3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
centrifugal pump
centrifugal pump
These are the instructions for a centrifugal pump a team of product design engineers made for a project to pump water a height of 60cm efficiently.
Pump is still in the prototype stage so any input would be welcomed.
Materials/Components
Motor
24V Power supply
Acetate Frame
Aluminium Axles
Acetate Gears
Aluminium Impeller
ABS Plastic Impeller Housing
Ball Bearings
Meccano Chain
Plastic Tubing
Purchased Components
Motor - RS Components.
Link:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2483671
Power Supply - Weir Instrumentation Ltd
Meccano No:94 sprocket chain
Ball Bearings - RS components
Link:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6671122
Plastic Tubing
Step 1Creating the Frame
Creating the Frame
The frame was manufactured using 4mm thick laser cut acetate.
Files were created in Solidworks and exported as a DXF file - the format appropriate for laser cutting.
5 Sections were cut and using dichloromethane attached together.
spec and pictures to follow.
1 comment
Sep 8, 2011. 12:21 PMMrF_DT_teacher says:
I made a similar pump to this using the laser cut laminated method about a year ago. Mine is really crude in comparison nice job. does the pump need to be primed before use as mine had to be submerged?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:beckka___
