Cheap Motor-operated Screw Driver
820
10
Published
Introduction: Cheap Motor-operated Screw Driver
A cheap motor operated cordless screw driver set.
Things required
  1. Geared motor 30RPM-60RPM
  2. Screw Driver set
  3. 9Volts Battery
  4. cables
  5. Soldering gun
  6. glue gun
  7. Pin to arrest the slip between motor and screwdriver
  8. 9V Battery terminals
Step 1: Rework on the Screw Driver
On the gripping side drill a hole to insert the motor shaft. I did not have a drilling machine therefore i used soldering gun to remove the material.
Insert the motor output shaft to the screwdriver hole and arrest the rotation using a pin
glue the battery to the motor and connect to the motor
i used bare terminals to reverse the polarity, you might want to use a DPDT switch to make it handy.
Step 2: Working of the Screwdriver Gun
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    2 Comments
