3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
concrete rocket stove
Here's a rocket stove that will outlast you, but it's cheap and easy to make.  But it takes sawing concrete...   I used a 7" diamond blade on a circular saw for the occasion.
This takes three 8" x 8" x 8" blocks and a 8" x 16" x 1" slab for a base.  One block needs the side sawed out so it can make the bend.
This is a true rocket stove, even though it is not insulated.  To start it, you may need to throttle it by putting something on top to choke the exhaust air a bit.  You might drop some dry dirt or sand down the chimney to insulate the base, but it's not needed.
It takes 1 1/4" standoffs on top for a pot so the flow is not restricted.  Use rocks or sawed off pieces of the cutout.
The only thing that needs replacing is the coffee can  in the inlet to raise the wood 1 1/2" for the air inlet.
5 comments
Apr 19, 2012. 7:04 AMdanzo321 says:
Seems like they make U shaped block already, for endcapping garage doors etc.
Apr 19, 2012. 6:41 PMmorgano says:
This looks promising, but you need clearer instructions. I think I can figure it out just by looking, but you must reveal your secrets! Show us the exploded view, at least.
Mar 2, 2012. 5:47 PMquzie says:
This is terrific! I'm going to find a way to get the block cut! We went through a storm in April, no power for 10 days and no phone/internet for 32 days. Thanks Quzie
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Tim Temple(The Order of Saint Patrick)
An Aspergers whose specialty is Christianity.
