3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
christmas tree door hanger
This is a step by step guide that will show you how to make a Christmas Tree that will hang from almost any door and can be decorated in endless ways.  If you're tired of a traditional wreath or just want something more substantive, this is it.
Step 1Gather your supplies and tools
gather your supplies and tools
The amount of some of your supplies will vary depending upon how big you make your tree.  I will list quantities of some of these for the tree I built in the pictures.
supplies:
3 x 9 foot bundles of branching, bendable garland...  the kind with short 3-4 inch branches.
1 x 18 foot piece of straight, plain "tinsel garland".  I used about 10-12 feet.  It needs to have the  same color as the branching garland so it will match.
1 x wreath hanger (this will be partially visible) I used black to be less noticable.
1 x roll of wide masking tape.
1 x spool of 24 gauge green floral wire
1 x pack or spool of 18 gauge floral wire
1 x piece of foam core board or heavy cardboard (a 1 foot x 3 feet piece should be sufficient)
tools:
wire cutters or needle-nose pliers with cutters.
a knife (xacto, utility, etc. - something sharp for the foam core)
optional tools:
pliers
tin-snips
I really recommend eye protection while working with this fine wire.  Throughout the project it will be sticking out in the air at eye level.  24 guage wire is not good for your eyeball.  Also if you are not experienced and comfortable working with fine wire, you may want to wear gloves or you'll end up with bleeding fingertips.
You also need a door.
6 comments
Aug 30, 2010. 3:38 PMkandikane says:
this is a great idea for if you live in a small flat etc and cant fit a full xmas tree.
Sep 1, 2010. 2:07 PMkandikane says:
was this expensive to make or roughly the same as buying an artificial tree?
Dec 10, 2009. 6:25 PMChrysN says:
Neat idea, it looks great!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kaylorRN
