3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
chain maille hacky sack
how to make a unique hacky sack
Step 11
You will need:
2 pairs of pliers
252 5/16" rings
2 1/2" rings
something to fill it with
First make a 4x24 sheet
144 comments
1-40 of 144next »
Oct 10, 2011. 8:46 AMGrey_Wolfe says:
I have used this pattern to make three hacky sacks now.
The first two I did with 18g 3/16" rings. It makes for a hacky sack the size of the small ones you can get in bulk. I filled those with knots made from the same rings.
Now, speaking of redundancy...
The most recent version I used 18g 5/16" rings like shown in the pattern to make the outside. When I was finished the weave looked to loose to me. So I made another with 16g 5/16" rings and filled it with the previously weaved empty shell.
Not only does it have a nice smooth look to it, using the previously weaved shell gives it just the right amount of fill (not too full or floppy). Also, using the weaved shell as filler keeps the fill from settling too flat.
Total rings used:
254 - 18g 5/16" bright aluminum (fill)
254 - 16g 5/16" bright aluminum (shell)
(I don't use half in rings to close the ends.)
Jan 22, 2010. 11:56 PMdany man148 says:
what i did is i put my hacky sack in there... kind of redundant iknow XD
Sep 17, 2011. 3:39 AMcurious youth says:
wouldnt want that hackey sack getting damaged ;)
Jul 12, 2011. 10:06 PMdscherer1 says:
i like the simplicity of it and it seems much easier than some ive done but it looks kinda sloppy
Nov 30, 2009. 2:21 PMbig-jamie says:
thought you all might like to see my first attempt at a maille hackey sack
NOTE: instead of 24x4 i done 24x2 sheet as i wanted to finish quickly =P
Jun 4, 2011. 9:49 PMzen of zappa says:
and with a 24x2, does it stall better? just wondering cause that always helps and i also want to finish quickly...
Jun 5, 2011. 4:45 AMbig-jamie says:
it does mean that the hackey sack is flatter than if you used a 24x4, but i dont do hackey to be honest so i wouldent know if it is any better at using, i just made this as a project.
Jun 4, 2011. 10:24 PMzen of zappa says:
i found awesome colored rings from the ring lord...but they are 3/8. do you think that will still be okay? cannot wait to make it for this summer!
Oct 15, 2010. 10:41 AMmofunnyman says:
i gotta say it takes a long time to make (im only on 12 rows) but it is fun and rather than steel i would recomend that you use copper due to the fact it is easier to bend.
Nov 10, 2010. 10:32 PMTrace II says:
The only problem is it will corrode faster. I recommend using 16 gauge annealed steel. It doesn't rust too fast, and because it is annealed, it is easier to work with than regular steel.
Feb 24, 2011. 1:53 PMmofunnyman says:
thats true mine does quit shining if i dont put it in vinigar.
Dec 11, 2010. 8:17 PMLastMemory says:
Not to take away from the Instructable creator but... If you google (used as a verb) Dragonfly hacky sacks you will come up with a hacky sack online footbag store. They sell chain mail hacky sacks also for only 15 dollars. They are almost impossible to break. Plus the geniuses put in a web of rubber... strands?? Ig lol. They add a bit of a pop to the footbag.
Feb 8, 2009. 7:25 PMmartin8510 says:
where can i buy those rings and can someone please help ,but i love those footbags
Sep 16, 2009. 5:02 PMKryptonite says:
You have to make your own, search around on Instructables on how to make the rings for chain maille.
Sep 20, 2009. 6:42 PMthing 2 says:
What?
Apr 4, 2010. 1:46 PMGrey_Wolfe says:
You can purchase good quality rings from theringlord.com.
THey have a wide range of sizes and materials to work with. If you prefer to make your own rings, they also have the wire and tools for doing so.
Sep 20, 2009. 9:28 PMKryptonite says:
Google it.
Jul 28, 2009. 9:06 PMCoinaco says:
Where do you go to buy tiny, metal rings?
Aug 3, 2009. 11:31 AMwizerd 745 says:
There are places online to buy the ringlets, but I buy 16 guage steel wire from Lowes to make into rings. There are instructables for this.
Mar 7, 2010. 10:57 AMSpeedmite says:
I got my wire from lowes too. 16 awg, annealed steel, of some mysterious length, but I weighed it at 3.4 lbs. So, A lot. For only $5 too!!!
Mar 7, 2010. 5:47 PMwizerd 745 says:
Ya!  I got 200 ft for about $6
Mar 8, 2010. 5:38 PMSpeedmite says:
Great stuff. I need to measure a section, weigh it and figure what I gots. Its a lots.
Mar 8, 2010. 7:23 PMwizerd 745 says:
Lol, yup
Mar 8, 2010. 9:27 PMSpeedmite says:
I was playing soccer with it, with shoes of course, inside on carpet with the plastic on it. It was fun. It was like a train when you kicked it, of course, only on the ground. =)
Only if you could shoot it out of a cannon..... as like a steel wire yarn ball.
Mar 9, 2010. 6:38 PMwizerd 745 says:
Lol, awesome  X3
Mine came in cardboard
Mar 9, 2010. 7:56 PMSpeedmite says:
Aw... Well, i guess you have to resort to other alternative soccer methods, such as knex splody grenades....heh heh.....
Mar 10, 2010. 3:10 PMwizerd 745 says:
Lol, I don't mind
Feb 20, 2010. 8:29 PMzigzagchris says:
wow i really want to do that now. I need wire but doubt my parents would let me get some for this.
Dec 10, 2009. 8:44 PMtwojima says:
works well =D
Dec 4, 2009. 6:14 PMcowscankill says:
Yay! I did my first chainmaille project! :D  (around it is a Full Persian chain)
Jul 24, 2009. 8:13 PMcrazyromanian says:
dude any1 try playing GOD with one of these sacks? I;m pretty sure they would hurt like hell!!!
Sep 29, 2009. 7:48 PMMathias Re'eh says:
Yeah I'm making one and going to use it for battle hack
Sep 29, 2009. 8:28 PMcrazyromanian says:
AWESOME, and stay alive
Aug 3, 2009. 12:06 PMMtalus says:
I imagine the best use is at the Renaissance Fair, dressed in full armor.
Jul 25, 2009. 12:04 AMtheatre_tech_guru says:
it hurts a lot I have made one recently for a friend, it leaves welts and bruises the size of cd's
Jul 27, 2009. 10:25 PMcrazyromanian says:
id say that beats paint ball, w/frozen balls...at least in size
Mar 21, 2010. 4:01 PMVTASATRUAR says:
hehe you said frozen balls :P
Jul 24, 2009. 8:27 PMqballcat says:
lolz im canada we play kill
Jul 24, 2009. 10:29 PMcrazyromanian says:
haha, nice. I guess that is less deadly though cuz u hav to get 4 insted of 3 hits
Sep 20, 2009. 6:45 PMthing 2 says:
Where can I get the rings????????????????
1-40 of 144next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jehan
