Step 3Componet resting spots
iImage Information
the componets need to be IN the guitar so you need to cut a place for them I used the 3/4" piece to cut into (more space see picture) the plexi glass pieces will rest on top of the holes. after cutting the plexi glass to the shape desired place them where you want them to go now take a drill bit and drill holes in both the plexi glass and the the wood ( these holes are for the screws to hold the plexi to the wood) during this step you should also dremel a pathway from the hum bucks to the componets to do this I used my dremel tool along with a drill bit. I made a line / cut with the dremel and a straight edge. then I placed the needed wires in the cut then glued the 1/2" piece on top. (also w/ the 3/4" you need to cut a place for the Neck of the guitar!!!!)
