build a digital pin-hole camera
I always wanted to try making pictures with a pinhole camera, but it was one of those things I never quite got around to. Now with digital cameras its easy.
You will need a digital single lens reflex (SLR) camera with an interchangeable lens, some black card stock, a pin, black tape, scissors, and a way to replace the lens with a piece of black card stock with a pin hole in it.
You could just take off the lens and tape the card with the hole over the lens mount, but I wouldnt recommend this, as it provides lots of opportunity to get dust and stuff into the camera. Instead I've devised two ways to quick-mount the card with the hole onto the camera thus minimizing opportunities for dust to get to the sensor.
The first is to make the pinhole in a body cap that fits your camera. It would be hard to get this right the first time, and stocking up on body caps is a bit of a pain, so I drilled a 5/16" hole in the body cap, and then taped the actual card with the pinhole over the hole in the body cap. Because the pinhole is mounted quite close to the camera's focal plane, it results in a fairly wide angle image.
The second way is to use a set of bellows to mount the card onto, and then onto the camera. I picked up a new, non-original equipment set of bellows off eBay for about $50. The bellows bayonets onto the camera, and provides a simple way to mount the card when the bellows is not on the camera. This results in a longer focal length, but with the bellows you now end up with a zoom pin hole camera, which is not something you see every day.
Step 1Making the pinhole
Making the pinhole
Measure the lens mount on your camera, or the diameter of the body cap. Mine was 2 inches outside edge to outside edge of the mounting surface. Draw circles this same size on black card stock and cut out with scissors. In the center of the cutout circle poke a small hole with a sharp pin. (Big pinholes mean fuzzy images)
Someone commented that the thicker the card, the fuzzier the image, so use the thinest piece of black card you can find. You could also try tinfoil which is very thin and could result in a sharper image.
27 comments
Oct 6, 2011. 9:14 AMspark master says:
very nice for shots at beach or autum leaves, are these all your pics or do you have more? The road picture in the last group is very impressionistic quite nice actually.
please do a short video of this, worth 4,000 words.
Dec 23, 2010. 2:36 AMcraziemutant says:
Cool! I'm gonna build this and use at Disneyland! =P
Oct 19, 2008. 2:25 PMbooklvr630 says:
Is that the only kind of digital camera it will work with or could it work with any kind?
Sep 30, 2010. 1:32 PMDreamsInBloom says:
This Instructable and this reply led me to try what you said...putting the pinhole right over the lens of a point and shoot digital camera. I have one that you can change the exposure length of time. It's not a true pinhole camera, but it's still kinda cool.
Jun 6, 2010. 7:39 PM92033 says:
Just visited your page...great photos...especially the one of the bridge. You can make an easy tripod base for use on the camera. Use a piece of 1/4" thick plywood or plastic. Drill a 1/4 inch hole in the center. Use double-face carpet tape or layer of rubber cement on face of the wood/plastic base and layer on bottom of camera. Stick together for a permanent bond. Screw your tripod screw into the hole and you're all set. Want 'simpler'? Lightly duct-tape it to tripod. Removes easily. Idea is to hold the camera still and level..this'll do the trick. Great Instructable mind-refresher for me...have been in photography all my lifetime...'1200 Year Old Highlander Immortal', y'know. :-) Which reminds me...Do you know what Jesus said to the Apostles at The Last Supper? "All you guys who want your picture taken, sit on this side of the table with Me". Moses was The First Photographer. He used a Pinhole Camera and Bolt Of Lightning for the FLASH. Came out pretty good, eh?REPLY [flag][delete].
Sep 4, 2008. 12:21 PMdrejansen says:
sorry, I do not understand the reason of pinhole photography.
Jun 6, 2010. 6:55 PM92033 says:
Do a Search on "Pinhole Photography" / Pinhole Cameras" for research on its history. Way back when...before Glass Lenses were invented, 'Pinhole' cameras was the void. It creates soft focus photos with unbelievable depth of field (sharpness from closest to furthest object from the 'lens'. Back in the early '50's I converted my 4x5 Speed Graphic Press Camera to Pinhole use for experimenting. With the focusing bellows and ground glass back you can set-up your image...slip the 'pinhole' over the wide open lens and get fabulous photos. They could be exposed on 4x5 sheet film or 4x5 sheet printing paper...developed and have photos regular cameras can't take.
Sep 5, 2008. 11:59 AMshoehornteeth says:
Theoretically, infinite depth of field. Or "it looks cool."
Apr 1, 2010. 7:00 PMhaunted_lady says:
 This picture looks like it was taken with a toy camera like a Holga or a Diana.
Apr 2, 2010. 7:44 AMhaunted_lady says:
 Ummm their "lens" is a piece of plastic..hahahaha
Sep 20, 2009. 6:28 PMcoolkid90999 says:
you can even just out aluminum foil in a filter holder or on an old lenscap and that will suffice then just zoom in and out until you get the desired look
Jul 10, 2009. 9:46 PMurbanmari says:
My first experience with photography was at camp. Our project required a box that we would paint black--I felt bummed or embarrassed that I didn't have a box, all we had at home was an old Quaker Oats cannister. In fact, mine was the coolest pic that I got to develop myself in the darkroom. Of course, it worked because the photo paper was placed in the cannister and 'absorbed' the curvature showing a really wide and distorted view. I keep wanting to recreate that with my digital but have a mental block of how. Thanks for sharing this. Care to theorize how to effect a cannister look, anyone?
Sep 19, 2008. 1:38 PMlgcalex says:
why do you feel that it is necessary for the bellows? Also try shooting these again in raw
Sep 6, 2008. 3:30 AMamagriva says:
i think you'll have the same effect breathing on the lens and shooting...
Sep 3, 2008. 4:57 AMPKM says:
I believe you can get some interesting effects with non-circular holes. Try a short vertical slit- you should get sharp detail in one direction but blur parallel to the slit. Having a bigger aperture should mean you can use shorter exposures. Here's something I always wondered- what happens if you have two pinholes about 1/4" apart? What happens with increasing spacing? Would you get diffraction fringes if they were close enough together?
Sep 4, 2008. 3:36 PMturnhandle says:
You do get diffraction effects with multiple holes. I tried this way back with a film SLR and got good and really bad results. Multiple holes in various patterns result in "insect eye" multiple images. Lots of fun for way less cost with digital.
Sep 4, 2008. 2:37 PMhammer9876 says:
Woo hoo! PT Cruiser!
Sep 4, 2008. 1:27 PMbbqpope says:
well done, I see you have a spot on dust on you senson....
Sep 3, 2008. 8:12 AMuguy says:
Sharpness also depends on the accuracy of the pinhole and the thinner the material.. A pinhole in the cardboard or paper is actually pretty fuzzy. Try making a pinhole in some aluminum foil with a nice sharp needle. Don't poke it all the way thru, then sand the back side lightly with a very fine paper. The better the pin hole the greater the depth of view and the sharper the image.
Nice intructable!.
Sep 3, 2008. 5:09 AMbrightest_cyan says:
Cool use of the bellows, for the adjustable focal length. One thing to try is put a cover over your viewfinder before you take the exposure, often viewfinders will leak light on such long exposures, which may account as to why several of these pictures are kind of cloudy white. Give it a try.
Sep 3, 2008. 3:30 AMve2vfd says:
Cool idea! It would probably be sharper and more contrasty if the pinhole were smaller and you used a longer exposure time.
Sep 2, 2008. 9:34 PMCameronSS says:
You might try digitally bumping up the contrast to get an image more like a conventional pinhole camera produces.
Sep 2, 2008. 8:00 PMLinuxH4x0r says:
Cool effect!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:richard2nd
