3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
compost bin
compost bin
I've seen a few compost bin designs online and took a little from each one and came up with this.
you can take yard clipping ,leaves and kitchen scraps. any organic material will work ,just never put meat in a compost bin. when its done cooking you have nutrient rich soil that you can use for all kinds of gardening applications
Step 1Materials
3 2x4 x 8 pressure treated
1 galvinized chain link fence post
4 3.5inch 1/4 bolts with washers and nuts
6 or 8 6" 60d nails
one 55 gal barrel (must be food grade)
4 latches
one piano hinge
one box of 10-32 3/4" nuts and bolts ( make sure they fit your hinges and latches)
paint if you want . I use barn paint from tractor supply co . its cheap and it doesn't require primer!
now I bought most of my materials but you can use what ever you have on hand also. the whole project only cost me 50 dollars so its not that expensive any way
106 comments
1-40 of 106next »
Mar 5, 2012. 4:14 PMgardenlvr says:
I have been looking into making one of these myself. I am trying to decide if I want to use roller or your design? One concern is the pipe in the middle, when the barrel gets heavy will it elongate the holes? Or should I reinforce the ends with plywood bolted onto it and the hole through that and the barrel? Other wise this design is very portable :0)
Apr 26, 2012. 3:24 PMrhodge-1 says:
Add aluminum plates to the ends with the holes drilled for the pipe. after side door is cut; add a plate inside and then Pop Rivet them or use plated bolts to sandwich them with the plastic.
Use the drive gear for a bicycle pedal gear and the driven gear at the wheels; or the equivalent- Like those maybe on a small motorcycle perhaps?
Use the pedal shaft and ad a handle extension perhaps.
Change the foot pedal for a hand grip.
Apr 26, 2012. 3:32 PMrhodge-1 says:
Make the hand grip with a free moving grip; not fixed to the shaft as that would be hard to turn it.
Dec 19, 2008. 8:47 PMmoreforles says:
just wondering if 3" pvc tubing would be strong enough to use in place of the post, if say filled with the right stuff foam......? I only ask because I happen to have it on hand, along with an old wooden swing/club house for the wooden frame and a blue barrel just like the one pictured. and a second blue barrel should be available shortly, so I can make one for my father in law too... maybe his first (for practice) then mine...
Nov 13, 2011. 1:50 PMjblanton1 says:
I used 2" sched-40 PVC as rollers when I was moving my 1600 lb (empty) gun safe to my new house. Usually had 4 pieces under the safe at any one point in time and the weight is distributed across the entire length of the 2" roller instead of just along 2 points like you would have in this project. Still, it seems pretty strong...
Aug 21, 2011. 12:22 PMajensen bjorgaard says:
did you use the pvc? did it work?
Oct 4, 2011. 3:53 PMDogTubs says:
Great plan! I built a couple, but now wondering if it the best way to compost because it dries out so fast. Any ideas on keeping the compost moist?
Sep 11, 2011. 5:19 PMcrzyuilter says:
I've been filling my bin for a couple of months now. Pretty heavy to turn, but doable. How full do I fill it? When is a good time to stop adding to it and just let it decompose so it can be emptied and started again? Thanks!
Sep 5, 2011. 2:16 AMyuemei87 says:
This design is working splendidly in my backyard in the tropics. Our house puppy used to always eat the food out of the compost corner but this is no longer a problem. I added a few extra venhilation/drainage holes to ours because its monsoon season now, but overall thank you for sharing!!!
One Question- How full do you usually keep it? Halfway?
Jul 26, 2011. 3:41 PMcrzyuilter says:
We just finished our compost bin and are thrilled with the design. We did make it higher off the ground (hoping the wheelbarrow will fit under it for easy of moving of the compost). We used one of the comments about drilling all the hinge and latch holes before cutting out the door, and it worked like a dream. That was probably the easiest part of the project. I used a Sharpie marker and drew a door using a magazine (flexible, but with straight edges) as a template. Note: After marking the top, bottom and one side I slide the magazine over before marking the last side so it would be wider. We then taped the piano hinge and all the bolt fasteners on with masking tape straddling the Sharpie line. Drilled all the holes, removed the hardware and cut out our door. It was easy to attach all the pieces to the door then put it on the barrel at the piano hinge side. All lined up perfectly, tightened, and on to setting it in the garden. We will load it with compost I've been collecting in a cardboard box and see what happens. It looks great. Thanks for the great project help.
Jun 19, 2011. 7:26 PMwridgeway says:
i built 2 sets of the A-frames, used white pvc (2' i.d.) for the end barrels, and a piece of grey conduit (2" o.d.) to slip in between the 2 end barrels, adding a third barrel in the middle. 2 end barrels are blue, center one black.(gets somewhat hotter).I drilled some 1 1/4 holes about 2 inches from the end of each barrel and turn them with 2 pieces of 1" pipe 24" long. stick the pipe in a hole, catching the pvc and turn down, and grab the next hole with the other pipe, keep turning for a full revolution. my first batch will be done in 2 days, and i'm staggering the barrels so i'll get a batch every week. Also the 1 1'4 hole at the bottoms will drain off excess "tea" into a 5 gallon bucket-dilute 1:1 with water.
May 14, 2011. 1:19 PMmerlehanna says:
Inspired by your Instructable...Thanks again!!!
Aug 28, 2008. 7:14 AMSTF says:
Here's one I built. I had some old 4x4's lying around so I thought I would use them. The one picture is what I drew up in Inventor. I guess stacking it is endless if you have a ladder :) Instructable to come with dimensions.
Aug 28, 2008. 7:41 AMSTF says:
Here are the pics:
May 14, 2011. 4:08 AMmerlehanna says:
very nice!
Sep 6, 2008. 9:05 AMSpinWard says:
Here's the one I built. Great instructable! I used 2 hinges instead of one piano, I couldn't find a good one. Instead of the big spikes, I used a bunch of wood screws that we had and haven't used.
Fantastic adaptations made in your version.......
May 14, 2011. 4:06 AMmerlehanna says:
Great instructable! My son and I hope to make this into a father and son project today...Thank you very much for sharing :)
May 6, 2011. 9:04 AMmiguel64 says:
Does it leak or drip? I want to make and put mine on a tiled urban terrace and I wouldn't like to dirt it...
The post is great. Thanks!
Nov 2, 2010. 4:26 PMPizzapie500 says:
Can you put fins onto the barrel so that if it's windy the fins will catch the wind and spin the barrel? Like a turbine? Also would this work in the winter?
Apr 12, 2011. 7:47 PMBucketBasher says:
What if we were to take that idea a step further? Adding a generator to one side of the rod so that when the fins spin the barrel, it generates electricity too!
Mar 20, 2011. 4:21 PMlee_schnitz says:
Great instructable... We built ours this weekend.
Oct 21, 2010. 11:44 AMKindlekat says:
Loved this instructable! Built it this past weekend.
Sep 20, 2010. 7:19 PMcrismel says:
i need some files about how to make a roatary drum composter or methodology in building a rotary drum composter. please send me some files about soon as possible. i hope somebody can help me
Jul 11, 2010. 7:52 PMhav2sing says:
Reading all the comments on how to acquire the barrels... cut them in half and have a circular container garden.... another way to recycle the barrels. Love the article, and am hopeful we'll have a compost bin by mid-autumn. And in Arizona, no worries with the heating ;-)
Jul 11, 2010. 7:47 AMNapole says:
Great instructables. Needs a turning wheel/handle on one end and a handle on the lid :-)
May 27, 2010. 1:01 PMsteveF5 says:
i made one of these, and it works great... i first stocked it with a bunch of newspaper and paper shreddings from a cross cut shredder, and mixed in some dirt that was from a pile of leaves from the fall. i read a page on compost and it was talking about the N P K levels, and if you have alot of fibrous brown (paper/dead leaves etc) material, you need to add something high in nitrogen, such as bloodmeal. i added some of this, and then the rest of the scraps, and it produces alot of heat  and has worms living in it.
Great instructable
Oct 3, 2009. 4:11 AMpinoymale says:
I'll be trying to make my first compost bin. Will it still work if I don't add worms?
May 26, 2010. 5:47 AMSketchabit says:
No, leave the worms out of it.  Composting creates heat and could kill them.  Best bet is to make the compost in the barrel until it's well broken down and then have a second place in your yard to let it finish composting, let the worms at it there.  We did that and things like orange peels that take longer to break down are great worm food.
Apr 22, 2010. 6:30 PMSteveSch says:
 I just finished up one of these. I have one question, Would it be beneficial to paint it black and if so what paint do you recommend?
Jan 22, 2010. 11:23 AMhollylynh says:
I called around to local food company's to find a barrel. I ended up getting one for $8 from a molasses company, it had a little of the sweet stuff in the bottom, but I kept it in to get my compost started off.
Jan 8, 2010. 4:39 PMewah says:
I tried to build a compost bin using bamboo fence.  Just fold the fence and use copper wire to clip them together so it looked like a tube with both end open.  I stick to the ground in the backyard and put compost in.  Of course, it didn't last and it a pain to stick the pitchfork in to mix the compost.  I tried using an auger to mix the compost but it was a lot of work.  Also, my bamboo fence compost bin eventually deteriorated.  After that, I told myself hell with it and bought a NatureMill compost bins.  It’s fully automatic, no mixing, no turning, no mess, no more rats and raccoons in my backyard and it produce great compost.  Wish I have done it sooner.
Apr 7, 2009. 9:05 PMfirecraker222 says:
hey great idea very simple stant and every thing, man great idea , hey should i still paint it black if i live in CA
Nov 24, 2009. 9:13 PMdanlab says:
The process decomposition occurring in the barrel will generate it's own heat. A black container will likely speed up the process some but likely not significantly. So it ultimately is up to you but I doubt it would be worth the additional work/up-keep.
Nov 24, 2009. 7:54 PMqman007 says:
using an aerosol spray can isn't good for the environment.  I would refrain from painting it all together.
Jun 10, 2010. 11:15 PMglenn.craver says:
Surely there are alternatives to spray though? I find it hard to believe paint meant to bond with plastics comes only in an aerosol... Hmmm, This is something worth checking out next time I'm at the home depot. Has to be something out there. If nothing else, perhaps just abrading the surface (coarse sandpaper maybe? Steel wool? Something that would scuff up a heavy plastic) so normal paint has something to bond onto?
Oct 28, 2009. 6:05 PMmarysescapades says:
where did you get the barrels?
Aug 22, 2009. 7:52 PMrsamtmann says:
Great project. I will be making at least one. What do you think about using rivets in place of the nuts and bolts? Do you think they will work and be strong enough? Thanks!
Jun 20, 2009. 1:46 PMJaxoat says:
I'm looking at making one of these and was wondering what is the purpose of the ventilation holes. If heat is what is need to "cook" the compost, I'd think the holes would not be wanted, Also, if one mounted a spigot, you could capture the "tea" that would otherwise drain out of the vent holes. Any insight?
Aug 21, 2009. 2:10 PMmeganscottage says:
If you don't make ventilation holes, the whole thing may become anaerobic and stink to high heaven... While there are a variety of microbes, critters, worms, etc at work the vast majority don't make the process stinky, unless the anaerobic (critters that live without oxygen) critters take over. This is also one of the reasons to turn a compost pile... Hope this helps!
1-40 of 106next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:ic517
