Cheap, easy, low-waste platform bed plans
Build a queen size platform bed on the cheap, with storage space underneath, for less than $30, in about an hour, and learn some basic carpentry skills in the process. Please read the "design objective" below.
For similarly easy shelving plans, see: http://www.instructables.com/id/Cheap-easy-low-waste-bookshelves/
For similarly easy dining table plans, see:http://www.instructables.com/id/Cheap-easy-low-waste-trestle-table/
As a professional carpenter, furniture maker, and designer/builder, I see a lot of home carpentry projects that are grossly overbuilt and over-engineered. One of the goals of this Instructable is to avoid the unnecessary overbuilding that I frequently see on this site, and that I see every day working in the residential construction industry. Many of the building methods we (in the US) use today are horribly wasteful despite the advances that have been made in materials science and structural engineering, because most people in the residential building industry, from architects and engineers to carpenters, are mired in tradition, doing things a certain way "because that is how it has always been done", rather than consulting the best available science, or even questioning their own assumptions about "the right way to do it". I don't intend to knock tradition, either. Many of the tricks, techniques, and tools that I use daily are definitely "old-school", but seem to have been forgotten.
This bed is designed to be cheap, lightweight, sturdy, and produce a minimum of waste, using a minimum number of tools. It is intended for use with a futon or mattress without a boxspring and provides storage space underneath sized to fit common cheap plastic storage bins. It also provides good ventilation for the futon or mattress, something that I learned was necessary after my expensive futon grew a large mold/mildew patch on the underside. For those who might think that this bed is flimsy, my wife and I use it nightly, and I am 6'-5" and weigh 240lbs. I wouldn't jump up and down in the middle of it, but it will easily take any other abuse you commit upon it. When I calc it out, this bed uses 23.16 board feet of lumber (1 bd.ft.= 144 cu.in.), or 1.93 cubic ft., and produces only 42 cubic inches of waste, about 1.25%.
Instructables member frazeeg has posted a SketchUp model here.
Step 1Materials and Tools
Materials and Tools
I was able to pick up these materials locally for just under thirty bucks. Bonus points for using reclaimed or scrap lumber.
Material:
(4) 14' 1x4 #3 and better pine
(1) 10' 1x4 #3&btr pine
(2) 10' 2x4 Std&btr fir larch
(8) 3" #10 wood screws
(66) 2" #10 wood screws
Try and pick fairly straight, pitch (sap) free lumber, if your local lumberyard lets you do so. Some yards are stingy about this. Try telling them that you are building a bed, and that you would rather not have pitch all over your mattress/futon and floor.
The finished dimensions of the top of the bed are 76" x 55". A queen mattress is 60" x 80". The slight mattress overhang covers up the ends of the slats and keeps the user from bumping their legs on them, and uses standard lumber lengths efficiently.
A note on screws: I am a professional carpenter and furniture maker, and I make things easier on myself by NEVER using Phillips head screws. The Phillips head was designed to "cam out" at a fairly low torque for assembly line work before the advent of adjustable torque limiting drill/drivers. I use only Robertson square drive or Torx head screws, and save myself a lot of time and frustration.
Tools:
Saw (Skil, hand, jig, or miter. Shown is a Skil)
Square (Speed, framing, or try. Shown is a speedsquare)
Pencil
Tape measure
Drill (Cordless or corded)
Appropriate driver bit for your screws
#10 pilot bit/countersink
527 comments
1-40 of 527next »
Aug 31, 2009. 4:34 PMtealeaf93 says:
Well looks like im not the only one that has built one of your beds and liked it. Thanks a lot for posting this instuctable. I've saved a ton of money.
Sep 24, 2009. 11:28 AMpartrician says:
i loved this project. i had to go to the home depot to get the lumber though but i got home and had this done within 2 hour. now i want to do the headboard mod with the nigth stand extension. i have already mapped it out and plan to install a drawer under the night stand exstension. thank you so much for such a cool project!!! i have saved a ton of money!!
Jul 18, 2010. 4:11 PMmhendrickson says:
After much searching, I found this Instructable for a platform bed. Built it, disassembled it and shipped it to where I needed it. Took under an hour to reassemble at the destination and it's wonderful. I tweaked the instructions slightly to account for the types of lumber available, but it's all worked out. Used the sheet recommendation in Instructables for a bed skirt and use plastic underbed storage containers to hold my clothes until the rest of the furniture arrives. This is a wonderful project and I recommend it to anyone who wants an inexpensive, easy to build bed. Would like to plug Otis mattresses. Made for futons and wonderful for this bed. Super quality - not a cheap mattress but worth it.
Aug 11, 2010. 2:01 PMBeanGolem says:
This Ible definitely deserves its rating. I just made one last weekend in a few hours. My lumber store down the street didn't have 14' 1x4s, so I had to improvise the breakdown a little and ended up with a few extra slats. I guess it just makes it that much more sturdy. The scrap is also long enough to be used in other projects, so that's a bonus. I'd post a picture, but... well... it kinda looks exactly the same...
Aug 19, 2010. 6:10 PMKbjug123 says:
I made my bed a week or two ago, built it all by myself. Amazed my husband that I actually did it. It squeaks slightly under certain conditions, but I think that I just need to put one new leg under it. For a headboard I really wanted a picket fence type headboard so I put an ad on Kijiji for a peice of used fence. Then , walking past our "burn" pile ( we live on a feedlot) I saw a peice of brown picket fence. My husband helped me fish it out and when I measured it , it was a perfect 60 inches wide, which is exactly what I needed. So I painted it glossy white and popped it between the bed and the wall. Ladada!!! Thanks for the great instructable . Can't wait to try something else!!
Oct 27, 2010. 8:44 AMsouthboundtrain says:
I am totally inept and I built this bed a year ago. It is a great bed, used with Otis futon. One of the best things about this bed is that it takes up so little space due to the fact the mattress overhangs. The size of the mattess if the amount of space the bed takes up. I'm about to undertake building 2 more. My husband is impressed as I have no carpentry experience whatsoever. Just trying to encourage other slightly beyond middle age women out there.
Thanks! Oh, p.s. only problem was that I couldn't find torx screws anywhere in the size recommended. Should I use deck screws on the next beds?
Nov 7, 2010. 9:25 PMeckmannl says:
Thanks so much for posting this! It is just what I needed. Last week my dad came over and I just called out directions to him and his helper. This week, I decided that I needed another one. This time I did it entirely on my own. I have never built anything totally by myself before (I'm a woman in my 30's), so this was really satisfying for me. The one that was built last week was according to your instructions. The one I did this evening was made a little more narrow to fit a full, extra long mattress. Thanks again!!
Nov 17, 2010. 6:59 PMmhendrickson says:
Hi Aeray,
Just wanted to send you pics of one of your bed designs. This is a full size. I had to use a piece of 2x4 vs 2 pieces os 1x4 (see pic). Will this cause me probs over the long run?
THANK YOU!
MaryAnn
Dec 20, 2010. 11:44 AMllmadigan says:
aeray, you are THE MAN! i made your shelves and am super pleased with them - especially since i'm not much of a builder :) i'm planning on making this bed tonight and have everything but the countersink. how important is it that the screws are sunk in? could just a pilot hole be good enough? i'm not trying to be a cheapskate, but if i don't have to buy it i'd prefer not to...
thank you, btw, for putting together these plans and posting them for free! i'm so proud of myself for building simple/solid stuff for myself.
Feb 14, 2011. 9:53 PMdivalea says:
I guess platform beds are like kittens, peanut butter cups, and potato chips: hard to stop at one!
I built a queen platform for myself this past weekend. I managed to get the Spax screws at Home Despot, but still had to settle for the loathsome Philips. (Which ended up causing problems, mainly fatigue from fighting the camming-out.) Another lesson learned with this project:check the angle on your table saw blade EVERY TIME, even the NEXT DAY. Most of my cuts were at a slight angle, very slight, because my blade got angled just enough from the previous day's cutting. On the slats and legs, this was not a big deal. On the one long frame piece, it was a "use a hacksaw to cut off a slice to square off the end of the lumber because otherwise there will not be a good joint" deal.
The building did go faster this time. Still not a two-hour job, but faster. The lumber and screws cost $40. I ended up with a number of 1.5" pieces (that I'm going to use for another project) because it was cheaper to buy 6' lengths of wood than 12'. (6' 1x4 at my HD was $1.99, 12' 1x4 was triple that.) I had to predrill everything again. Even with better screws, the wood split. Grrr.
After sleeping on my mattress on the floor for nearly a year (hey, divorced lady, should've taken the King bed frame!), this bed feels really high in the air. It's great!
I got the uncut lumber into the Crown Vic this time (last time, I had some pieces cut first, this time I didn't.) It took a while! I've included a pic for proof. ^__^
Pic 1 is the bed, all dressed up. I'm using a king comforter and flat sheet. (Bed linens were all sourced from discount stores like TJ Maxx. Still expensive, but much nicer than what the same money would buy for "current season" linens.)
Pic 2 is to show the awesome storage under.
Pic 3 is construction, using a sewing table and the first platform bed as sawhorses.
Pic 4 is "How to get 13 pieces of lumber in a car."
Next project: building your bookshelves to make swell room dividers. Can hardly wait.
5441637233_5f8a8bbdc7_z.jpg5441636701_147f7e2133_z.jpg5441638083_253a4b46d6_z.jpgphoto(9).JPG
Jul 14, 2011. 9:48 PMddodd1 says:
Firstly, this bed looks incredible, and it seems like an extreme thorough and concise instructable. As a college student, I especially like the low price estimate!
I'm hoping to build a platform bed for a twin size mattress, but it needs to fit a 28" tall dog crate underneath. It seems simple enough to just build much longer legs, but is that safe? Should I add an extra leg in the center and/or connect all four legs to keep it from wobbling? Maybe drill it into the studs along the wall? How much bowing do I need to account for? I don't have an extremely extensive amount of carpentry experience, and I'm worried about crushing my dog!
Jul 15, 2011. 3:02 AMddodd1 says:
Perfect! Thanks so much! I can't wait to build my bed!!!
Jul 17, 2011. 10:58 AMaertz says:
This looks pretty simple! I'm planning on building this but for a full size mattress. How would the measurements differ?
Jul 20, 2011. 6:44 AMtheloo007 says:
This is such a wonderful layout for a bed frame/storage area. I have a question for the author, do you see a problem if I substitute using 4x4 for legs. I want to add wheels and will shorten legs accordingly to adjust for the height? Lynn
Jul 23, 2011. 8:58 PMMindfulmoon says:
This is an excellent instructable. Directions were clear, thorough and easy to follow. The project turned out just as it should have. Even though we calculated and purchased for a different sized bed (Full) we had no trouble doing so. Took us slightly longer than we had planned but that was due to a severe thunderstorm, two meals and a movie break. :-) We are not "rushers". Thank you for posting this. We have plans for one more (twin) in a month or so. Also, we decided on a different sized bin due budgetary restraints and found it advisable to "downsize" the legs by 6 inches. I'll post a pic when I can. Also, I'll try to show our "hack" for attaching my legacy store-bought headboard.
Aug 1, 2011. 11:31 AMskillingsworth says:
I built this bed yesterday in a full sized version. I started with Phillips head screws which were a disaster, and quickly chose to drive all over town in search of Torx screws. After I found them, an hour and forty five minutes later, my "work in progress" guest room has a great looking sturdy bed! I'm working on a wood burning project for the headboard, and my daughter has already asked that I make her one in a twin version and paint it turquiose! I am going to shorten the legs though, she's only 5, lol. We are going to get the materials later today!
I am going to build bedside tables and bookshelves myself also. Once I realized how much money I could save, I decided the entire guest room will be made by yours truly.
Thank you aeray! I am inspired! ;-)
Aug 1, 2011. 9:39 PMskillingsworth says:
aeray,
I told you I was going to do it again...but I didn't! She did it herself! (I pre-drilled all the holes) But she really did her thing, this was an excellent project to do together.
Thank you again.
Aug 1, 2011. 10:59 PMskillingsworth says:
Thank you, I thought they were far apart also, and was about to go cut another one when I remembered her mattress is the "bunk mattress" it has it's own built in slats at the bottom of the mattress, so I don't think it will be an issue.
Take care, I'll be checking back often, I noticed you talking about a corner unit and some other projects I'm dying to see, lol.
Goodnight.
Aug 3, 2011. 1:28 PMurbanalbino says:
I made this today! Thank you for posting such awesome directions. I have never assembled anything this 'detailed' before. I had the help of tool identification and uses from my dad and an exceptionally smart 7 year old cousin. I haven't put my mattress on it yet, but I've got a feeling its going =)to be postiively splendiferous.
By the way --- using a saw leaves you with a very strange satisfying feeling!! =)
Aug 12, 2011. 7:20 PMBuildAFence says:
Just so ya'll know, if you use an impact screwdriver and not a drill driver the phillips head screws go straight in. I was using a drill with a bit to run 4 inch screws into the studs of a wall and when the drill gets loose and jumps the track while your still pressing in it just eats the screw head. Not so with impact driver. I have never had the impact driver jump out the track of a phillips head screw, even once its all the way in it'll keep driving. Impact drivers are awesome!! I have a Ridgid at home and the new little 12V Dewalt for work.
Aug 12, 2011. 8:56 PMBuildAFence says:
By the way here is my twin version. It is kinda high for my liking and for kids to climb onto so I think I am going to chop the legs in half. It was nice to put those kids jumpers and walkers under there for a while.
Feb 1, 2012. 7:51 PMdevells says:
Just built this frame for the second time in a year. Thanks so much for the plans! I built it in Boston a year ago, then just moved to DC, and instead of moving it with me, since I had limited space, I decided just to build it again when I got here. It's cheaper than a cheap Ikea frame, it's pretty much just as easy to put together, and I can feel proud of building it myself. Thanks!
Also, second time around I shortened the slats a little bit, as well as the legs - slats are 4'5" and legs are 1'7", so I was able to buy 6' 1x4s and have no waste for 8 slats and all 8 legs! And my storage bins still fit underneath! I appreciate your attention to waste, I probably wouldn't have given it as much thought as it deserves, being an ultra beginner at this stuff.
Feb 1, 2012. 7:53 PMdevells says:
Oh and with the old frame, my roommates repurposed it by taking the legs off, adding boards in the spaces, staining it, and using it as a small deck in a small Boston yard. Pretty cool!
Feb 8, 2012. 7:50 PMEven-O says:
Thanks for posting Devells! I'm looking to use the bed as a platform...has the deck been in place for a while? How is it doing?
1-40 of 527next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
156
Author:aeray(none yet)
Craftsman of fortune. Less is more, and simpler is better.
