I've seen a few compost bin designs online and took a little from each one and came up with this.
you can take yard clipping ,leaves and kitchen scraps. any organic material will work ,just never put meat in a compost bin. when its done cooking you have nutrient rich soil that you can use for all kinds of gardening applications
Step 1: Materials
3 2x4 x 8 pressure treated
1 galvinized chain link fence post
4 3.5inch 1/4 bolts with washers and nuts
6 or 8 6" 60d nails
one 55 gal barrel (must be food grade)
4 latches
one piano hinge
one box of 10-32 3/4" nuts and bolts ( make sure they fit your hinges and latches)
paint if you want . I use barn paint from tractor supply co . its cheap and it doesn't require primer!
now I bought most of my materials but you can use what ever you have on hand also. the whole project only cost me 50 dollars so its not that expensive any way
Step 2: Assembly
first cut 2x4s in half
take 2 2x4s measure and make a mark half way down both of them . then center them and bolt ( you can use nails but bolts work better) them together.
repeat for other side.
you should have two giant X's
it doesn't matter which way they go,so pick one side as the bottom measure up 3 inches from each foot for the bottom braces.
now attach your other 2 boards with nails or screw them together.
your frame is now done and you can start to work on the barrel.
you can cut your bottom braces a few inches longer than the barrel for a better fit but you don't have to .
Step 4: The lid
this is the most difficult part of the whole project take your time to cut , drill and line everything up.
I use 4 latches because the heat from the compost can warp the lid and the plastic is somewhat flexible anyway. the piano hinge adds stability also.
start by marking the door out. I used a carpenters pencils , its a little hard to mark mark on the plastic.
then drill 4 1/4" holes in the corners.
cut out door with a jig saw . i made mine big enough for my shovel the fit in just use good judgement and dont make it to big or small.
first drill and bolt the hinge to the barrels first.
now drill and bolt the lid on . drill two holes and bolt them together first just on case they don't line up. the drill bit will try to slip on the plastic so start your drill slowly.
make a handle out of what ever , a simple finger hole would work.
now drill and attach the bolt side of the latch first then slid bolt open and use it to line up bolt reciever. close each bolt when you go to install the next one so the stay lined up. take your time aand it should be ok
Step 5: Ventilation holes
on the opposite side of barrel from the lid mark off 4 evenly spaced 1/4 holes across the barrel.then measure 6 inches down from each hole till you all gone all the way around. just make sure it has some ventilation. this would be a minimal amount .
now randomly drill some hole for the spikes . drill a hole a little small than the spike and just nail them in. these help brake up the material when you rotate the barrel speeding up the composting.
you should use 4 to 8 spikes what ever works best . you can always pull them out.
Step 6: Add compost!!!!
the only other thing you could do is paint it black . they make paint that will stick to plastic. I live in south Florida so thats really not necessary but if you live in northern climates you might need to find a good sunny spot and place it there! the advantages of this barrel composer are quite a few. its quick, cheap and effective. no bugs or rats, almost no odor. you can use it in a very small yard and not bother the neighbors.
I square foot garden ( mel is a genius ) and buying fertilizer and compost can add a lot of expense you don't need. I save a lot of money growing my own food and you would amazed how much food you can grow this way .good compost can double your harvest!
1-40 of 114Next »
edx111 says: Mar 19, 2013. 8:33 PM
what I used to do is make a pile with alternate layers of grass and cow manure, with a little wood ashes thrown in alternative layers and a little water over the finished pile. After 3 days I turn it inside out and then repeat every 2 days after that. The finished compost is ready in 3 weeks flat
mel53 says: Mar 19, 2013. 8:12 PM
Great queations I would like to know the answers to them also.
welder tig says: Mar 19, 2013. 2:27 AM
i have built one of these for a food company for mixing dry ingredients , instead of the shaft being straight off set it one dia of the shaft , one end will be high and the other will be low . this will toss the scraps from one end to the other . or if you want a straight composter using a steel shaft weld a bar to each end , drill a hole and put a bolt thru it so the barrel will not slip on the shaft
clevernonsense says: Mar 13, 2013. 3:50 AM
you absolutely can compost meat scraps, we've been doing it for years. just make sure it's in smaller bits and mix it with a lot of browns
GrowNatural says: Jan 10, 2013. 1:42 PM
forgive me if this has been addressed previously,
I am confused on how the barrel is secured to the pipe?
It would seem to me that the barrel rotates on the pipe,
how would one make it so the barrel and pipe are one?
therefore one can install a turn handle.
strumok says: Jan 8, 2013. 7:46 AM
Inspired by this design, it keeps a pretty even temp even in winter. It does leak a little, but no big deal, and it's nice to put the coffee grounds somewhere useful besides the trash. Started this one with leaves, then added other stuff, mostly egg shells, coffee, fruit and vegetables. Occasionally tea bags. It's fun!
coxj2000 says: Jul 29, 2012. 8:15 PM
A: My mom and I are in a dispute. She is an environmental biologist, and says just piling the organic matter and spraying it with water will produce compost within a month to two months. I think that an enclosed bin with vents will work more quickly. She pitches vegtable scraps in her garden or put them in a pile with horse or rabbit leavings, and I collect them along with horse and rabbit leavings and mix them with a 1-3 nitrogen rich to organic inert matter (leaves, paper, twigs [twigs rot slowly] etc.,) then spritz every day and churn every several days. There does seem to be a hype with rotating bins. Any second opinion from others who have tried both?
B: I use an old plastic white printer box from the days printers were giant turned on its side. It had four wheels, but two broke off. This is working, but do you think I should paint it black? Not much visible light can get through. I think it is 1/8 to 3/16 inches thick, but I am not sure of its composition? I think the white is good on the inside but not out. Help, please?
gardenlvr says: Mar 5, 2012. 4:14 PM
I have been looking into making one of these myself. I am trying to decide if I want to use roller or your design? One concern is the pipe in the middle, when the barrel gets heavy will it elongate the holes? Or should I reinforce the ends with plywood bolted onto it and the hole through that and the barrel? Other wise this design is very portable :0)
rhodge-1 in reply to gardenlvrApr 26, 2012. 3:24 PM
Add aluminum plates to the ends with the holes drilled for the pipe. after side door is cut; add a plate inside and then Pop Rivet them or use plated bolts to sandwich them with the plastic.
Use the drive gear for a bicycle pedal gear and the driven gear at the wheels; or the equivalent- Like those maybe on a small motorcycle perhaps?
Use the pedal shaft and ad a handle extension perhaps.
Change the foot pedal for a hand grip.
rhodge-1 in reply to rhodge-1Apr 26, 2012. 3:32 PM
Make the hand grip with a free moving grip; not fixed to the shaft as that would be hard to turn it.
moreforles says: Dec 19, 2008. 8:47 PM
just wondering if 3" pvc tubing would be strong enough to use in place of the post, if say filled with the right stuff foam......? I only ask because I happen to have it on hand, along with an old wooden swing/club house for the wooden frame and a blue barrel just like the one pictured. and a second blue barrel should be available shortly, so I can make one for my father in law too... maybe his first (for practice) then mine...
jblanton1 in reply to moreforlesNov 13, 2011. 1:50 PM
I used 2" sched-40 PVC as rollers when I was moving my 1600 lb (empty) gun safe to my new house. Usually had 4 pieces under the safe at any one point in time and the weight is distributed across the entire length of the 2" roller instead of just along 2 points like you would have in this project. Still, it seems pretty strong...
ajensen bjorgaard in reply to moreforlesAug 21, 2011. 12:22 PM
did you use the pvc? did it work?
DogTubs says: Oct 4, 2011. 3:53 PM
Great plan! I built a couple, but now wondering if it the best way to compost because it dries out so fast. Any ideas on keeping the compost moist?
crzyuilter says: Sep 11, 2011. 5:19 PM
I've been filling my bin for a couple of months now. Pretty heavy to turn, but doable. How full do I fill it? When is a good time to stop adding to it and just let it decompose so it can be emptied and started again? Thanks!
yuemei87 says: Sep 5, 2011. 2:16 AM
This design is working splendidly in my backyard in the tropics. Our house puppy used to always eat the food out of the compost corner but this is no longer a problem. I added a few extra venhilation/drainage holes to ours because its monsoon season now, but overall thank you for sharing!!!
One Question- How full do you usually keep it? Halfway?
crzyuilter says: Jul 26, 2011. 3:41 PM
We just finished our compost bin and are thrilled with the design. We did make it higher off the ground (hoping the wheelbarrow will fit under it for easy of moving of the compost). We used one of the comments about drilling all the hinge and latch holes before cutting out the door, and it worked like a dream. That was probably the easiest part of the project. I used a Sharpie marker and drew a door using a magazine (flexible, but with straight edges) as a template. Note: After marking the top, bottom and one side I slide the magazine over before marking the last side so it would be wider. We then taped the piano hinge and all the bolt fasteners on with masking tape straddling the Sharpie line. Drilled all the holes, removed the hardware and cut out our door. It was easy to attach all the pieces to the door then put it on the barrel at the piano hinge side. All lined up perfectly, tightened, and on to setting it in the garden. We will load it with compost I've been collecting in a cardboard box and see what happens. It looks great. Thanks for the great project help.
wridgeway says: Jun 19, 2011. 7:26 PM
i built 2 sets of the A-frames, used white pvc (2' i.d.) for the end barrels, and a piece of grey conduit (2" o.d.) to slip in between the 2 end barrels, adding a third barrel in the middle. 2 end barrels are blue, center one black.(gets somewhat hotter).I drilled some 1 1/4 holes about 2 inches from the end of each barrel and turn them with 2 pieces of 1" pipe 24" long. stick the pipe in a hole, catching the pvc and turn down, and grab the next hole with the other pipe, keep turning for a full revolution. my first batch will be done in 2 days, and i'm staggering the barrels so i'll get a batch every week. Also the 1 1'4 hole at the bottoms will drain off excess "tea" into a 5 gallon bucket-dilute 1:1 with water.
merlehanna says: May 14, 2011. 1:19 PM
Inspired by your Instructable...Thanks again!!!
STF says: Aug 28, 2008. 7:14 AM
Here's one I built. I had some old 4x4's lying around so I thought I would use them. The one picture is what I drew up in Inventor. I guess stacking it is endless if you have a ladder :) Instructable to come with dimensions.
STF in reply to STFAug 28, 2008. 7:41 AM
Here are the pics:
merlehanna in reply to STFMay 14, 2011. 4:08 AM
very nice!
SpinWard says: Sep 6, 2008. 9:05 AM
Here's the one I built. Great instructable! I used 2 hinges instead of one piano, I couldn't find a good one. Instead of the big spikes, I used a bunch of wood screws that we had and haven't used.
2008_0906CompostBarrel0016.jpg2008_0906CompostBarrel0014.jpg2008_0906CompostBarrel0017.jpg
merlehanna in reply to SpinWardMay 14, 2011. 4:08 AM
Fantastic adaptations made in your version.......
merlehanna says: May 14, 2011. 4:06 AM
Great instructable! My son and I hope to make this into a father and son project today...Thank you very much for sharing :)
miguel64 says: May 6, 2011. 9:04 AM
Does it leak or drip? I want to make and put mine on a tiled urban terrace and I wouldn't like to dirt it...
The post is great. Thanks!
Pizzapie500 says: Nov 2, 2010. 4:26 PM
Can you put fins onto the barrel so that if it's windy the fins will catch the wind and spin the barrel? Like a turbine? Also would this work in the winter?
BucketBasher in reply to Pizzapie500Apr 12, 2011. 7:47 PM
What if we were to take that idea a step further? Adding a generator to one side of the rod so that when the fins spin the barrel, it generates electricity too!
lee_schnitz says: Mar 20, 2011. 4:21 PM
Great instructable... We built ours this weekend.
Kindlekat says: Oct 21, 2010. 11:44 AM
Loved this instructable! Built it this past weekend.
65928_517881974734_152300249_30622798_3409437_n.jpg72789_517881954774_152300249_30622797_3203022_n.jpg
crismel says: Sep 20, 2010. 7:19 PM
i need some files about how to make a roatary drum composter or methodology in building a rotary drum composter. please send me some files about soon as possible. i hope somebody can help me
hav2sing says: Jul 11, 2010. 7:52 PM
Reading all the comments on how to acquire the barrels... cut them in half and have a circular container garden.... another way to recycle the barrels. Love the article, and am hopeful we'll have a compost bin by mid-autumn. And in Arizona, no worries with the heating ;-)
Napole says: Jul 11, 2010. 7:47 AM
Great instructables. Needs a turning wheel/handle on one end and a handle on the lid :-)
steveF5 says: May 27, 2010. 1:01 PM
i made one of these, and it works great... i first stocked it with a bunch of newspaper and paper shreddings from a cross cut shredder, and mixed in some dirt that was from a pile of leaves from the fall. i read a page on compost and it was talking about the N P K levels, and if you have alot of fibrous brown (paper/dead leaves etc) material, you need to add something high in nitrogen, such as bloodmeal. i added some of this, and then the rest of the scraps, and it produces alot of heat  and has worms living in it.
Great instructable
pinoymale says: Oct 3, 2009. 4:11 AM
I'll be trying to make my first compost bin. Will it still work if I don't add worms?
Sketchabit in reply to pinoymaleMay 26, 2010. 5:47 AM
No, leave the worms out of it.  Composting creates heat and could kill them.  Best bet is to make the compost in the barrel until it's well broken down and then have a second place in your yard to let it finish composting, let the worms at it there.  We did that and things like orange peels that take longer to break down are great worm food.
SteveSch says: Apr 22, 2010. 6:30 PM
 I just finished up one of these. I have one question, Would it be beneficial to paint it black and if so what paint do you recommend?
hollylynh says: Jan 22, 2010. 11:23 AM
I called around to local food company's to find a barrel. I ended up getting one for $8 from a molasses company, it had a little of the sweet stuff in the bottom, but I kept it in to get my compost started off.
ewah says: Jan 8, 2010. 4:39 PM
I tried to build a compost bin using bamboo fence.  Just fold the fence and use copper wire to clip them together so it looked like a tube with both end open.  I stick to the ground in the backyard and put compost in.  Of course, it didn't last and it a pain to stick the pitchfork in to mix the compost.  I tried using an auger to mix the compost but it was a lot of work.  Also, my bamboo fence compost bin eventually deteriorated.  After that, I told myself hell with it and bought a NatureMill compost bins.  It’s fully automatic, no mixing, no turning, no mess, no more rats and raccoons in my backyard and it produce great compost.  Wish I have done it sooner.
firecraker222 says: Apr 7, 2009. 9:05 PM
hey great idea very simple stant and every thing, man great idea , hey should i still paint it black if i live in CA
1-40 of 114Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
