craft and food related, but I would think that you could use candle coloring for the paraffin, and food coloring for the alcohol. You might even be able to use water colors. There are other paints of course, but I would imagine that a translucent paint would be desirable. I hadn' t thought about coloring the alcohol or wax until you mentioned it. Thank you. I was thinking of trying to bottle out on a coffee mug warmer before trying to build the rest of the apparatus though.
rustlabs (author) says: Jul 7, 2009. 8:37 PM
yes, i probably should of mentions that, but only the colour of the alcohol, the bubble will stay clear, i tried it before on an artwork of mine.
the "lamp" section is on the far right of the attached image.
full sized image: http://lh4.ggpht.com/_Fu8rqNSZflM/Si36VYz5kLI/AAAAAAAAA3o/2QWH11Po868/kinetic-organic%20pan.jpg
maruawe says: Jul 7, 2009. 7:21 AM
neat! are you going to make a different base now that you can weld
rustlabs (author) says: Jul 7, 2009. 7:24 AM
(removed by author or community request)
maruawe says: Jul 7, 2009. 12:48 PM
not the wood base, the lamp base, where the bottle is held.. I make a lot of stuff and don't like the bolt heads showing. (personal opinion) I will make the lamp but without bolts, a 30 watt bulb should not get hot enough to cause problems
could also use led's to illuminate the mixture in the bottle, But at what temperature do you have to have for the wax to move in the bottle...
Chicken2209 says: Jul 7, 2009. 8:56 AM
incase you didnt know, the movie didnt take in step one
MLB Baseball Guy says: Jul 7, 2009. 8:24 AM
Looks nice indeed. Lots of creative persons here!
Abhorsen says: Jul 7, 2009. 8:17 AM
Like it a lot. Gonna try it sometime.
jessyratfink says: Jul 7, 2009. 6:45 AM
Really pretty. Nice design! :D
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
