Cardboard Coffee Table
887
Posted in WorkshopFurniture
Introduction: Cardboard Coffee Table
I have been using cardboard for different thing ( mostly Helloween ) for over 20 years now this was a dream that I had to bring to life. my dream was a coffee table that looked a little asian,
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    2 Comments
    Wow, this is so cool! Please post a step by step on this!
    1.I used chair boxes (because the pieces are large enough that I wouldn’t have any breaks)
    2. Cut a template out of paper. Folding the paper in half and cutting so both sides are equal.
    3. Glue 3 pieces of cardboard together using paintbrush and school glue. (The corrugation was all running the same way (sort of north and south.)
    4. Repeated step 3 except I put the corrugation the other way (east and west.)
    5. Repeated step 3 again (north and south)
    6. I put a ¾ inch one piece of lumber on all and let dry 3 days.( covering the whole piece of cardboard with equal pressure.
    7. I took template and traced it on all 3 layers (making sure one run north/ south than east west than north south.) this helps with the strength.
    8. Cut them out with a jigsaw.
    9. Glue them all together and put the weight back on. Waited 3 days. This did one side.
    10 started back with step 3 for the other side. Now I had two outer sides.
    11. I bought paper tablecloths (without plastic in them) from the dollar store and cut stripers, using paintbrush and white glue I painted the strips on like you would do paper mache. I tried regular paper but didn’t like the length of the strips. The tablecloth was much longer and the paper didn’t rip when it got wet.
    12. The part in-between where a little harder.
    13.once I decide how wide I wanted it I repeated the gluing process but instead of 3 pieces running the same direction I did one north/ south, one east west, one north south.
    I did not want it so thick, 3 layers was thick enough. I only built the inside to reach the outer potion of the side panels.
    14. I did this so I could add 6 layers on the outside to hold the side from collapsing outward. Again I repeated the glue and paper thing.
    The bottom shelves was done the same way.
    15.After about 3 more days of dry time I painted everything red.
    16.Waited for it to dry than painted about a 6-inch square and took a bamboo stick, (the one used for shish cob) bent it almost to breaking point and scrapped the black off revealing the red under tone.
    17.Varnished with spray varnish.
