this is a lamp in concrete, glass, and steel.
this is a project for futurecraft (blog here)
Step 1: Stuff you'll need
You will need:
concrete (rockite works best). something to mix it in/with
something to make formwork. Plywood or melamine work well. Foam Core can also be used.
16" of 1 1/2" X 1/4" steel bar stock
3 pieces of glass: 1/4" thick: 12" X 4"; 1/8" thick: 12" X 3 1/2"; 1/16" thick: 12" X 3 1/2"
(you can cut these yourself, or easier yet have a glass store cut them. they need to be fairly precise.)
screws, drill, drill bits, driver
foamcore.
glue gun
ceramic lamp socket
4" threaded lamp post
light bulb (bright)
lamp cord
lamp switch
screw driver
space to make a mess
free time.
TnT101 says: Oct 15, 2008. 2:41 PM
Waaaay cool. I'd like to know what the weight difference is between that RockStuff and standard cement. Guess I'll find out soon enuff. Great work!!
Canoeman in reply to TnT101Oct 2, 2011. 9:53 AM
This could also be done with concrete backer board, and then troweled with grout, to eliminate mixing concrete. Then sanding grinding the outside smooth, to expose the glass.
I have built a few pony walls like that.
(pony wall = A short partition wall about 3 to 4 feet high.)
Canoeman
Sandisk1duo says: Dec 18, 2008. 7:50 PM
how much does it weigh?
SugargirlDesigns in reply to Sandisk1duoJan 10, 2009. 11:19 PM
I wonder if you could add the same materials to the concrete/cement mix that is used in making the lightweight "concrete" planters and such? Or, would make it not as heat/fire-proof, I wonder? Although, if the light source was a lower wattage, would that matter?
andybuda in reply to SugargirlDesignsApr 17, 2011. 8:21 AM
broken glass added to the mix maybe. if you left glass in a cement mixer with just the sand and let it run for a while it would take the sharp edges of the glass and give sand blasted effect to the glass. i dont know if adding water would help.
This is kind of a new technique used on concrete floors and some wall covering
where nails, screws, glass, and bits of well anything really is added, then ground flat to remove sharp bits using Carborundum Stones. mosaic of bits of crap
http://www.youtube.com/watch?v=ogVYwPcsnqY
Canoeman in reply to andybudaOct 2, 2011. 9:48 AM
I once made some concrete sheres with chunks and strips of aluminum and pewter in the mix. and ground the surface, exposing the aluminum, then polishing the outside, then polishing it again with bees wax, they were beautiful.
Canoeman
snowluck2345 says: Dec 2, 2010. 4:23 PM
Maybe to prevent alot of the light from being absorbed by the grey concrete you could paint the inside white. This would reflect alot of the light and allow more to come out the top, bottum and sides.
Canoeman in reply to snowluck2345Oct 2, 2011. 9:42 AM
Conrete dye is available from any builders supply, in just about any color you can imagine.
It can either be mixed in, or rubbed on soft curing concrete.
It comes in a powder form.
picbuck says: Oct 9, 2008. 9:03 AM
Looks great and very clever! Just to prove I have no life, I'll throw in the following: It's cement when it's in the bag, and also when it's in a liquid (or semi-liquid) state. It's only concrete after it's hardened. "Hardened" because cement does not "dry" by evaporating water. It hardens--into concrete--by a chemical reaction. OK, sorry to be such a stickler, back to the lamp. Lamp's cool!
SugargirlDesigns in reply to picbuckJan 10, 2009. 11:15 PM
Umm...not to be a jerk, but, that's not what I have been told. I was told that it's cement when it's dry, concrete when it's mixed with the other ingredients that make it concrete, and... My stepfather was a General Contractor, and I have other family that is in construction also... they've always said that you have to wait for concrete to "dry" and that is why it isn't good to lay concrete in wet or cold conditions. Hmm...
Canoeman in reply to SugargirlDesignsOct 2, 2011. 9:32 AM
I am a division of the state architects structural inspector, and was a general/electrical contractor for 30 years. Cement is a dry powdery ingredient, in concrete When it is mixed with sand, and aggregate (rock) it becomes concrete mix. When you add water, it becomes concrete Cement is made by heating limestone (calcium carbonate) with small quantities of other materials (such as clay) to 1450 °C in a kiln, in a process known as calcination, whereby a molecule of carbon dioxide is liberated from the calcium carbonate to form calcium oxide, or quicklime, which is then blended with the other materials that have been included in the mix. The resulting hard substance, called 'clinker', is then ground with a small amount of gypsum into a powder to make 'Ordinary Portland Cement', the most commonly used type of cement (often referred to as OPC). Portland cement is a basic ingredient of concrete, mortar and most non-speciality grout. The most common use for Portland cement is in the production of concrete. Concrete is a composite material consisting of aggregate (gravel and sand), cement, and water. As a construction material, concrete can be cast in almost any shape desired, and once hardened, can become a structural (load bearing) element. Portland cement may be grey or white. After pouring concrete, it is important to keep the concrete hydrated and above freezing temps. Hot weather will cause the outside of the concrete to begin curing faster then the inside, causing shrinkage cracks, As concrete cures, it produces heat as a chemical reaction. When looking for a smooth outer surface, use a vibrator to remove bubbles and consolidate the concrete. Keep it cool, and if possible cover it with plastic after the surface has cured long enough, so it will not leave plastic fold marks on the concrete. If you are making a lot of concrete objects, a fairly inexpensive cordless drill mounted vibrator that has a phallic shape can be dipped into the concrete to consolidate and remove exterior bubbles or what is referred to as rock pockets. Once you remove the forms, keep it covered for as long as you can to prevent cracking. Vibrators can be rented cheaply at tool supply centers Humidity is concretes friend, when curing. To add a nice touch, quartz, turquoise, minerals and fossils can be imbedded into the mold when pouring, then polished with a hand grinder when finished. The colors really stand out, after grinding, and coating it with a clear concrete sealer, to give that wet river rock look. Hope this info helped. Canoeman
wdanewood in reply to SugargirlDesignsMay 16, 2011. 2:23 AM
I live in England and when I worked for a leisure company installing patios and conservatories I regularly used to have to lay concrete in the wet or cold conditions; It does set, but it just takes longer, it sets through a reaction withthe lime in its mix.
and to help with the Concrete/ cememnt argument , the English Oxford dcitionary defines the following:
" Cement/ noun/ : a powdery substance made by calcining lime and clay, mixed with water to form mortar or mixed with sand, gravel, and water to make concrete. "
ballagie in reply to SugargirlDesignsMar 8, 2010. 9:59 AM
It is true that the concrete "cures" and doesn't just dry out. Also are you sure you heard them correctly? In northern Australia (where I am from), it is often too hot for the concrete to set evenly (causing cracks etc.). To combat this, most "pours" are done late in the afternoon when it is cooler, and then once the concrete has begun to set, its given a good spray with the garden hose. I honestly think (though i'm no expert) that being wet and cold are ideal conditions for curing concrete.
Oh and i'm not sure but I remember seeing a documentary on the construction of a huge dam somewhere (maybe in the U.S. or China? pfft) where they actually had to chill the concrete to prevent it from curing too rapidly.
And I think they actually added ice to the mix when building the Burj Dubai. But that was to stop the mix from seizing under the pressure when being pumped up so high...
snowluck2345 in reply to ballagieApr 7, 2011. 10:37 AM
Its the hooover dam.
surroundsound5000 in reply to ballagieApr 3, 2011. 7:38 PM
If it's really cold it can be important to keep the pour warm while it cures, because clearly there would be trouble if the water in the mix was to freeze.
Large pours have to be watered, often for several days after being laid, because the curing reaction is exothermic. Setting concrete actually produces some heat, so a large amount of concrete setting can cause enough heat to be problematic.
I've never bothered with the semantics of concrete vs cement, and I figure nobody will be confused by using set, cure, and dry interchangeably.
badideasrus in reply to ballagieOct 20, 2010. 12:38 PM
well, if the concrete dried to quickly, wouldn't it crack? like mud?
Canoeman in reply to badideasrusOct 2, 2011. 9:39 AM
It can but is more likey to spall.
Thats when concrete freezes, or cures too hot, and after curing the top smooth surfaces slake off in chunks, exposing the rough rocky interior, making surface look like broken concrete.
Canoeman
badideasrus in reply to CanoemanDec 6, 2011. 11:00 AM
interesting.... might be a design element to take use of. that is if the concrete wouldnt just fall apart or something.
andybuda in reply to SugargirlDesignsSep 11, 2009. 4:28 AM
but the weird thing is concrete will set under water and is alot stronger because it cures more evenly
Austinisi in reply to SugargirlDesignsJun 4, 2009. 12:12 AM
I'm not sure if you said this or not (I couldn't understand what you said exactly), but cement is an ingredient for concrete. Concrete is made up of sand, rocks, cement, etc.
techtable says: Jan 10, 2010. 10:04 PM
 an interesting idea would be to embed fiber optic cables in the concrete, to make it slightly translucent.
DIY-Guy in reply to techtableOct 24, 2010. 8:10 PM
Fiber optic transmission of light through concrete is a good idea that has already been done.
Without the expense of communications grade fiber optics, acrylic rods and fishing line have been used to transport light through concrete in years past.
Jeremyrooker says: Oct 13, 2008. 4:39 PM
Ok so I did all the steps but I'm still having trouble getting the light to shine though the concrete.... any suggestions? Btw if it dont let light though it makes a great hat.
badideasrus in reply to JeremyrookerOct 20, 2010. 12:43 PM
lol. 15 lbs hat.....
sensoryhouse says: Sep 3, 2010. 12:55 AM
One of the best lamps on here. Period.
ConcretePhil says: Oct 3, 2008. 7:24 AM
Great work! I'm in the decorative concrete field; counter tops, floor overlays, furniture, vertical stamped and hand carved concrete, and on occasion a dinosaur statue :) This is a design I haven't seen. I will definitely be making one of these. Thanks Concrete Phil
andybuda in reply to ConcretePhilSep 11, 2009. 4:33 AM
concrete phil i know a concrete pete u 2 should meet up
andybuda says: Sep 11, 2009. 4:20 AM
I'm thinking of using two pieces of glass and putting a mould on the front to take speaker drivers so the front has the two edges as glass with speakers down the center that would be cool .... the sides could all so have a design in them "its a shame to have all the sides in glass under concrete and not use it" if i get round to doing this ill let u know should work though...let me know what u think... did you use any mould oil on the wood/foam.... or do you think if i used plastic over the inside of the moulds that would work cause i like the very smooth finish it produces...
jamesccostello says: Sep 10, 2009. 11:21 AM
am I seeing correctly that your wall is also covered in / made of concrete?
otoupalik says: Sep 10, 2009. 7:20 AM
Very beautiful!
ixisuprflyixi says: Aug 3, 2009. 9:39 PM
Very stylish, very modern and sophisticated. I love it.
pepsiqueen says: Apr 18, 2009. 10:32 AM
this project reminded me of something i would have done for a class back in architecture school. then i saw the image with the graphic standards in the background and couldn't help but laugh! Thanks for the post.
gosub says: Jan 14, 2009. 7:45 AM
Maybe not for everyone to build but yes: Slick.
Aerospaced says: Oct 2, 2008. 9:01 PM
That is freakn' slick! One thing I learned by casting metal, porcelain, wax and plaster: use a release agent. I find petroleum jelly works best. It's messy, but it will fill any little voids that the material will get into and cause your mold to stick. I think I'll try this one with a twist. I want to put colored glass on top of the large panes in a pattern. Sort of like a stained glass effect. Or maybe a T.A.R.D.I.S. !
hands_on (author) in reply to AerospacedOct 2, 2008. 10:30 PM
To answer a few questions: It's 16" tall, 4" square. Probably weighs about 15 pounds. Walls of the shade are 1/2" thick. Yes, your formwork needs to be able to release. I used packing tape which works well on flat surfaces and leaves a smooth finish. Petroleum jelly works well but can leave marks. The glass is smooth enough so no concrete will stick to it. The design is intentionally restrained. There's a lot you could do with this technique. Please, modify and experiment. I'd be curious to see how it goes. Thanks for all the nice comments.
SugargirlDesigns in reply to hands_onJan 10, 2009. 11:43 PM
This is a GREAT design! I love the "Industrial" qualities, but also that it looks Modern, Sleek, and totally Fresh! I really, really do love it! I might try this, but, I might think about adding that material(s) that they add when making Planters, in order to make it more lightweight and less costly. I don't know. I've been thinking, though, of adding lamps, one of a kind and others, to my list of "products" to sell once I get my website up and running. Even if I altered this design a little, I think I'd feel that I would have to credit it's original design to YOU. How could I go about doing that? Would you have a problem with that?
charonme says: Nov 19, 2008. 12:38 AM
Stick tinfoil on the outside of the glass (between the glass and concrete) so that a bit less light is absorbed by the inside concrete walls. This might make the overall light output a tiny bit brighter and reduce heat buildup a little.
SugargirlDesigns in reply to charonmeJan 10, 2009. 11:11 PM
Or, what about using Copper-Foil Tape, as is used in Stained Glass Constructions? Just a thought. It might be a little less work and a little neater. If anybody else already suggested this, sorry, I haven't read the whole thread yet, and I am new here.
Abhorsen says: Jan 5, 2009. 1:06 PM
That's pure genius. I love it 5.0! I'm soooo gonna do this!
simplicity is key says: Jan 4, 2009. 8:22 AM
Thats awesome. This would cost ALOT in a store. Remember: BE PEACEFUL BE ZEN BE SIMPLE Great job!
mikedoth says: Dec 18, 2008. 4:26 PM
How heavy is the final product?
Mediacenterpc says: Nov 20, 2008. 3:03 PM
Excellent Work.
Carlos Marmo says: Oct 29, 2008. 11:45 PM
Wonderful Work! Congratulations!
tchiseen says: Oct 2, 2008. 2:38 AM
Great work, good instructions and pictures. Rock on.
drummonkey92 in reply to tchiseenOct 8, 2008. 12:22 PM
haha rock on lol great lamp!
JorritJ says: Oct 8, 2008. 12:48 AM
A simple trick to avoid bubbles in the concrete is to hold a sanding machine against the mold. This will vibrate te mold and force all the bubles in the concrete to go up.
hot-fresh-rider says: Oct 7, 2008. 3:49 PM
well done from Rick in the UK
nerdologist says: Oct 4, 2008. 2:59 PM
You deserve an award. We loves it.
WildBlueRhino says: Oct 4, 2008. 2:55 AM
Dude, it look like it should belong in the Citadel in HL2 :) Great work.
totoro47 says: Oct 3, 2008. 6:21 PM
my idea but i don't know if it is can be ok : mix the rockite or concrete with pieces of colored glass (from broken bottles why not?) to get some transparency effects of diffusing colored light through the semi-opaque "walls" of the lamp. i think doing so , we will absolutely need a good vibrator to eliminate the bubbles catched in the mixture and get flat surfaces. what do you think about this ? any ideas of low cost fibrous materials to mix the rockite with to keep the whole thing strong enough but light regarding the final weight ?
puffyfluff says: Oct 3, 2008. 4:42 PM
Nice and modern. I love it!
gadgetcollector says: Oct 3, 2008. 1:53 PM
Cool....Use wood....it's more light weight...I made a lamp from wood and from concrete...the only difference is the weight.
nejo0017 says: Oct 3, 2008. 10:36 AM
Very well done! I never worked with concrete, but soon I'll do :)
i.am.flink says: Oct 3, 2008. 4:06 AM
If you have a reciprocating saw, you can fire that up and touch the handle to the top of the mold to encourage air bubbles to rise and avoid leaving any voids in the material. What you're going for here is a small, intense vibration.
i.am.flink says: Oct 3, 2008. 4:03 AM
Pam works rather well. It's easier to apply and doesn't have the risk of leaving a "shadow" in the finished concrete the way Vaseline can do.
Geordiepom says: Oct 3, 2008. 2:01 AM
It's a long time since I have rated an instructable 5 stars. Excellent. Very timely too as I have just snaffled my mate's mixer. I have a couple of countertop/bar projects to do and I can just see this sitting on at least one of them. A couple of things I've learnt in my recent research: cheapo vegetable oil spray makes a good release agent and an orbital/jitterbug sander without paper is good for vibrating out any air-bubbles.
cyc4015 says: Oct 3, 2008. 12:57 AM
and I recommend filling the mold halfway, and then pushing a long stick into the mould to release some air bubbles, then filling it more, stabbing more, etc, until it is full, it'll make it stronger and smoother.
saltoricco says: Oct 2, 2008. 10:38 PM
Wickedly creative and well described. Aced!
tdbtdb says: Oct 2, 2008. 2:39 PM
If this rockite stuff is similar to regular concrete, you want to cover it with a plastic bag or something to make sure it stays wet while setting.
solo.card says: Oct 2, 2008. 1:58 PM
So how much does the beast weigh? I like it.
yngla says: Oct 2, 2008. 11:58 AM
Just love it!
comodore says: Oct 2, 2008. 11:36 AM
Great job! It looks grate! So conceptual! Great art work! rate:*****
StickyC says: Oct 2, 2008. 11:23 AM
Could you coat the inside of the glass with vaseline or similar to make it easier to remove concrete spillage?
jessyratfink says: Oct 2, 2008. 10:06 AM
That's really great! I love how clean it looks. Very sleek. :)
Grey_Wolfe says: Oct 2, 2008. 9:58 AM
This is very cool. A nice modern feel without being tacky like most modern art and furnishings.
Solderguy says: Oct 2, 2008. 12:03 AM
Doing this on a much smaller scale, seems plausible; of course, concrete doesn't fall from the sky.
omnibot in reply to SolderguyOct 2, 2008. 2:33 AM
I think I speak for all when I say we're very glad it doesn't. Neato lamp though.
Valche in reply to omnibotOct 2, 2008. 9:24 AM
Hahaha.
cornflake_81 says: Oct 2, 2008. 12:03 AM
Cool! That really looks fantastic.
kenbob says: Oct 1, 2008. 9:41 PM
Great Job!
Firstaccount says: Oct 1, 2008. 8:33 PM
genius.
Painkilla05 says: Oct 1, 2008. 8:04 PM
This is very clever.
LinuxH4x0r says: Oct 1, 2008. 6:50 PM
Love this idea! Featured
shooby says: Oct 1, 2008. 1:09 PM
Not very efficient as a standard lamp, but as a work of art/sculpture, this is beautiful. Concrete is so plastic. Do you do any free form work with it?
gmjhowe says: Oct 1, 2008. 1:59 AM
Excellent work! i love it!
thearchitect says: Oct 1, 2008. 1:47 AM
Brilliant!.. K.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
