Change Eye Color With Photoshop / Cambia Color De Ojos Con Photoshop
Published
Introduction: Change Eye Color With Photoshop / Cambia Color De Ojos Con Photoshop
English
In this Instructable you can learn an easy way to change eye color with photoshop. 8 steps :D
I don't know much about photoshop, but here's a little something. I hope you like it : ).
Espanol
En este instructivo puedes aprender una manera facil de cambiar el color de ojos con photoshop. 8 pasos :D
No se mucho de photoshop, pero aqui­ hay un poco. Espero que les guste : ).
(Lo siento, no puedo utilizar ni acentos ni enies]
Step 1: Pick Out an Image / Elige Una Imagen
English
First, you should pick out an eye image big enough to see the changes. Or take a picture.
It's just to practice.
Espanol
Primero, debes elegir una imagen de un ojo suficiente grande para ver los cambios. O toma una foto.
Solo es para practicar.
Step 2: Enter Quick Mask
English
Now, select "enter quick mask". Honestly, don't know if it's called like that :$
(colored with yellow).
Espanol
Ahora, selecciona "enter quick mask". Honestamente, no se si se llame asi :$
(subrrayado con amarillo)
Step 3: Brush / Brocha
English
Pick out a brush size to carefully paint the iris.
Espanol
Elige el tamano de la brocha para que, cuidadosamente, pintes el iris.
Step 4: Select / Selecciona
English
Exit quick mask mode (Press the yellow colored button). Now inverse the selected part Select>inverse.
Espanol
Sal de "quick mask mode" (oprime el boton subrayado con amarillo). Ahora invierte lo ya selccionado "Select>inverse"
Step 5: Hue/saturation
English
It's time to color your eye :D
Select: image>adjustments>hue/saturation
Es momento de colorear tu ojo :D
Selecciona: Image>adjustments>hue/saturation
Step 6: Colorize
English
Adjust the Hue and lightness depending on your image (mostly you don't need the lightness). If you use "lightness" just try to make it to much 'cause this would make your eye look less realistic.
Espanol
Ajusta el "hue"[no se como se escriba en espanol ^^U] y la iluminacion (lightness) dependiendo de tu imagen (la mayoria de veces no se necesita de la iluminacion). Si necesitas de la iluminacion solo intenta no utilizarlo mucho, ya que esto hara que tu ojo se vea irreal.
Step 7: DONE!
English
With some other adjustments on the image this is my result.
Thanks for reading. :D
Espanol
Con algunos otros ajustes a la imagen tuve este resultado.
Gracias por leer. :D
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    6 Discussions
    I love doing this! I do it with hair, though. It takes a long time. I spent an hour and a half with a friend on his hair in photoshop, and we sent it through email to people. They all believed it!
    Nice job, especially having twin languages, I incorporated a similar technique for changing eye colours in to one of my photoshop 'ibles but this might leave more detail in the eye after...
