it blew up (the rectivier)
and i dont want to repair it
the lm317 still works
i need the powersupply for my plasma speaker
i need 24 V
Well it is so cheap that if you are handy (like me), it only will set you back 3 or 4 dollars for a nice case.
With a well stocked junk drawer, you could even make it for free.
Would you like to see what it is? It is a low voltage, variable power supply.
V1 = from 1.5 to13 volts positive output
V2 = from 2 to 35 volts positive output
WARNING:
With Version 1 you cannot use the higher output because the fan can only hande 12 volts.
You can modify it to handle the higher voltage, but I suggest you build Version 2 instead.
Version 2 starts in step 5.
Remove these ads by
Signing UpStep 1Bill of Material
Parts List:
1 - LM317 (Texas Instruments has the smd in the free sample program, the same one I used.)
1 - 10K ohm variable resistor (potentiometer) (pot)
1 - diode bridge (rectifier) or 4 fast diodes . Watch the polarity! Follow the schematic exactly.
1 - electrolytic capacitor 63V, 100-300uF (it doesn't matter.) ( Watch the polarity.)
1 - small heatsink for the LM317
1 - small PC fan (12V)
1 - small piece of circuit board
2 - connectors (so you can screw your wires instead of alligator clipping them)
1 - transformer (I used one that has 3 wires and 2 outputs, 13.5V and 27V)
Note: In order to use the full power, use a transformer that can handle at least 1A because the LM317 can deliver up to 1.5A.
1 - box
1 - line cord with plug
Various lengths of wire
Optional:
1 - voltage display (mine is from an old radio control (rc) transmitter)
adj.-out resistance should be at least 220 ohms so if you put your pot all the way up it will short adj.-out (0 ohms) not realy good for the lm317
but mine still works
i did blow it when i powered a flyback transformer
so the next version has some sort of protection
mine has a thermal fuse build in
the label shows that it can take 135 degre's celcius
i will coorrect connector
i am corecting a lot on my grammas mistakes latly
so i can be be understandeble for others.
but it will never be the best
What I was thinking was to download your I*, make some corrections, then send it back to you to post. I don't want any credit. I just think you have a good I* and it needs to be understand. Or, I could just send you the corrections to make on your own. My email: mathman at comcast dot net. Understand how to make this into an address? I'm doing it this way so the bots don't have such an easy chance. Glad to help.
if i am correct you can now edit it
if not you will get it via e-mail
Good thinking :)
