Remove these ads by
Signing UpStep 11
2 pairs of pliers
252 5/16" rings
2 1/2" rings
something to fill it with
First make a 4x24 sheet
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
The first two I did with 18g 3/16" rings. It makes for a hacky sack the size of the small ones you can get in bulk. I filled those with knots made from the same rings.
Now, speaking of redundancy...
The most recent version I used 18g 5/16" rings like shown in the pattern to make the outside. When I was finished the weave looked to loose to me. So I made another with 16g 5/16" rings and filled it with the previously weaved empty shell.
Not only does it have a nice smooth look to it, using the previously weaved shell gives it just the right amount of fill (not too full or floppy). Also, using the weaved shell as filler keeps the fill from settling too flat.
Total rings used:
254 - 18g 5/16" bright aluminum (fill)
254 - 16g 5/16" bright aluminum (shell)
(I don't use half in rings to close the ends.)
NOTE: instead of 24x4 i done 24x2 sheet as i wanted to finish quickly =P
THey have a wide range of sizes and materials to work with. If you prefer to make your own rings, they also have the wire and tools for doing so.
Only if you could shoot it out of a cannon..... as like a steel wire yarn ball.
Mine came in cardboard
