Introduction: Build a $4 Lens With Interchangeable Kaleidoscopic Filters for Any Digital Camera
in this instructable i show you how to build a really cool lens attachment for almost any digital camera.
with the advent of digital cameras, i blossomed (not like that chick in that sitcom, though). if i had had the money, i would've loved to get into developing my own film and slr cameras and what not, but alas. . . i did not. taking film to get developed at exorbitant rates didn't help. digital let me do it all without the expense or the darkroom. i'm sure many out there feel the same.
i still can't afford the cutting edge, so no digital slr. but, here's a novel way to make abstract lenses for almost any digital camera.
Step 1: The Lens
i began by looking for some sort of lens to experiment with. i was hoping to find something like a kids science optics kit but came up short.
at michael's (a craft store) i stumbled upon some cheap plastic kaleidoscopes and a light bulb turned on above my head.
these things are $1.49 apiece, and there were different types of lenses. i'll show you the two options that i liked the best in this instructable.
Step 2: The Fit
we need something that will fit over the lens of a digital camera and connect to some of the pieces from the kaleidoscope. this will vary depending on the camera you have. i have an olympus and the lens slides out when activated.
i looked for something that would fit snugly around the lens. i came across a small cardboard tube of glow bracelets that was just larger than the circumference of my camera lens. this was a good find, because it had these black plastic caps on each end. these are easy to carve up and make a custom fit. check out the pics.
the bracelets were $1, and given the fact that the bracelets are still usable and you are only recycling the packaging, i'm not sure we should include that in the price. either way, it's cheap!
Step 3: The Parts
here is the setup. when you take apart the kaleidoscope you will find some fun parts.
the blue piece in the shot is the outer part of the kaleidoscope on the end that holds the prism lens.
the white piece is part of the interior that holds the lens.
the prism is obviously the prism.
the tube is part of the glow bracelet packaging.
the black ring is the modified ring seen above.
disclaimer: this is how i did it. just allow this to inspire you to find your own way! no single way works for everyone. . .
(i was a philosophy major)
Step 4: Make It Interchangeable
before gluing anything, i inserted a lens into the blue tube, shoved the white one in after it, and then started drilling. i drilled a hole through both pieces of plastic to accommodate a small screw. this allowed me to change the lenses for various effects.
i'm sure there is a better way to do this and welcome any ideas.
Step 5: Put It All Together
we've seen this pic before, but let's look at it again.
glue the cardboard tube to the white plastic tube. that's really about it. the rest just sort of snaps together.
the black plastic end cap slides into the cardboard tube. the lens goes into the blue tube, which then fits over the white tube. the screw goes in to hold it in place, and you're good to go.
check out the next step for a visual of the final product.
Step 6: Get Crazy
here is the finished product. it slips right over the lens of my point and shoot camera. it's incredibly light and therefore doesn't need threading or anything else to hold it on.
look closely at the pics and you'll see the two different lenses.
make one. send me some pics. go nuts!
cheers!!
-pdub
cheers!!
-pdub
