Cheap Power Supply for Projects (20v)
1,031
13
4
Posted
Introduction: Cheap Power Supply for Projects (20v)
This is a cheap and easy power supply that can be used for many things.
Step 1: Materials
1. laptop power supply (old)
2. hot glue
3. electrical tape
4. wire cutters(optional)
5. 3 nails
6. voltmeter
7. scissors
8. small cardboard box
no soldering required
Step 2:
cut end off the cable that plugs into your laptop, make sure its not plugged in
Step 3: Strip Wires
you will find 3 layers of isolation and 3 wires, strip the isolation off of the wires. The smallest wire in the middle is usually the ground.
Step 4:
Add the nails onto the wires. Fold the wires together hold the wires and twist it together then wrap the wires with electrical tape.
Step 5:
Push the nails into the box and make sure the ground nail is in the center. Then glue or tape the nails onto the box.
Step 6:
Test for shorts if there is a short when you plug the power supply in the the Power supply will automatically turn off.
Step 7:
If all is working then wrap the excess wire around the power supply around it and then glue the power supply into the box. *(not the cable that connects to the wall)*
Step 8:
close off the box and find out the polarity of the power supply then label it. your now done. a laptop power supply will automatically shut off if there is a short so your safe if it shorts. you can connect alligator clips and paperclips easily to the nails. this is really cheap, if you already have a laptop power supply then it would be even cheaper. total cost is under $15 and that includes a 95w psu. any laptop psu should work.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    4 Comments
    The word "dangerous" comes to mind.
    the power supply will automatically shut down if there is a short. it shouldnt be very dangerous
    I love re-using all sorts of old power adaptors. Anytime anyone is throwing one away, I always snag it. You never know when they will come in handy!
    yeah they come in quite handy a USB charger can be used for a low voltage and current application like electroplating
