Introduction: Compost Tumbler
Picture of Compost Tumbler
this compost tumbler is portable it is also my first instructable
Step 1: Get a Barrel
Picture of Get a Barrel
find a barrel with a lid you can get one at freecycle.org
Step 2: Get Tools a Materials
Picture of Get Tools a Materials
Materials
- barrel
- plywood about the size of the barrel
- 3 sets of skateboard wheels
- 2 L brackets
- a handle
- 2 small blocks of wood bigger then the wheels
- peice of wood the weight of the barrel
Tools
- drill (an electric/corded drill works best for this job)
- 3/8" and 1" drill bits
- screws
Step 3: Drill Holes
Picture of Drill Holes
with you drill make hole thoughout the whole barrel
Step 4: Put Wheels On
Picture of Put Wheels On
drill on set of the wheels on bottom to one end
Step 5: Tumbler Wheels
Picture of Tumbler Wheels
With the other wheels put them in the middle of the plywood on the other side about a foot and a half apart
Step 6: Handle
Picture of Handle
put the handle on the same side that has the 2 sets of wheels but the other end of the wheels on bottom
Step 7: Back of Wood
Picture of Back of Wood
put the wood that is the height of the barrel on the same side as handle but other end
Step 8: Blocks of Wood
Picture of Blocks of Wood
put them on same side as the one set of wheels but to the other end and spread them apart
Step 9: Put Barrel On
Picture of Put Barrel On
now put the barrel on the wheels and you are done
Bubbler (author)2011-11-13
The one thing of upmost importance that I found missing was the loading door. To take the screw top lid off of the barrel would be way to awkward in muy opinion, and so I think the a carefully planned door by cutting out a section of the side, would be needed. Otherwise, this is a brilliant Instructable. I have kept away from making rolling composters, because of the idea of having an axle through the middle. I would also have a collector tray underneath bacuase the nutrients from that would be good for plants, or simply poured back through the composter. I agree, this is the best idea use of a skateboard yet. LOL
duhfuss (author)2010-02-02
I like the thoughts in your design; however, I think it may be difficult to execute when composting.  First, the oddly shaped barrel will most likely not stay balanced on a single pair of wheels as the compost shifts inside the barrel when turning.  A barrel shaped more like a complete column with two sets of wheels has always worked for me.  Second, I really like the idea of moving the compost to where it is needed, but bigger/stronger wheels will be needed  to roll over the lawn or garden paths.  I have made several compost tumblers with the external wheels like your design and I may add the movability design in my next construction.
pleabargain (author)2009-12-24
It would probably begin to leak smelly water as well through the air holes. An outside composter IMHO.
nlevan01 (author)2009-06-11
He meant on the opposite side as the wheels. When it is flipped back over those legs will keep the barrel from moving off the backstop.
.hacker (author)2009-06-08
good job cody/nick
dbinvt (author)2009-06-08
Great project, nice design. Could use some additional directions on use.
Z.. (author)2009-05-24
Just to add something positive.. As a first instructable, this is very good! I won't put one up because I'm old, ugly, and could not take being criticized after making such an effort.. Nice first try son.
Greenish Apple (author)2009-05-24
I tried this several years ago but with furniture casters/wheels, the offset type, at the four corners of the main body of the barrel. The plastic of the barrel was too soft for the weight of the compost and it couldn't rotate properly.
Similar to https://www.instructables.com/id/S1KOA71F8MM9QT4/ but with larger wheels.
MalKnowles (author)2009-05-24
this type of composter is ok, but you must add water to promote rotting, and plenty of air-holes to allow aerobic decay otherwise you get a wet, soggy mess of stinking stuff. High nitrogen vegetation like lawn mowings will rot better if the pH is raised by adding lime , don't waste money on expensive decay promoters. The plastic barrel should be rotated ccasionally.
uguy (author)2009-05-23
Your context is extremely confusing.
But, the absolutely best use of a skateboard I've ever seen!
brian_3339 (author)2009-05-23
huh??? makes no sense....
karossii (author)2009-05-23
punctuation seconded! also, you may wish to add a step or two on how to use this. i can easily see it is manually rotated tumbler, but there are those who don't know what compost is (or how it is made) much less how to use a tumbler. In the least, a link to another source for that information would be useful.
mrdepo96 (author)2009-05-23
good idea, but revise the punctuation and it would be much better. ;)
About This Instructable
28,540views
62favorites
License:
More by kingcusson:compost tumbler
Add instructable to:
