Cheap and Easy Led Grow Light
Introduction: Cheap and Easy Led Grow Light
this is my version of the led grow light. the blue and red led are good for stimulating plant growth and the clear give off all the other colors the green is to make the light look clear instead of blue and red like most led grow lights
Step 1: Materials
1.a metal pie pan blue high output led strip red high output led strip clear high output led strip
5.optional one green high output led strip
6. 12 volt adapter
the led strips should only be about 2 dollars for two inchs at the local electronic shop and should have a self adhesive side
Step 2:
put the led strips on the inside of the pan. put four holes in the pan so the wire can go to the top of the pan.
Step 3:
pull the wires though the holes and connect the positive wires together them do the same for the negative wires and connect them up to the adapter. i wrapped  the wires with some electrical tape to make it look neater and to prevent shock.
Step 4: The Test
plug in the adapter into the wall if the lights turn on the your ready to hang your light. if the lights do not tun on the check the wire and make sure the positive is not connected to the negative. and for hanging i used some cheap paper clips that i had they hold on to the rim really good.
Step 5:
now place the plant of your choice under your light and watch it grow. in the photo i have my pepper plant in my home made hydroponic system that i show how to make in another instructable
Step 6:
check out my other instructable and maybe event give me a vote for the contests i will be entering thanks a lot and happy growing
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Really keen on the outcome, if it's good, will consider building it =]
    Here is a question. If a colour change LED system is Blue, Red, and Green LEDs, and they give off white light when all are combined couldn't you use a commercially available (ikea for example) LED colour shift kit for grow lights? The specs on the Ikea product are spotty, but if powerful enough they should work...?
    I know green light does not help I just made it with these colours so the resulting light would be clear and not mess with your eyes
    Green light for plants indifferent. White light they are only interested in red and blue. On the photo - the schedule of light absorption by the plant.
    I was using it for a while and the plants grew well but I had to take it down I did not have enough space for it
    Cool instructable. I would be curious to see how well the plants react to this setup over time.
    How long have you been using this, or a similar setup?
    Do you have any data on how well this would work long term vs getting a full spectrum fluorescent?
    I am just using the high power LEDs they seem to work really good but from my understanding I think it's the colour of light given off by the LEDs that helps the plant to grow
    What electronics store? Will radioshack have this?
    I just went to the electronic store and they had sold it by the inch but the brand does not really matter as long as they are high output and have a self adhesive side
    Do you have a brand for the light strip. ?
