Cereal Box Backpack
6,431
13
Published
Introduction: Cereal Box Backpack
This is a simple 5 minute project
all you need is an empty cereal box (or full I don't judge)
tape for straps (I recommend you use duct tape because it is thin and light)
a cutting implement of some sorts (I used a box cutter)
2 binder clips
Step 1: Cutting the Box
mark 4 lines on the box and start cutting
your slits should be very thin and just wide enough to thread the straps through the box
Step 2: Staps 1
make two long lines of duct tape and two lines of packing tape and stick them together so that both sides are smooth
you should end up with two long strips that are not sticky
Step 3: Straps 2
now thread the strips of tape through the slits that you cut into the box and tape the ends together so they make a loop
Step 4: Latches
take the two binder clips and clip them at the ends of the box these clips will work as latches for your backpack.
Step 5: Finished
your done now just fill it with this and that and your ready to roll.
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    • Pets Challenge
      Pets Challenge
    3 Comments
    Hm, I don't think a backpack like this will be strong enough to hold anything... Neither spacious enough to hold much, neither is it very comfortable.
    Maybe sewing a backpack would be a better alternative?
    is it strong? I might consider covering the outside with duct tape. that might make it stronger.
    hey this is nice
