Step 3Experiments ive tried and rough results
now pictured here is the solenoid pickup i made for the 3 string slide guitar thats been featured on this site a while back.( i didnt remove it for a closer look as its hotglued in place and i dont want to break it)but it is a coil that was found in the filter paddles of an old one hour photo printer{i know thats not common junk but copper coils are everywhere} a magnet from an old car stereo speaker has been positioned in the centre{wrapped with a bit of vinyl tape to make a nice tight fit}
the two leads from it run through the back of the guitar to a 1/8 phono jack near the end .
plug it into your amp and get it within about half an inch of a vibrating guitar string and you will hear it .
its a little quieter than a real pickup but it works
but it should still work.
though if the magnet is hugely strong it may dampen down the vibration of the strings some .
let us know if you try it and how it works.
if you have a small but very powerful magnet you can just stick it to a bigger bit of iron or steel and it will all be magnetized.
also check out this instructable that i did after the 3 string one.
it may answer a lot of questions you might have and save time on your experiments.
http://www.instructables.com/id/cheap-and-easy-guitar-pickups/
try to get a working pickup made before you build the guitar that way you can build around whatever shape you come up with.
also document what you do and make a posting of it .
the more the merrier i say.
after all there have been about 40 knex sniper guns on here but mine was the only slide guitar.
id like to see yours. cheers.
