loading
Step 12: Glue the front panel
After all the glue from the last few steps has dried (24h), start to glue the front part. First unscrew the front part and mark the middle of a side.
Now apply some wood glue to the lower half of the front face and the frame and press it together with the help of something heavy, like water bottles or books. Make sure you don't load it to the middle of the front plate, because this will bent the sides up and buckle the front side. Alternatively turn the box around and load the back with something heavy or use supporting boards.
<p>I'm going to be building a custom Cajon and wanted a professional opinion on my design.</p><p>I've noticed that a lot of Cajon players will tilt back on the instrument when playing. Leaving a gap between the floor and the bottom of the Cajon. I can only imagine this does two things. Makes it more comfortable to play and improves the sound by allowing some of the vibrations to escape from underneath and be focused toward the front.</p><p>I've used this observation to design the Cajon pictured below. My design allows for the playing surface to be more ergonomic to the player without tilting it. And the opening in the front caused by the raised bottom panel and bottom sound hole should focus more sound toward the front of the Cajon.</p><p>My questions are, will the additional sound hole on the bottom degrade the sound quality in any way? If I add a sound hole on the bottom, is there a need for one on the rear panel? And last, are there any other considerations I need to keep in mind when building this to maintain the best sound quality possible?</p><p>Thank you for any advice you can lend.</p><p>- Dean -</p>
<p>Hi Dean, </p><p>this is an interesting approach. Yes, most players tilt it because it is easier to play. But I have no idea what the second hole in the bottom does. Or if it is better to have only one hole in the bottom. </p><p>The wood on the back is thin, like the front surface, so to make a hole into this seems logical to me. Also it is directly opposite of the playing surface. </p><p>But make a try! As long as you don't use glue, you are free to disassemble it again! And please share your experience. I'm curious to know if it is better... :-)</p><p>Cheers<br>Andreas</p>
<p>Thanx for the reply Andreas. This will be my first Cajon and my first Cajon build. So I'll have no frame of reference as to whether it is better than a traditional Cajon. But I did see a design very similar to this that I stumbled upon recently. The Pearl Sonic Boom. </p><p><br>This looks a lot cleaner and simpler than my design. I may have to give it a try. I'm going to write Pearl and see if I can get them to explain how the inside is built and if there is a rear facing hole. There may be a baffling system that redirects the sound forward. I'll check back if they do.<br><br>Thanx again for the help.</p><p>- Dean -</p>
<p>Hi Dean, </p><p>this is a cool Cajon, didn't see that before! And I could not even find any pictures of it in the web. Maybe I have make a stop at my lokal music-store for a look... </p><p>Good luck for your building!</p><p>Andreas</p>
<p>http://pearldrum.com/products/percussion/cajons/sonic-boom-cajon/</p>
<p>Hi!! I made my first cajon following you instructions with a bit of customization, It sounds really good and the percussionist of my acoustic band plays it in our gigs. Thank you</p>
<p>Hi,</p><p>the sound is surely good without the snares. It depends on what you like, the snares just add a new component of sound to it. :-)</p><p>Try at the local music stores, maybe they have spare snares or used guitar strings... </p>
<p>Loved the instructable, i've been thinking for so long to make one by myself :)</p><p>Just a small question, the sound without the snares is good, it does the work, or the snares make a better sound? Because here in Portugal it's hard to find some cheap snares ou guitar strings :/</p><p>Good Work :)</p>
<p>Great instructable, I want to start it this weekend.<br>I am based in the UK, and was wondering will the standard plywood (from B&amp;Q or Wickes) at those thickness work as am trouble sourcing 'Birch Plywood'<br></p>
The side parts have to carry the weight, so make sure to select wood that is strong enough. <br>The front has the major impact on the typical sound of the cajon and should be only 3-4mm thick. <br>DIfferent plywood may be different sound. <br>That doesn't mean one it better than the other. I've seen a lot of Cajons with different wood. <br>Here in Germany it is hard to get something else than birch... :-)<br>
<p>Thanks, </p><p>i will try what my local depot is supplying and let you know the results</p>
I made it my self!! Cheers from Greece!!! A great tutorial!! I put the snare in the middle and in a very small difference from the vertical position!! Made the perfect sound!!!! Thanks again!!
Since I'm from Germany, too: where exactly did you manage to get 14mm Multiplex? I searched for it and 15mm was the closest I could get. Since it's that hard to find on the Internet I don't suppose it's easier to find at Toom or such stores.
Actually I used 12mm for the side and 4mm for the front and back side. <br>And I bought them both at Bauhaus. <br>The sides are not critical, they only have to carry the weight of the player, even 15mm is ok. <br>The front and back panel shall be as thin as possible, to provide a good sound. The 4mm might not always be available, just keep on trying!
How do you keep the snare rattles from staying in that position against the wood? Wouldn't it fall off if you hit the front side?
The wooden 'U' keeps the long rectangular rod in place and the snares produce counter-pressure to the 'U'. It won't fall off, even if you would turn it upside down! <br> <br>On the other hand, if you install the snare so that they don't touch the front side, because you don't want the snare sound, then the rod may fall out if turned upside down!
I made my own and the coats of stain and polyurethane did wonders and made it look store bought. I made four legs by cutting out 1.5&quot; holes in a 1&quot; piece of wood with a hole saw, then countersinking them and putting felt tabs underneath. A great instructable
Perfect! An absolutely wonderful tutorial. I just finished mine and the sound is incredible. A quality cajon like this is sold for $100 - $300. We have enough wood to build 4 and we only spent $80 (wood, glue, sandpaper, etc. included). <br> <br>Thank you andyk75!
I have this project going on right now. I'm gonna make those snare wires myself by recycling old guitar strings.
I haven't read through the whole instructable, but, are the cornered shafts actually just for the corner? Are they necessary? Thanks!
I think yes. They are used to take up the screws from the two sides parts that form the corner. Otherwise you would have to screw directly screw the side parts to each other and they are rather thin for this purpose. Look at step 10 to see what I mean. With the shafts it is much more stable. <br><br>What gldx03 meant was the main frame of the box. I used 12mm wood and he suggested 8mm. Then you really need corned shafts! The front part could also be thinner like 3mm or so, but that is hard to find.<br>
Hi, I am Peruvian, and the &quot;Cajon&quot; is from Peru, and I want to comment that the wood should be thinner for that sound is much better, should be around 8mm
Are you talking about the front part that you beat on? I'm not a very good builder, so i'd like to make sure...
are the screws in the small blocks completely necessary?
Do you have any idea how many double entendres are in this instructable? I was both cracking up and admiring the detail the whole time. Helpful and entertaining.
Yes indeed, I didn't intend to, but now you said it I might have thought a bit longer about the text... <br>
Very cool. <br>I have played a few Cajon drums, and I really liked how versatile they can be. The only thing that has kept me from buying one myself is that it seems to always bee overpriced. I guess also.... my lower back would start to ache if I played too long. It would be nice to be able to sit more upright when played.
To play the &quot;Cajon&quot; it takes a lot of practice with the techniques in their hands. Afro-Peruvian music is the most used instrument. I can see Eva Ayllon concert or Peru Negro as an example but there are many more.
Never heard of a cajon, or one played. After looking at youtube, this is something I might try. thanks for posting.
A tip: next time you should clamp the block first exactly into place, then drill the holes, release the clamps, apply glue and after five minutes put the parts together and immediately screw them together. This way you don't have to worry too much about the parts swimming in glue or sliding out of place when clamping. And you're not stuck with some parts with clamps on it for hours as the screws will hold everything in place fine and no clamps are needed after glueing.
I tried this several times before, but the chance for a misaligned piece is much higher. You might drill precise enough, but the screw causes some force by itself. Think of a hard piece of wood right beside one of the drilled holes! The screw will then be shifted to the other side...<br> <br> Because of that it is much better to glue the parts first and then screw them together. It's the difference between enough and too much that is difficult for beginners, this is why I wrote these notes.<br> <br>
It would be good if you could add an mp3 or video of it being played...
I have tried a video yet, but the sound is so bad, you only hear a click any time I hit the cajon... I hope to get a better one soon.
Andy, Any idea why you are not getting a better sound? I wonder if plywood is appropriate? Also how thin were your front and back?
It's a problem with my camera, not with the cajon! The Sound of the cajon is great, but recording a drum is not easy. Front and back are 4mm thin or thick.
Andy - Just a thought... if you are trying to record the sound and a video using a digital camera it might help to see if you can set it not to change focus during the video. I had an old Cannon camera that picked up the sound of the motor adjusting the focus. Just an idea, you may have tried this already. Cheers - Mike
I second Kiteman, I would love to hear how it sounds. You did a very good job laying out the steps and I'm think about making one, but I would really like to hear it! Thank you for the effort you put into the instructions, well done.
Thanks now i have another project ot add to my list of things I need to build. Seriously Great project and great instructable, very clear
Looks good andyk75 - nice work! They are really fun to play, sound much like djembe/cunga/bongo once you get the hang of it. It makes many sounds depending where you tap it or even slide your hand along the head like a brush sound, just combine the different sounds like any hand drum. I've made a number of them and given away most. I make three sizes, one very large I call filing cabinet (drawer, get it? use it for bass drum, tap it with my foot while playing a smaller one with the hands) one I call kitchen (the size of a kitchen drawer or briefcase, much more portable, 12x20x3 inches) and one called nightstand about 13x13x2 inches. I try to use only recycled wood, and the older the better. Old wood gets more resonant with age, more sustain, a more rich tone, like a Stradivarius! My fave that I kept has sides of 50 year old red cedar and heads from 50 year old 1/8th inch wood paneling before they invented that particleboard junk. I've made several from actual crate wood, some from tearout from remodeling, always free and otherwise headed for a landfill. A light finish like a thin coating of wax or tung oil on the 2 thin &quot;head&quot; plywood sides and rubbed on, rubbed off urethane/stain on the 4 thicker sides. A light, very resonant wood is the best side wood such as red cedar if you can find it, or any guitar wood or other musical instrument wood, solid wood or ply. A wonderful ply is birch. Whatever species, if you tap it and it sings, it will make a great cajon. I have a little black walnut I'm going to try next for sides, and I predict fabulous tone. Tried pine but its too soft and makes a more muted tone. Most important thing is to have fun making it beautiful, and then have fun make the music beautiful. Enjoy!
A guy in our church worship team went from a djembe to a cajon and the volume is about the same, while the range of tones is spectacular for such a small instrument. Another advantage is the player has a built-in seat. In fact, that's the way it's supposed to be played.
Here are my plans which include the ability to &quot;tune&quot; your cajon. http://www.tomasdaly.com/How_to_build_a_Cajon.html
Very nice instructable. a cheaper alternative is to use guitar strings for snares. but this looks very well constructed.
I have always wanted to build one of these self so simple but yet very cool instrument. One thing tho don't the real drums lie this ave snare wires in the to resonate. here is a link of a picture of the snare wires inside sorry about low res i cant find any better ones http://brandontrading.wholemusiclearning.com/BTE%20Graphics/LP%20Aspire%20Cajon%2001B.JPG. Also another picture a little better resolution with snare wires only going half way im not sure what difference it would make http://caseyconnor.org/cajonstuff/images/markscajon4.jpg But I've heard if u want to go cheap instead of snare wires you could use old guitar strings (or new if you want) but i would say to wait till u have a bunch of the same gauge. Good instructable tho i still may try to build one myself!
Looks really cool. Be nice to see it played, especailly regarding how to position yourself for play and also to see the size compared to a person. I'm assumming you can play it from any side, right? I wonder how loud it is?
http://www.youtube.com/watch?v=HXeNTf2EaUI&amp;feature=related
I just saw one of these at a live gig recently. I was completely stumped as to where the drum set was. It took me a while to figure it out, but as soon as I saw it, I wanted an Instructable about it! Thanks!!!
It's kind of a drum that's completely made out of wood. It's origine is from south america, Peru.<br> In an earlier version I had a short description, but that somehow got lost. Obviously...<br> <br> Thanks to edbro, g2yeux and jacob13 to set this clear!<br>
I would add this to your intro to make it better :) I was wondering what a cajun is as well. Perhaps you also should put &quot;music instrument&quot; in the title or something. Judging by the front picture I was thinking of a small stool or something :p
I didn't know I could edit the instructable once I submitted it! But now I added some information to the intro.<br> The similarity to a stool is not wrong. It is also a very comfortable seat during outdoor sessions...
About This Instructable
237,932views
490favorites
License:
Bio: I like to explore new things and try out stuff. At the moment I'm in to electronics, BLE and LEDs.
More by andyk75:Micro Bluetooth Low Energy (BLE) Robot (for Roborally?) Make 3D-action Videos for a Budget-price Wifi Photobooth with a Raspberry Pi
Add instructable to:
