Step 4Preparing the mold
Regardless, it need to be 3" square, exactly, and the same length as the outer mold, PLUS the amount you want it to "float" above the base, if you want to do that. I used 3/4". This way, the base can rest on this while we cast the feet into the shade, and it'll keep the right spacing (see photos).
Ok the glass. You can glue the glass directly to the inner formwork, as shown. This way, the glass will be exposed on the inside of the shade. This glue will come off easily when you release it. The thick piece of glass overhangs 1/2" on either side of the inner formwork. The other 2 pieces butt into it and overhang 1/2" on their respective sides. Obviously, you can modify this layout. There should be at least 3/4 on the top and bottom. This is critical so that the concrete has some structure, since we're cutting it all up with the glass.
Now slide it into the outer formwork. This might require loosening some screws. This is not an easy step. You'll have to futz with it. If your measurements were good, it will be easier. It's critical that the glass butts into the outer formwork so that the edge will be exposed, and that it is securely glued to the inner formwork, so it will be exposed in the inside, so the light can get out. This will take patience. Trial, error, adjust.
The last step, once the formwork is adjusted, tight, and SEALED (you can use the glue gun like caulk if need be), invert base over the top so that you can cast the legs into the shade. Make sure they're reasonably straight, and that everything looks good. Take it out. Next step: pour.
comments
Add Comment
Add Comment
