3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
cheap mesh head snare drum- £15
quick cheap drum for your electronic kit costing only you only £15 to make
id like to point out the information for producing these drums is originally from www.edrums.info I'm simply showing my method of producing a cheaper drum that still works the same (only cheaper)
Step 1
First step is your parts.
Youl need:
- 1 tunable hand drum (any size you want) £9
- Window mesh £3
- 1/4 inch jack £2
- Peizo transducer £0.5
- various wire and a means of attachment to your kits frame
23 comments
Nov 12, 2009. 11:02 AMkevincowell says:
do the piezos pick up sound differeces from low to high? (accents)
Feb 10, 2010. 10:01 PMdoggyd69b says:
It also depends on the module, the DM5 (one of the cheaper decent ones) can pick intensity which translates on volume but also on slightly different pitch when hitting harder...
http://www.youtube.com/watch?v=khq-p4LoIi4
I will post more videos with the different sounds that I have programmed and maybe add some other instruments, it gets a little more involved but it's still not too expensive to accomplish.
Aug 10, 2009. 12:56 PMsamzaxe says:
lol.....inshort... i m too poor to have any d5 device to be attached to homemade e-kit. thats why i m willing to break my keyboard .
Aug 10, 2009. 12:54 PMsamzaxe says:
hey there. dude i have read another tutorial in making a home made edrumkit. the guy used aluminium foil as an extended switch of keyboard(computer's keyboard) and when any of the piece of drum is hit it completes the circuit and the sound is generated from computer......i wana ask that is it posible tht we use peizo transducer as a switch attach it to the specific key of the keyboard and when the relative cymbal or part of drum is hit with stick the sound is generated from any keyboard operated software like EZ drummer.,. please reply.......
Jun 24, 2009. 12:24 PMMARIOSCLONE says:
I just ordered the stuff to make a whole kit out of these using a DM5 drum module
Jul 5, 2009. 5:15 PMMARIOSCLONE says:
I've also made cymbals out of an old album of records, by heating them up while rotating them over the stove and pressing the on a real cymbal to create the shape and some rubber and a sensor your done.
Jul 5, 2009. 5:12 PMMARIOSCLONE says:
I've got mesh heads on 4 10in handrums already and am still waiting for my 12in handrum to come in the mail for the snare. I've also developed a much quicker way to make the mesh heads without sowing. Once you've cut off the original head lay your mesh under the rim and slide it on to the drum shell, flip the drum upside down, and then use hot glue to glue the mesh to the rim. Cut off the excess and tighten it your done. If some of the mesh is pulling thew strengthen it with more hot glue.
Jun 10, 2009. 4:47 PMBartboy says:
Hmmm .... could you clarify how this works as a drum?
Jun 10, 2009. 11:59 PMfrollard says:
its replacing the skin of an electronic drum with window screen.
Jun 11, 2009. 3:35 PMBartboy says:
I meant how it picks up the power of how hard you hit it, not what you do. The type of sensors....
Jun 12, 2009. 1:22 PMBartboy says:
So it's pressure? I have seen some electronic drum kits that use laser sensors.
Jul 4, 2009. 5:08 PMBartboy says:
No... a laser only costs about 2 $
Jul 5, 2009. 5:13 PMMARIOSCLONE says:
but the module to use the laser sensor is very expensive.
Jun 11, 2009. 4:51 PMfrollard says:
He modified an electronic drum - it already has the sensors in hit.
Jun 11, 2009. 7:33 PMcokebottle tuque says:
He did not modify an electric drum. He wired up a cheap peizo and a 1/4 inch jack, then placed a piece of foam between the peizo and the drum skin. go re-read step 3.
Jun 12, 2009. 2:14 AMfrollard says:
I stand corrected!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:allix69
