3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
building an Eve costume from Disney/Pixar's Wall-E
Step 12Build the heart light
build the heart light
Eve has a light on the left side of her body which pulses green with a simple image of a plant on it. I drew a picture on the computer, coloring the plant part black and the part around it green.
I then took a poster tube and cut out the paper to fit inside it. I cut off a 3" section of the tube, and covered the inside with silver foil. I did the same for the end cap. I then drilled a hole and threaded through 3' of green EL wire, and hot glued the battery pack to the side of it.
I then taped the paper printout of the plant on to the left side of Eve's body, and hot glued the poster tube assembly atop it.
Because I was running out of time (this was the day before Halloween), I bought it from a local electronics shop in Berkeley, Al Lasher's on University.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:drwave
