3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
can tab chain body armour
grade 2 aluminum can tab armour.
Strong and easy to make, but takes a while to make.
Step 1Materials
materials
for this you will need
- a lot of copper wiring
- needle nose pliers
- wire cutters (unless the pliers come with wire cutters)
- and a couple hundred can tabs
45 comments
1-40 of 45next »
Nov 5, 2009. 5:10 PMKosmicon says:
Ok, 2 Points to make here.
          1: This takes waaaaay too long! Im having a hard time gitting all the tabs, and not to mention being bored outta my mind wile weaving.
           2: Has anyone ever thought of smashing cans into a flat plate like thing, and hooking them together with Duct tape? I think its worth looking into...  :D
Nov 9, 2009. 5:55 PMKosmicon says:
Smash a can flat Long wise, so its not just a flat circle. Put a few strips of ductape on it so it covers both sides and cover your whole body with it. then u will see what it is, and how well it works! THANKS
Mar 20, 2010. 8:36 PMtrevor3693 says:
that would be really cool if u put da colored side so people can see it.
Sep 19, 2009. 9:25 PMChaseyWasey11 says:
this is how big I make my rings compared to a dime
Jan 13, 2010. 12:01 PMchainedflesh says:
Links that small... are you a madman? (LOL)  My first chainmaill project I used rings that size... to make a hauberk.  After six months I vowed "never again".  To be honest i still use links that size, but only when making jewelery or making Japanese weaves.
Sep 20, 2009. 5:37 PMChaseyWasey11 says:
I used my camera phone to take the picture. I need to get a real camera so I can show you guys what the coloration of the two different types of ring are like. The coat hangers I put through an electric wire brush thats on my stationary grinder, then I hand crank the coils because the metal is so thick. I tried using a drill on the coat hanger and it didn't go over too well. I then slide the coils on a peace of rod after bending the ends tight so they are tight fitting on the rod and then proceed to cut them with my dremel tool very slowly about half way through. I cut them half way through and then bend them off the could snapping them right off of there and making a very nice butted together ring.
Sep 20, 2009. 5:39 PMChaseyWasey11 says:
I meant to say bend them off the coil snapping them right off
Nov 12, 2009. 12:07 AMNIJU! says:
www.instructables.com/id/Genuine-chainmaille-from-pop-tabs/ why dont you make it like this. (link above) i made a 14cm by 11cm peice in half an hour without any skills here is a pic
Nov 12, 2009. 9:06 PMNIJU! says:
 oh yea and this way is very scratchy so i sowed it onto the top of some gloves and now it looks awsome. cant send a pic because i gave it away as a birthday present.
lol $56 of pepsi
Nov 12, 2009. 9:04 PMNIJU! says:
 well this one still looks beter even if when you dont make it big enough it has a tendancy to disconect link by link but if you make it big enough that doesent hapen
Sep 26, 2009. 7:43 PMmoosofa says:
it looks very scratchy... and probably hurts when you move your hand around... have you thought about lining the inside? maybe with duct tape or a thin glove or a thin cotton?
Sep 20, 2009. 5:41 PMChaseyWasey11 says:
The bottom ring is coat hanger and the top ring is galvanized. Both rings seem to be similar in thickness other than the fact that the coat hanger wire is stronger and a slight bit more thicker. The galvanized wire I use is 14 gauge being harder to work with but much more stronger than 16 gauge.
Sep 19, 2009. 12:28 AMChaseyWasey11 says:
hope this is just for looks because mah knives would go right through this. Why not use metal coat hangers, make a mandrel, make ring coils, and cut your own rings? If your going to make chainmail you might as well make it good and make it worth your time. This would be good for costumes only.
Sep 19, 2009. 1:42 AMChaseyWasey11 says:
4 in 1 chainmail is not hard to repair, doesn't cost that much if you know where to find ur materials, and is more effective than soda tabs. Soda tabs are lighter but as far as that knife going through it ur better off with real chainmail. I know no ones going to knife you any time soon but when I think of chainmail I think of the real thing being better.
Jun 18, 2009. 2:49 PMPastTheVoid says:
OOH, Black Sabbath...
Jun 24, 2009. 8:56 PMPastTheVoid says:
What are you trying to prove?
Jun 23, 2009. 11:35 PMdunnos says:
how did you get so much tabs? nice ible
Feb 21, 2009. 4:47 PMsoullessperson says:
ha, i hacked into soulessperson's acount. The knox lives! muahahahaha
Jun 5, 2009. 4:10 PMo123 says:
THIS IS AMAZING''
Apr 30, 2009. 5:07 AMminerug says:
I have finally got around to making my own version of this click here to see the intructable
May 2, 2009. 6:22 AMminerug says:
Thanks for the nice comment =)<br/>
Jan 29, 2009. 3:28 AMthedog458 says:
that is amazing 10 out of 10 like you said its easy to repair very cool im gona start geting lods of those littel tabs now.
Sep 14, 2008. 6:59 PMsageserver says:
Use european 4 in 1 chain mail. its stronger than yours. i also did the same thing but i did it the scale mail way, not the chain mail way.
Oct 17, 2008. 4:41 PMBuffaloNickel says:
doesn't exactly hav a system, does it?
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:knoxarama(Knoxarama Company)
Visit my site. If you have a site, send me a link and i might add you to my 'partners' section, where your link will be.
