loading
Step 8: The Cooling Interface
note:i am coming up with a efficient cooling interface so hold tight. wire the battery pack to the fan through the switch. this creates a switch to turn the fan on/off. place the switch in an easy to reach place(preferably the floppy drive if you have one). freeze the ice pack and place in the sandwitch bag(helps to stop rusting of the dispenser). this blows cold air at the drinks. with insulation
use LN2 ( liquid nitrogen....)
Wow, I have the same PC case. (shame it's housing a server)
i take it you are running XP. STICK WITH IT, UNTIL WINDOWS 7 COMES OUT. viista is really slooooooooooow.
id stll stck with xp it the most stable
Vista is beast! XP sucks now for internet
really? for me vista is really fast
Im supposed to be constructive and positive but there is only one way to say this:<br /> LAME!!!!<br />
this is just a really really bad rip off of invent geek's PC case cooler
point taken, but I did not get it from invent geek, I had an old computer case, because the hard drive went stupid, and was looking for something to do with it. I have been trying to invent something, and came up with this.
Good instructable. My mom got a laptop so I got an old computer with parts from 2000! It is about to die so I needed Something to do with it. Great Idea.
i thought about that... not worth the tine, and it is not big enough :! and =(.<br/>
If you have a bunch of old heat sinks, you could use them as a more lasting cooling system. They'd keep the inside a few degrees cooler than the outside. Another possibility, would be have two or three different kinds of soda with a double hatch, and when you pull the soda release string it closes a hatch over the bottom one and opens a hatch beneath it. Okay, that's probably more trouble than it's worth...
Cool, how do you keep your soda cold?
IF you have the old fan,motherboard and power supply cables, lucky you. find the wires that connect the motherboard to the fan and unplug them. take or cut the socket out, and connect it to power supply cables of it's voltage.
or you could just get any type of fan (computer fan, regular fan, one of those portable air conditioners) and wire it up so the cable comes out where the computer's PSU cable used to come out. then put it in the bottom of the case under the ramp and put holes in the ramp (to help airflow) it would probably work better with a stronger ramp
i used very thick cardboard
the above comment doesn't work but it does keep it cool. to increase the effectiveness, insulate the dispenser.
I've seen a different form of this on invent geek which is cooled and insulated. But does need more modding to the case and costs more to make.
this is cool. I am going to have to try this with my old computer case. it would also be cool if you divided the case into 2 parts: the drink dispenser out of one the cd drives, and turn the other one into a tray that slides in and out. put a better cooling system in there and you have a freezer! or just leave it as-is and keep snacks in there.
dang i was thing this would have some sort of cooling a interface<br/><br/>well it cools real good<sup>even the lack of cooling</sup><br/><br/>oh and how many pops do you get in?5-10?<br/>
FIRSTLY,I'm working on the cooling interface, see "ikssk's" comment and my replies, and second,if you are willing to stack the cans, you should get about 15 in.
cool about the cans and you working on cooling and sry i didnt readed all the comments
It would be awesome if it refrigerated the drinks at the same time.
SEE COMMENT ABOVE
About This Instructable
10,269views
19favorites
License:
More by gutty:computer shell soda dispenser
Add instructable to:
