3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
coin slot detector
Step 3Program in Arduino 0012
open up Arduino 0012 on your computer. copy and paste the following code into your program window...then press the Verify button to make sure it works. Finally, click the Upload to Board button, to upload it to the Arduino to run. Once the program is uploaded, click the Serial Monitor button to see the values changing as you cover and uncover the photoresistor. When the values go above 500, the vibrating motor will vibrate!
/*Coin Slot Detector
by Amy Khoshbin
2008*/
int photoPin = 0; // Analog input pin that the photo resistor is attached to
int photoValue = 0; // value read from the photoresistor
int vibPin = 9;
boolean isVibrating = false;
void setup() {
// initialize serial communications at 9600 bps:
Serial.begin(9600);
pinMode(vibPin, OUTPUT);
void loop() {
photoValue = analogRead(photoPin); // read the pot value
Serial.println(photoValue); // print the pot value back to the debugger pane
vibrate();
delay(10); // wait 10 milliseconds before the next loop
void vibrate(){
//change the values greater than and less than to fit the sensitivity of the photoresistors you use
if(photoValue > 500 && isVibrating == false){
digitalWrite(vibPin, HIGH);
isVibrating = true;
if(photoValue < 500 && isVibrating == true) {
digitalWrite(vibPin, LOW);
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:semiotech(Amy Khoshbin)
Amy Khoshbin is an Iranian-American artist based in Brooklyn. She creates hybrids between performance, video and installation art, music, and interactive media to explore the subjects of perception an...
more »
