Here we are going to turn 3 cheap ($4 each at fry's marketplace) LED screw-in lights into a fishtank light/hood combo.
Remove these ads by
Signing UpStep 1Break lamps
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
Those were my very first foray into led light bulbs.
Stupid, mismatched led batches, with no surge protection in the circuit.
If you are VERY careful, it's just a bit of caulking, holding the glass overbulb in place. Wearing heavy gloves, and eye protection, give the glass a gently twisty motion, while rocking back and forth. I only broke 1 out of 4 that i tried this with, but when they break they REALLY break. little shards flying everywhere.
Now, the two piece plastic base can EASILY be pried apart with a flat blade screwdriver. So easily, in fact, that the base pops back together, if/when you finish replacing the single burned out led.
On the other hand, BEAUTIFUL re-use of the product.
The extra space, and the metal mounting should help with heat.
Just make sure to keep a spare set of leds around for when one or two burn out.
One bad led will kill the entire circuit till it is replaced.
(remember when Christmas lights were like that? on bad bulb would kill the string, till it was found and replaced?)
Question.
"THESE LEDS ARE WAY TOO DIM, BUT PROJECT IS A SUCCESS NEVERTHELESS. "
Does that mean they are dimmer than in the original bulb configuration?
Just wondering if the current led batches are bright enough to do the job of ACTUALLY lighting stuff. Like , say, replacing a 4 foot T8 florescent fixture with two of your 3-bulb light hacks?
I know a single bulb was enough for lighting a small stairway at night, and 4 were enough to light up our small bathroom when used in the over-the-sink-tracklighting.
If you have any specific questions, feel free to PM me(to minimize the clogging of your comments section). Or you can start a thread in the forums. Either way, the community is here to help :-)
Using virgin led's, the only thing i can think of that would really be different is... you probably want a new driver circuit.
One tuned to meet the needs of the led's you use.
