3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
switching circuit
switching circuit
In this Instructable (my first) I have posted the circuit design that I am currently fiddling with for its eventual use in my coilgun. When it is finished it will serve as the activation switch for a second coil. Like I said; I am still modifying the circuit and I'm currently looking for a bit of advice, so any ideas would be helpful.
Continue on to the next page for a few more details.
Step 1The Parts
Of course with any electronics project you have to have a parts list. Here it is so far.
3904NPN Transistor
3906PNP Transistor
Diode (not needed)
LDR (Highest Ohm rating I could find @ radioshack)
3-16V Buzzer
The buzzer is on the circuit in place of the relay that will eventually be used to short out my capacitor bank.
15 comments
Jan 21, 2009. 1:24 PMadmin says:
This project looks awesome but there isn't enough documentation of you actually making it to be a full Instructable. There are two things which you could do. 1) If you happen to have images of you making your project you can create some more steps, add those additional photos into your Instructable and then republish your Instructable. 2) If you don't have any more pictures of you working on your project, that's ok too. That just means that your project is better suited to be submitted as a slideshow. Your images are already in your library, and you can use the same text that you have already written for your Instructable so it should only take a few minutes to create your slideshow and show the world what you made! Thanks for your submission and let me know if you have any questions along the way.
Jan 26, 2009. 12:29 PMrandofo says:
Oct 14, 2009. 6:44 PMtheblindferrengi says:
cany tou just wire the relay in so the turning off [of the relaycoil] will close the circut,
Jul 4, 2009. 5:07 PMQuestioneverything13 says:
Forget about using an LDR they are to slow use a photo transistor.
Mar 30, 2009. 9:30 PMd-lite says:
The first thing you should do is learn about photo-transistors. The LDR is totally unsuitable for anything that requires precision, and, a rail gun needs milli-second timing at the very least! For the same reason, forget about SCRs - use MOSFETs instead!
Apr 12, 2009. 8:18 PMWesley666 says:
He's right. Probably a better choice would be IR transmitter and receiver or laser and a different LDR. The problem with the circuit is that it turns ON when it should not and OFF when it should not if I am correct. To correct this, first, is voltage in + or -. Then what you need to do is have the amplifying transistor, PNP, base connected to LDR output, collector to - (NEGATIVE) ground and the emitter to the base of the NPN transistor. Connect the emitter (EMITTER!) to - (NEGATIVE) Ground and the collector to buzzer or relay. Of course make sure the buzzer/relay output is connected to + (POSITIVE) and the LDR input to - (NEGATIVE) Ground. This should work but it is hard to think about, easier if it is written down. When actually using this for the coil or rail gun, definitely go for MOSFET (Check to make sure they will work BEFORE buying/E mail company to get info) and definitely use either a more precise LDR and Laser or IR Transmitter and Detector. Hope this helps.
Jun 11, 2009. 2:30 PMMacDynamo says:
I probably sound noobish to most hobbyists, but for my own and other viewers benefits, what's an LDR? The schematic almost makes it look like a photosensitive cell for detecting light and dark.
Mar 5, 2009. 4:39 AMMuscelz says:
and what the buzzer for?
Apr 12, 2009. 8:22 PMWesley666 says:
Relay
Mar 5, 2009. 4:38 AMMuscelz says:
aye mate, that aint a coil gun circuit. delete the Instructable ur making urself look stupid lol. buy urself a SCR, they're pretty cheap, and stop trying to reinvent them, because no NPN or PNP setup would be able to cope with hundreds of amps
Apr 12, 2009. 8:21 PMWesley666 says:
Also I doubt he is using hundreds of amps to power this. He is probably using just a nine volt battery to power external circuits for the gun.
Apr 12, 2009. 8:20 PMWesley666 says:
you can get transistors that will, but they are mighty expensive. I have some that handle 100 amps at 600 volts, but they are also beasts.
Mar 9, 2009. 12:28 AMMuscelz says:
oh! well ur reason is understandable, soz about sayin dat b4 :), kool as
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:sabre
Student @ University of North Texas working towards a Mechanical and Energy Engineering Major. I do all kinds of fun little projects. I'm currently trying to scavenge old pictures so I can publish a f...
more »
