3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
convert a tire inflator-type air compressor into a vacuum pump
Step 2Find the air intake
find the air intake
Once the case is open, you can flip the motor/pump assembly up and inspect the cylinder to find the air intake---that is, the holes where the air comes into the cylinder before it's squirted out the compressed air hose.
Some pumps have a hose barb or other fitting connecting to a muffler. If yours does, that's great---you can just use the hose barb that's already there.
This pump just has four little holes in the top of the cylinder. (Actually, there's a little filter under the holes, but we can ignore that.)
Unfortunately, the holes are down in a funny-shaped recess, so we can't just glue a hose barb directly over them. We also want to make sure that the glue doesn't slop into the holes, so we need a couple more steps to make things fit.
2 comments
Aug 27, 2010. 5:14 AMbomihdar says:
thank you
Apr 6, 2008. 4:34 PMdrhoff says:
First, I'd like to say great job on this and your other instructables. They are very nicely done. Second, I would like to add a comment about this project. Some models of little inflators like this one, will not work for this method. The Tool Shop version I bought has a different air intake setup. The intake is built into the piston of the pump, much like a bike pump would be constructed. But the way it is built, you can't flip it around to make it suck air in.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:drcrash
I'm a research scientist who likes to design and build things, especially cheap, elegant tools for building things you wouldn't have thought you could make yourself.
